I have a panasonic sa-pt960 home theater system which i just purchased about 2 weeks ago. i am not getting any power into the system, i have already checked connections and tried multiple outlets for the system. everything else i have plugged into the surge protector still works. is there a history of power failure on this sound system?
  • KANO1988 Oct 22, 2008
    I have PS3 and i try to connect the sound system to it but it dont !
    iam not sure why ?
    please can u help me fixing that
Did you connect the optical cable from the dvd component to the ps3?
Posted on Dec 13, 2010
I had to replug things in for my dish and unit sat sidewards to get to plugs. It now says locked and can eject disc, select source. Help
Try this:
Press and hold [?] (Stop) on the main unit and [>10] on the remote control until "INITIALIZED" disappears from the TV. Turn the unit off and on again.
All settings should return to the default values.
Not saying it will work though!
Not
Dec 31, 2015 | Panasonic...
How to connect a blue ray player with the sc pt760 sound system with dvd?
According to the models you provided it looks like the DVD player has only HDMI out and the sound system you have does not directly support that. I would suggest purchasing a HDMI audio extractor so that you can covert the digital signal from your blu-ray to an analog signal. However, there are other ways of doing this. If you provide me with your TV that you use I might be able to advise another work around.
Go on google and look for "hdmi audio converter" or "hdmi audio Extractor".
Make sure to look at review to determine the quality of the product and decide what device fits your budget.
Nov 23, 2015 | Panasonic...
Sa-pt960 ipod won't load
Please check iPOD Doc port of pins condition. available parts for model Panasonic SA-PT avsystemparts.com
Oct 05, 2013 | Panasonic Home Theater System System
I have a Panasonic SA-PT960 surround sound/dvd player. Whenever I turn it on I get a chgr err flashing on the screen and a loud grinding noise
There is a fault with the DVD Changer and the noise is the gears grinding. This is a common fault with these units as a small arm within the unit breaks and blocks the mechanism.
You can either try and replace the complete DVD Changer or remove it and just us it as a surround sound system with your auxiliaries connected to it.
May 09, 2011 | Panasonic SC-PT960 Theater System with...
I have a Panasonic SA-PT960 surround sound/dvd player. Whenever I turn it on I get a chgr err flashing on the screen and a loud grinding noise. I only use it for surround sound but I cannot use it for...
Hi! the chgr err code indicates one of you trays is stuck inside the dvd tray unit. this occurs typically when the reader is initializing the last disk viewed and you push the exchange disk button. This happened already twice on my system. I did solve the problem by opening the unit and removing all components until I could access the trays and manually release the mechanism. I only recommend doing so if the player is out of warranty and if you are not afraid on working with small electronic/ components parts. I could not find any other non-invasive solution to the problem.
Jul 05, 2010 | Panasonic SC-PT960 Theater System with...
SET UP VIERA LINK PANASONIC PT960
Can you explain a bit more please. What exactly is the problem? Are you getting any picture or audio through to the TV? Are you getting any picture or audio through to the home theatre? Have you got the home theatre setup via HDMI? Have you connected the audio from the cable to the home theatre via optical or phono? What model is your LG LCD HDTV?
I already have the manual in front of me for your home theatre system. If you can give me some more information I can help you out.
Thanks.
Nov 30, 2008 | Panasonic Home Theater System System
Panasonic home theater SA-HT940
the best thing you do is set the region to ply coz some of the dvd player need to set the region
Mar 24, 2008 | Panasonic 600W DVD+VCR Home Theater System...
617 people viewed this question
 Grubhead
Grubhead
