Aiwa Shelf system volume control doesn't work right
Apparently (I believe it is the same type of volume control on most of these systems) the volume won't go down when knob is turned counterclockwise and vica versa. I have to spend a lot of time turning the control both directions just a little bit to effect a volume change, usually not to a level I want. Is the volume control defective? It does not act like a standard volume control that has stop detents at min & max levels. This is an international version as my son purchased it in Germany and it has dual voltages plus dual AM channel spacing for Europe and the U.S.
  • 1 more comment
  • dalynns Oct 13, 2008
    I have the same problem with my Aiwa cxzl31 stereo, is it worth fixing?? the volume knob just spins and only goes to 5... very little volume
  • mihkel Dec 14, 2008
    Hey, my volume button doesn't work at all. My model number is NSX-S514, could Abrsvcs give me the part number?
    Mike
  • Anonymous Mar 29, 2009
    NMT 520 is my unit. The volume only goes to about 5, then goes back to zero even though i am trying to turn it up? How to fix? email at huskiefan at aol dot com
  • 4,234 Answers
The part in question is called an encoder. I have had to replace this part on a number of Aiwa units. If you can post the model number off of the back, I''ll get you the part number.
Dan
Posted on Oct 01, 2008
Y have a proble whit my vlom control he dont exisat in my pc
Posted on Nov 17, 2008
I have 2 AIWA CX-NA303 volume can only be controlled from remote. Cassettes no longer play and doors won't open to remove them. Where are repairs available?
Search Results
    images for aiwa audio shelf systems service manual
    Free Aiwa Stereo System User Manuals ' ManualsOnline.com
    audio.manualsonline.com > ... > Aiwa > Home Audio Aiwa
    Products 1 - 50 of 107 - Aiwa STEREO RECEIVER User's Manual AV-S17. Pages: 0 Saves: .... Aiwa Compact Disc Stereo System Operating Instructions CX-NA22
Oct 21, 2015 | Aiwa Audio Players & Recorders
Aiwa cxzr555u
Hello. I had a similar problem with my AIWA ie. erratic control of volume. I found a how-to on youtube which describes how to take apart the volume control, clean it, and put it back. It now works fine. For me, the tricky part was getting to the front face of the PC board.
Feb 02, 2014 | RCA Audio Players & Recorders
The volume go up sometime and down sometime when i am turning it up.
Bad volume control. Would need to take apart the control and clean the contacts as the part is probably not available anymore.
Jun 20, 2013 | Aiwa Z-L30 Shelf System
I have an Aiwa cx-nma545 that I just hooked up to a Westinghouse SK-32h640g. The sound is very muffled. The sound is fine if I have it on cd or the radio but when on Aux Video I can barely here it.
On most TV's with speaker control there's a way to disable the TV's volume control effect on the level fed out to an external amplifier. Find it and disable it it or select FIXED for its level, or, while listening through the Aiwa, raise the TV's volume through its own remote and see if that affects what the Aiwa gets for volume.
Or, enable the TV's speakers but find the same interna lAudio setting and make it Fixed, but turn the TV volume down if you don't want to hear its speakers. That way, you could actually listen to the TV on its own speakers if you want, say, for casual watching of the Weather Channel or news, for example.
Nov 28, 2009 | Aiwa NSX-DS55 CD Shelf System
I need a part # for the volume controle on an Aiwa
The "volume control" on your Aiwa is in fact what is called an "encoder". These can fail. They work in concert with the microprocessor to control the electronic volume control IC. Yes this part can be replaced. Try calling Sony with your model number and request the part number for the volume encoder. They should be able to help.
Dan
Aug 24, 2009 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
Speaker left/right balance control
This Aiwa audio system has no balance control as its already balanced.
May 19, 2009 | Aiwa NSX-AJ20 CD Shelf System
Why does the volume go all the way up when i put it to 15?
aiwa typical issue. loved my aiwa's sound hated the stereo. my volume control knob did the same thing and i had to order a new control.
please take time to rate,
good luck
Ryan
Feb 16, 2009 | Aiwa NSX-DS55 CD Shelf System
AIWA shelf system volume button
I'm sorry but I don't have a listing for that model number. Many of hte Aiwa units use what is called a digital encoder. A call to Sony with the model number should get you the part number as well as the cost and availability. Aiwa is a brand of Sony.
Dan
Dec 15, 2008 | Aiwa NSX-DS55 CD Shelf System
Volume knob
Normal Aiwa compact shelf units use what is called a jog switch for the volume. Usually you can tell the difference if when you you turn the volume up or down. It goes a short distance and seems to spring back. In this case there are two momentary contact switches. One for up one for down. With a plastic lever on the back of the knob that bumps the approriate switch whether turning down or up. If the lever is broken it will bump up against one but not the other. If it is broken plastic you know how good gluing plastic goes it never seems to hold.
Aug 02, 2006 | Aiwa NSX-A777 Shelf System
873 people viewed this question
 Grubhead
Grubhead
