Question about Olympus Cameras
Olympus stylus zoom 140. Camera was great for about 2 years, pictures were great. My last two rolls of film developed with large, orange light streaks running vertically just to the right of center. Additionally, there were several "blobs" of orange light left of center. This occurred on 90% of the pictures, the remaining 10% were fine. Is this a light leak in the camera body? Is it worth trying to get Olympus to repair? Of course, the camera is now out of warrenty. Thanks for your time and help.
5 Suggested Answers
sonyspares
  • 89 Answers
SOURCE: Power button stuck in down position
You may have to change to switch portion and if you need assistance in blow up diagrom or spares, contact me.May take 3 to 4 weeks to get from Sony service.
Posted on Mar 29, 2007
SOURCE: date and time change
First you press the button called "MODE" and, without releasing it, press the "SET" button.
Then, the year will start to blink.
Set the year with the "SET" button. Once you finish setting the year, press the "MODE" button to change to the month.
Then, the same way with the month, day, hour, minutes.
After minutes, the display will stop blinking.
YOUR SET!
Posted on Mar 23, 2009
  • 32 Answers
SOURCE: Flshing ''E'' on my Olympus Stylus Zoom 140 35mm camera
The flashing E indicates the film is already rewound.   If you're concerned about it not being fully rewound, open the back in an absolutely dark room. A windowless bathroom or walkin closet will work. Block the bottom of the door with a towel or blanket and make sure there aren't ANY light sources in the room. No charger lights, smoke detectors, etc.
If the film is still hanging out, carefully handle it by the edges only & gently remove it from the camera. Try not to kink it. You can manually wind it back in the cassette by rotating the post on top.
You can download the owner's manual from Olympus at http://www.olympusamerica.com/files/Sty_Z140.pdf .
Posted on Apr 09, 2009
  • 16 Answers
SOURCE: film streaked images
the shutters are broken or the film loader is schratching the film.
Posted on May 06, 2009
SOURCE: 35mm film developed with streaks
I take it the streak is a hot streak of light. If you're shooting negative, look at the negative and see if it's one long streak. If so the light leak could be anywhere between the film roll and the take up roll. I would open up the back, go into a closet and shine a bright light on the front of the camera and see if you can find the leak and tape it up. Otherwise, 35mm SLR's are very cheap these days. I'd recommend a Canon A-1 for your daughter, but you can't go wrong with any Canon or Nikon.
Posted on Sep 03, 2009
My olympus camera won't charge properly
If the camera battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Apr 02, 2013 | Olympus 228230 Model VG-140 Digital...
Grainy pictures...iso problem for olympus stylus 820
Without ISO you will not be able to take pictures.
ISO is the old ASA which is related to film speed
ISO 50 is very slow film speed and may result in blur and some grainy appearance , same as if you PUSHED ISO up to 800 in low light.
Try setting it to ISO 100 and see if that helps.
You can still select auto, but its related to either shutter or aperture priority in relation to the set film speed ( now ISO 100)
Sep 09, 2009 | Olympus Stylus 820 Digital Camera
What is the button on the bottom of Olympus Stylus zoom 140
No. You just rewound the film. The pictures you took are safe, but you probably 'lost' the rest of the film you did not shoot.
Jun 19, 2009 | Olympus Stylus Zoom 140 35mm Point and...
I look through viewfinder and view is out of focus
Yes, common problem, small plastic tab(s) connecting viewfinder to the zoom are broken.
Apr 17, 2009 | Olympus Stylus Zoom 140 35mm Point and...
Apr 09, 2009 | Olympus Photography
Large, bright orange light streak in pictures
It does sound like a light leak, but hopefully all that has happened is that the foam seals surrounding the film compartment have perished and need replacing. With luck, this is unlikely to be expensive - check with your local camera shop or second hand camera dealer.
May 20, 2017 | Olympus Stylus Zoom 140 35mm Point and...
Zooming with Olympus Stylus 820
Hey missy0528,
There are a few reasons your images might be grainy, one of which is your image quality is set to low. I would always have the camera set to the highest resolution possible, because you can always reduce the size of an image but you can never make it bigger. Another cause of grainy images in digital cameras is the sensitivity of the camera (ISO) is set to high. Since you are only seeing grainy images when you use the zoom the reason for the grainy images is most likely do to using the digital zoom. All a digital zoom does is crop the image much as you can do in some computer applications, and by doing this you greatly reduce your image quality. I would never use a digital zoom. Your camera has a 5x optical zoom and a 5.6x digital zoom. I would only use the optical zoom. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 09, 2008 | Olympus Stylus 820 Digital Camera
Olympus Stylus Zoom 140 All Weather 35 mm
Make sure the flash is coming up all the way. If it gets stuck even slightly down from fully raised, it will do what you describe.
I agree, digital P&S won't work as well as your Olympus. Plus all your shots will have to be stored on a hard drive-
Jan 01, 2008 | Olympus Stylus Zoom 140 35mm Point and...
Date and time change
YOUR SET!
Dec 08, 2007 | Olympus Stylus Zoom 140 Deluxe 35mm Point...
Help!! 10-year old Accura Zoom 80 film camera is taking blurry photos all of a sudden
you should be able to place your hand in front of the auto focus window while looking in front of camera (be careful not to blind yourself with the flash) you should notice the lens moving sightly as if to focus. The best way though is to actually shoot a roll through it. Do not shoot a wedding or anything of real importance...the cost of a roll of film and develop is worth piece of mind.
Jul 04, 2007 | Olympus Accura Zoom 80 35mm Point and...
Cameras Logo
20 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
