Question about LG KU990 Viewty
Setting the number of rings before voicemail cuts in
My voicemail cuts in after only three rings. This is too quick, I would like to set it to 6 rings.
How do i do it on my U990 Viewty?
    Problem Solver:
  • 17 Answers
This is controled by your mobile phone provider. not an phone issue
Posted on Oct 04, 2008
Why does razr goes to voicemail too quick
It could be that the phone is delayed in ringing. Try placing a test call and see how many times it rings in the phone you are calling from before it rings on the phone. Then you can determine if the phone is delayed in ringing. If you hear ringing and the phone rings once and then it goes to voicemail then there may be a setting on your phone that is causing this.
Mark
Motorola Support
Jun 01, 2014 | Motorola Mobility DROID RAZR MAXX HD
My att cellphone only rings 4 times before voicemail
If the problem is with an AT&T cellphone you will need to call them or go log in online to change that feature, however if it is with a Uniden Cordless Phone (the product this question is linked to) the directions below found in their manual should help:
From the base
1) Press [clock/menu] three times. The base displays the current number of rings (2, 4, 6, or TS for toll saver) and announces the setting.
2) Press [>>/select] or [<</select] until the desired ring time appears.
3) Press [set]. A confirmation tone sounds, and the answering machine announces the new ring time.
From the handset
1) Press the MENU soft key. Select the ANSW. SETUP menu, and then the RING TIME submenu.
2) Move the cursor to select a Ring Time (2 TIMES, 4 TIMES, 6 TIMES or TOLL SAVER).
3) Press the OK soft key. You will hear a confirmation tone.
Hope this is of help
May 05, 2014 | Uniden Cordless Phone
How to change recording on day/ night mode
This depends what voicemail you have, SVM OR TVM. and you need to know what group rings in each mode SVM day *47 (voicemail extension number) (PIN number) *38801 record STORE NIGHT *47 (voicemail extension number) (PIN number) *38811 record STORE TVM voicemail extension number (500 or 200) #6* (ringing group number) option 3 then 1 then 1 follow the prompts
Aug 12, 2013 | Panasonic BTS KX-DT343-W-NR Digital Corded...
Our phone only rings 4 times before it goes to voicemail.
Depending on your phone ,but you should be able to adjust it in your setting and that is in your phone menue
Apr 24, 2012 | Samsung Prostar DCS-24B-LCD Corded Phone
Hi I have a Panasonic cordless phone kx tg2511al. I sometimes find that incoming calls go straight to voicemail without it ringing first. How do I make sure it rings at least a good number of times...
Remove the battery and allow the set to phone to reset. Now check for the ringer setting at teh back of the base phone to be set to the maximum rings, there can be three settings.
Some times this is also set on the menu.
Connect and test the timing to confirm
Jun 13, 2011 | Cell Phones
My Samsung Jet only rings three times before going onto voicemail. Can't find how to set ot to ring longer. Thanks in advance
This is a setting that you cannot change from your handset. You will need to call your wireless provider and they can lengthen the ring time before your calls are routed to the voicemail system.
Mar 19, 2011 | Samsung Jet S8000 Cell Phone
Set number of rings before voicemail iphone
This procedure allows your iPhone to ring for longer or shorter periods than the default setting of 20 seconds before voicemail answers. *** Attempt at your own risk but if you pay attention to the keys you input and follow the directions you should have no problems.
1. On your phone, dial *#61# and click Call
The screen will display:
Setting Interrogation Succeeded
Voice Call Forwarding
When Unanswered
Forwards to +1xxxYYYzzzz
Enabled
2. Write down the xxxYYYzzz number (including +1) - this is the number to your voicemail.
3. In order to make the + appear on the keypad in the next step you'll have to hold Zero down for a few seconds, then it will become a Plus (+). Dial **61*+1xxxYYYzzzz**30# and hit Call. +1xxxYYYzzzz is the number you wrote down previously, 30 is the delay in seconds. The delay can be set in 5 second increments, 30 is maximum.
4. Dial *#61# to verify that the new settings are active.
5. Verify working voice mail.
If you find you or your contacts are not being forwarded to your voice mail you have incorrectly altered your voice mail forward number.
To find out what it is and try again:
Dial ##002# and send. This will reset that forward number to factory defaults.
By then Dialing *#61# you will again display the your current (default) voice mail forwarding number.
Return to step [2] and continue.
*** Use this tutorial at your own risk ***...and if you have the time you can always give AT&T a call to have them change the number of rings on an incoming call before Visual Voicemail kicks in. I was able to quickly change the duration on my own, using these diagnostic iPhone GSM codes. The default time duration before Visual Voicemail intercepts the call is set by AT&T to 20 seconds. You will be able to add another 10 seconds yourself, but if you want your callers to wait more than 30 seconds before voicemail picks up then you'll need to contact AT&T technical support - they can change the duration to 45 seconds upon request.
Dec 19, 2010 | Apple iPhone 3G
Incoming calls ring 3 times at main extension, then phone stops ringing at main & rolls over to ring at all other phones. Phone rings once at those extensions before going to voicemail. (We have...
Your voicemail thinks that it is ringing six times. The time that it takes to transfer to the extensions counts. Whiloe it seems that there is a lapse the system actually is using enough time to ring six times total. If you need longer ring time at the extension, take in account the transfer time and set it to pick up after 8 or 9 rings. It will actually only ring six. You just have to trick the system a little.
Jul 22, 2009 | Cell Phones
Fax answers on phone calls.
Hello There. Most household all in one units cannot operate on the ring characteristcs that you are describing.
They simply operate on the number of rings before automatic pickup to the fax machine. Therefore, you will need to just change the number of rings before the fax machine picks up. In this case however, you will not be able to use voicemail, since one or the other will will pickup.
http://h10032.www1.hp.com/ctg/Manual/c01102249.pdf
Page 63 and 64 (in PDF) or page 62 and 63 (hardcopy manual) explain the process.
Ignore the information about setting higher then voicemail. That information is typically only valid if you have the old voicemail devices in your home. Most people now adays get a voicemail service added to your telephone service, in which case you cannot control the voicemail as easily.
So again, in other words you will be sacrificing your voicemail for your fax machine. Only other way around it is to get a dedicated fax line to seperate the two numbers.
Feb 26, 2009 | HP Photosmart C6180 All-In-One InkJet...
3com NBX phone number of rings setting problem.
Delete the MAc Address from the system and delete the user account. Re add the phone.
Feb 12, 2009 | 3Com NBX 2102 IP Phone
LG KU990 Viewty Logo
150 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
