Question about Franklin MWS-840 Dictionary
I have an EV38 dictionary .I just bought it for 9 months but i don't why now it doesn't work any more
Help! Changed battery but still don't work for a long time
you probably have a short in the amplifier under the driver's seat. I had the same problem. Bought mine used, but the amp had water damage due to the vents for it on the left side of the driver's seat letting in water, probably snow or something that fell in there. Was $1200 to replace. Basically your car will be fine for a couple weeks, maybe a month then the battery will die.
Aug 01, 2012 | 2004 Saab 9-3
Paper wont feed 11x17-keeps jamming ( problem with the rollers?)
For first clear rollers w/alcool or orig clearing solvent. If it doesn't solve Your problem remove the rear cover and controll the little fingers hanging in the way of sheet edge. Some of them may be in wrong position because of missing or released spiral. Fix it back with a medical clip or you may remove the whole finger (one piece) if You don't find the spiral. Control and clean the turning surface.
You need strong light in the spot because of the usally black accessories.
Don't miss monthly cleaning procedure.
May 15, 2012 | Canon ImageRUNNER 3235i Black and White...
Need the manual for th WM 1200 Don't remember
Here's the manual (.pdf file) for the Franklin "Merriam-Webster MWD-1450 Dictionary & Thesaurus
User's Guide", which has a "Games" key to get to the Franklin Games Menu, which hopefully
will let you use all the Games features of the WM 1200, since I can't find any evidence online that
a "WM 1200" exists.
http://support.radioshack.com/support_radios/doc73/73417.pdf
Sep 14, 2011 | Franklin Merriam Webster DBE-1450...
I opened my Lingo after a couple of years and put new batteries in it. It doesn't come on when I press the red button. I assume the battery contacts may be dirty, but I can't get to them
You can use a cotton swab wet with a cleaning solution (or some alcohol) to clean the battery contacts.
Electronic items are damaged faster when you don't use them. Therefore the problems might be not only with battery terminals.
Sep 04, 2011 | Lingo Office Equipment & Supplies
Why don't costco stock the magalite wireless motion detection lites anymore, model MB-DLM-82. I've bought 9 so far and would buy more but can't find them in Phoenix, AZ.
I'm guess they don't stock for they stop working in a few months.
I have three and after three months, they go on and off when they want to.
If it detects movement, they may or may not work.
Loved them until they went crazy.
There are many posts on the net about the problems with these. I'm probably going to ask
COSTCO for a refund. I suspect they've given plenty already.
See my post from today, Bob Bergg Michigan
May 17, 2011 | Costco Megabrite Wireless Motion Sensor...
Not work with new battery. i left it for 2 months with weak battery.
try replacing the batteries and pressing the reset for 10 seconds
Oct 20, 2010 | Franklin Merriam Webster SCD-1870...
Hello sir i m using samsung SGH-L700 model phone, but i am unable to install mobile dictionary or any kind of games.....unsupported file format comes when i try to install that... sir plzzz help me as i...
hello sir i m using samsung SGH-L700 model phone, but i am unable to install mobile dictionary or any kind of games.....unsupported file format comes when i try to install that... sir plzzz help me as i bought this phone only for dictionary purpose... plzzz
Jan 21, 2009 | Lands Phones
On/off button
good evening !try to chagne the battery of your seiko britannica concise dictionary efter replace the battery press the reset button ! good luck !
Mar 30, 2008 | Seiko Britannica Concise Encyclopedia...
Nokia n80 keyboard problem
These symptoms are showing that the T9 dixtionary is activated o fur phone, u just open message setting option and turn off ur t 9 dictionary
Oct 03, 2007 | Nokia N80 Cellular Phone
Franklin MWS-840 Dictionary Logo
Top Franklin Office Equipment & Supplies Experts
Michael Vincent Cruz
Greg Cann
Greg Cann
Are you a Franklin Office Equipment and Supply Expert? Answer questions, earn points and help others
