Question about Frigidaire FRT18B4A Top Freezer Refrigerator
Condensation on refrigerator front btwn top freezer and refrigerator doors
Frigidaire top freezer, bottom fridge. Actually is model FRT18TJHW1, but that is not in the product list below. It is going on 8 yrs old. Dial settings in both areas have not been changed in years. Same quantity of items in each area as typically are there. Neither area is empty or unusually full. We have recently noticed moisture on the front face of refrigerator - both underneath and below the edge of the freezer door bottom edge gasket. It is causing mildew/mold to form in the ridges of the top gasket of the refrigerator door. The freezer door gasket seems like it is nice and snug, but how can I know? What else can I check for? Any ideas?
  • Anonymous Oct 09, 2008
    I have a similar problem-- the refrigertor is brand new, but there is some condensation on the front doors (both the freezer and refrigertor door). I've done the dollar bill test (that is, put a dollar bill in the door and see if the seal can hold it), and the seal is tight. Any ideas?
I have the same problem with my frig in the basement. I get condensation and resulting mold on the top outer surface and related areas. This is from the surface being cold, with resulting outside moist air condensing on the cold surface. Best solution - spray/wipe the surface with a bleach and water solution, let it soak a few minutes, then wipe off with a rag. Add a drop of dishwasher soap to a mixture of roughly 4 parts water to one part bleach. Repeat if necessary. Do this as often as the problem seems to creep up again. Good luck!
Handyman in NJ
Posted on Oct 11, 2008
Frigidaire frige warm between freezer door and refrigerator door
It's probably something called the YODER LOOP, which keeps condensation from forming between the fridge and freezer doors, If it is only slightly warm it's probably normal.
Aug 12, 2015 | Frigidaire Refrigerators
I have a 7 year old 21 cubic ft., top freezer Frigidaire refrigerator. There is always water dripping down the back of the inside of the fridge, which then pools in the well in the bottom. It seems like...
syringe the tube with clorine bleach.dry out the interior then cover all food to cut down on condensation,although most freezers are "frost free"the fridges ARE NOT.so most of the problems are condensation.....
Sep 02, 2010 | Refrigerators
Water leaks from underneath
Make sure your drainage tube is not plugged.
Check inside the back of your fridge to make sure the little cup that collects condensation from your freezer compartment is not plugged with food or ice.
(I had that happen in my fridge,different model). I had lots of water on the floor of the fridge until I found this solution here on fix-ya.
Also, make sure your fridge is set right for the the humidity levels you have may experience.
Get a hold of the manual for your fridge if you don't have it, and make sure freezer is not too cold.
If you have a lot of condensation on the outside of your door, look inside your freezer and try some different settings.
I'm not sure if this helps at all. Try blowing with a blow dryer on your condensation container area on the inside of the fridge.
I'd love to know if this helped.
Aug 26, 2009 | Frigidaire FRT18B4A Top Freezer...
I have an extreme amount of condensation appearing in my new frigidaire. my shelves are wet and the food at back of my top shelf has frost. (i live in los angeles, not too sure if that at all factors into...
If it's new I would think the door gasket is ok but that's one thing that could cause it.
The air has to circulate by way of a vent between the freezer and fridge. Make sure the vent door is opening when you adjust the fridge temp.
To complete the circulation the freezer fan behind the back panel inside the freezer must work and the evaporator coils near the fan must not be iced up blocking the air flow. (defrost failure.)
Aug 09, 2009 | Frigidaire FRT17G4B Top Freezer...
Water under veggie bin in fridg. model frigidaire F44Q21RJ,
possibility's:
1 There is a drain that carries away the water under the cooling coils. These coils are in the freezer section.
2 The damper going to the crisper( s) is open too far allowing cold air to cause condensate on the fridge wall or bottom.
3 The freezer section is not defrosting and there is a spot where the ice buildup is allowing conductive cooling into the refrigerator section and therefore is allowing condensation on the refrigerator wall or ceiling.
4 The refg section has a heater (possibly not positive) in the area of the door frame, or it may have a "power saver" switch. This switch and the heater (if it has a heater it may not have a switch) are designed to stop condensation on the refridg while running. I fit is placed in the "power save" mode it turns off the heater. But, if you live in extream humidity (Great lakes east side or Gulf coats Houstion...) the humid air will condensate water out and it will collect and settle on the floor.
5 Door gaskets are not sealing especially on the bottom of the door. This allows warmer air into the fridge section and it is condensation on floor under the crisper.
If you check all of these items and still cant find it please post back and tell me what you did find. So I can help you more. Please rate me as much as possible as Im trying to keep my average up and do the things that will actually educate and help people.
THANK you for using fixya and good luck..
Mar 22, 2009 | Refrigerators
Accumulation of water in bottom of fridge
You probably need a new door deal for the freezer. When you cet too much condensation in the freezer, it drains down the back of the refrigerator section during the defrost cycle. Check under the produce bins for a drain. If you don't have one, you're not alone. I used to have have to wipe mine out every other day until I finally replaced the seal.
Feb 02, 2009 | Frigidaire FRT21G4B Top Freezer...
Frigidaire Side-By-Side Top Not Cooling
the unit is loosing the freon supply to the evaporator.you either have a leakage,a blockage or the compressor is not pumping to full capacity.
Nov 05, 2007 | Frigidaire FRS3R5EMB Side by Side...
Condensation problem hotpoint mistral 8596
if the door seals are both ok, check and see if she has any open containers in the fridge juice ect that may be allowing moisture to escape. a model number and serial nuber off the sticker in the fridge would help me with more ideas.
Sep 25, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Frigidaire FRT18B4A Top Freezer Refrigerator Logo
1,597 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
