Question about Olympus Stylus Zoom 140 35mm Point and Shoot Camera
Large, bright orange light streak in pictures
Olympus stylus zoom 140. Camera was great for about 2 years, pictures were great. My last two rolls of film developed with large, orange light streaks running vertically just to the right of center. Additionally, there were several "blobs" of orange light left of center. This occurred on 90% of the pictures, the remaining 10% were fine. Is this a light leak in the camera body? Is it worth trying to get Olympus to repair? Of course, the camera is now out of warrenty. Thanks for your time and help.
  • Olympus Master
  • 3,976 Answers
It does sound like a light leak, but hopefully all that has happened is that the foam seals surrounding the film compartment have perished and need replacing. With luck, this is unlikely to be expensive - check with your local camera shop or second hand camera dealer.
Posted on May 20, 2017
Agent Allan
  • 480 Answers
SOURCE: Zooming with Olympus Stylus 820
Hey missy0528,
There are a few reasons your images might be grainy, one of which is your image quality is set to low. I would always have the camera set to the highest resolution possible, because you can always reduce the size of an image but you can never make it bigger. Another cause of grainy images in digital cameras is the sensitivity of the camera (ISO) is set to high. Since you are only seeing grainy images when you use the zoom the reason for the grainy images is most likely do to using the digital zoom. All a digital zoom does is crop the image much as you can do in some computer applications, and by doing this you greatly reduce your image quality. I would never use a digital zoom. Your camera has a 5x optical zoom and a 5.6x digital zoom. I would only use the optical zoom. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Posted on Jun 10, 2008
  • 479 Answers
SOURCE: SP550UZ photos show vertical purple streaks if bright reflection
reset the camera using the menus
Posted on Jan 20, 2009
SOURCE: Olympus Stylus Zoom 140 All Weather 35 mm
Make sure the flash is coming up all the way. If it gets stuck even slightly down from fully raised, it will do what you describe.
I agree, digital P&S won't work as well as your Olympus. Plus all your shots will have to be stored on a hard drive-
Posted on Feb 08, 2009
  • 32 Answers
SOURCE: Flshing ''E'' on my Olympus Stylus Zoom 140 35mm camera
The flashing E indicates the film is already rewound.   If you're concerned about it not being fully rewound, open the back in an absolutely dark room. A windowless bathroom or walkin closet will work. Block the bottom of the door with a towel or blanket and make sure there aren't ANY light sources in the room. No charger lights, smoke detectors, etc.
If the film is still hanging out, carefully handle it by the edges only & gently remove it from the camera. Try not to kink it. You can manually wind it back in the cassette by rotating the post on top.
You can download the owner's manual from Olympus at http://www.olympusamerica.com/files/Sty_Z140.pdf .
Posted on Apr 09, 2009
pontelemon
  • 531 Answers
SOURCE: I look through viewfinder and view is out of focus
Yes, common problem, small plastic tab(s) connecting viewfinder to the zoom are broken.
Posted on Apr 19, 2009
How to fix olympus fe-340 streak and peaks verticaly when picture taken
Not sure you can fix this, but most of the time the stripes are produced in a dark environment with one or a few bright lights. The streaks start on the bright light. Most of the time if you shoot the picture the streaks are not on the picture.
You could try to switch the camera to the automatic, or perhaps night scene.
If the streaks are there in normal light, I think your camera is defect.
Jul 27, 2014 | Olympus FE Cameras
My olympus camera won't charge properly
If the camera battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Apr 02, 2013 | Olympus 228230 Model VG-140 Digital...
I've had my Olympus FE-340 for 3 years, and I've never had any problems with it before. Now, whenever I try to zoom in, the camera takes white pictures or pictures with streaks in them. I've tried reseting...
I have exactly the same problem. I am writing an email to Olympus for further advice. I beleive there is some replacement policy as this seems to be a manufacturer problem.
Apr 07, 2011 | Olympus FE-340 Digital Camera
What is the button on the bottom of Olympus Stylus zoom 140
No. You just rewound the film. The pictures you took are safe, but you probably 'lost' the rest of the film you did not shoot.
Jun 19, 2009 | Olympus Stylus Zoom 140 35mm Point and...
Apr 17, 2009 | Olympus Stylus Zoom 140 35mm Point and...
Apr 09, 2009 | Olympus Photography
Hey missy0528,
Sincerely,
Allan
Go Ahead. Use Us.
Jun 09, 2008 | Olympus Stylus 820 Digital Camera
Jan 01, 2008 | Olympus Stylus Zoom 140 35mm Point and...
Date and time change
First you press the button called "MODE" and, without releasing it, press the "SET" button.
Then, the year will start to blink.
Set the year with the "SET" button. Once you finish setting the year, press the "MODE" button to change to the month.
Then, the same way with the month, day, hour, minutes.
After minutes, the display will stop blinking.
YOUR SET!
Dec 08, 2007 | Olympus Stylus Zoom 140 Deluxe 35mm Point...
Camera lens will open then close, plus both orange and yellow lights both flashing all the time
In addition to the one year World Wide Warranty,
issued by Olympus Corporation in Japan, the European warranty, issued by Olympus Imaging Europa GmbH, is
valid for two years from the date of purchase, if purchased after 1st April 2004
Oct 10, 2007 | Olympus FE-140 Digital Camera
Olympus Stylus Zoom 140 35mm Point and Shoot Camera Logo
71 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
