FixYa.com
Tags:
Aiwa F2000 20
A.C. through coax
By Pasty - usenet poster
What causes a T.V. to send A.C. through coax? Normal repair from Cable Co. is place a Matching Transformer between T.V. and coax keeps A.C. from feeding back and impeding signal flow to T.V.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 23, 2007
Not Rated (0)
ray1
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Problem could be in the AC outlet. I had similar problem and found that the "hot line was connected to the ground pole. Reversing the connection solved my problem.
Ray
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jun 23, 2007
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
try to turn of the tv
Solution #3
posted on May 30, 2006
Not Rated (0)
Joey2
Joey2 - usenet poster
Rating: 0%, 0 votes
AC is passed through the cable because there should be a "Isolation" device in the coax inside the TV. Your set problem is an older Quazar and the "Isolation" device is made as part of coax cable going from the tuner to out side connection. The device is bad or someone replaced it with a standard cable.
This Problem Also Relates To: GE 13R100T 13" TV Jensen TS2050J 20" TV Panasonic CT-32SL14 32" TV Panasonic CT-36SX12 36" TV Sony FD Trinitron WEGA KV-20FS120 20" TV Sony KV-32V40 32" TV Sony FD Trinitron WEGA KV-36FS320 36" TV
Can you Help with these Standard Televisions problems?
jvc information
i cant turn on tv but the on... Answer This...
Aiwa F2000 20" TV
tv blurry
picture okay sometimes other... Answer This...
Aiwa F2000 20" TV
AIWA TV-A2119 PROBLEM: SOUND...
i just s/o the tv. and when i... Answer This...
Aiwa F2000 20" TV
Aiwa Tv sound menu is not...
in aiwa tv sound menu is not... Answer This...
Aiwa F2000 20" TV
TOSHIBA TV
Hello.I have a toshiba tv that... Answer This...
Repair Service
Find Standard TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
