Its a Sanyo 42" TV and it the image went black on me and all i can see now is just spots of yellow white blue and green On the top half of my HDTV. I still get sound out of the thing but Image wise Its basically black.
  • Jacobis Soriano Oct 02, 2008
    Well tried that already and the whacking test use to work before but now its just like white spots which appear at the same spots every time i turn my HDTV on its like white and pinkish and yellowish. I figure out that the three parts at the top are sort of messed up i think. It sort off feels warmer than the bottom three slots. and Yeah i opened the HDTV. and a Transformer gets really warm in a small amount of time. Any ideas
    Sergeant:
  • 208 Answers
HI,
It's probably the flyback transformer and associated diodes in the same circuit. It's an easy repair if you know how to solder.
TRY THESE,
ONE: Do the hard reset. Unplug the power cord for 4 hours then power it back up. That will restore all internal soft codes into the set.
TWO: Give it the whacking test. Just bang on it with your fist; strike it at the top, back, sides, etc, to see if you can restore the picture. It is possible that some loose wire, loose connection or cold solder joint has begun to act up and the banging will sometimes get it back in order. Worth at try.
you have to contact the service center if the above steps workout......
Let me know if you need more ideas.
Thanx for using fixya.
Posted on Oct 01, 2008
  • Swaminathan R
    Swaminathan R Oct 02, 2008
    Thanx for your reply,
    And i suggest you to take your TV to the service center to take a look into the transformer.
    It may need some resoldering.....
TV picture goese black and white
Check your cables on the back of the TV and cable box. You either have it connected wrong, or they are loose. If you are using red green and blue, make sure that you are tightly in the red green and blue connectors. If you are using yellow white and red, then make sure you don't have the yellow in the green spot.
Mar 20, 2013 | Dell W3706MC 37 in. LCD HDTV
Dell w4201c no picture just bright colored spots
Was this set moved or transported? Is it possible someone struck the screen even if mildly?
If you can take a few good pictures and post them somewhere on the internet and provide the location--seeing what it looks like might tell what is wrong.
A classic description: set comes on but is a black swirling cloud where images can be dimly seen but are not clear--gets a little better after a few minutes but never gets normal.
Apr 24, 2012 | Dell W4201C 42 in. Plasma HDTV
The DP26649 model TV has three inputs; video one (which is fine and has all color and everything), video 2 (if you plug them in certain ones the best i can get is full sound and all but its black and...
OK, here is the breakdown on whet you are doing wrong.
Video 1 - Composite -
Video - Yellow
White - Audio In - Right
Red - Audio in - Left
Video 2 - Components - HD - RGB = Red, Green, Blue
Video -
Red - Red Colors
Green - Green Colors
Blue - Blue Colors
Your GameCube will only work on Video 1, unless you buy an HD (Component cable). You will need to buy HD cables for your device connected to Video 1 to work on video 2. I will assume it is a DVD player. This is a high definition cable to produce a better picture. Let me know if you do not completely understand
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 06, 2011 | Televison & Video
Hi, im searching for the stereo wiring chart for my mitsubishi lancer 2002 GLXI. i have searched for it but the colours are completely different to what i have. For example the colours i have are - Blue/...
This is all I could find. Hope it helps.
WIRE COLOR POLARITY LOCATION
Battery RED/BLACK (+) RADIO HARNESS
Accesory BLUE (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
Illumination GREEN/WHITE (+) RADIO HARNESS
Power Antenna YELLOW (+) RADIO HARNESS
LF Speaker (+) WHITE/BLUE
LF Speaker (-) BLACK/BLUE
RF Speaker (+) WHITE/RED
RF Speaker (-) BLACK/RED
LR Speaker (+) YELLOW/BLUE
LR Speaker (-) GRAY/BLUE
RR Speaker (+) YELLOW/RED
RR Speaker (-) GRAY/RED
Apr 14, 2011 | 2002 Mitsubishi Lancer
Wii display black/ white only
I had this problem too. It was just because I had the wrong cord that goes from the Wii to the t.v. I had a green, blue, and red for the video. And a red and white for the audio, while my T.V. only took yellow for the video. I just went out and bought the right cord that instead of having green, blue, 2 reds, and a white, just had a yellow, red, and white.
Hope this helps.
Aug 23, 2009 | Nintendo Wii Console
I have a Sanyo HD TV and my Playstation 2 has the red white and yellow jacks but when I plug them in I get no color. If I move them to the bottom red jack and the top green and blue jacks it works but...
the red and the white cables are the left and right sound
the yellow one is the only one sending a picture signal
plug it into the video in...which should be yellow on that tv, the green and blue jacks are for another type of video connection
Jun 28, 2009 | Sony Playstation 3 (PS3) Console
Total black TV
hey hello, you have a bad buffer board. some tvs have them on the sides and another tvs have top and bottom of the screen.it should not cost more than $150.00 for the board. i think that's too much.a tech will determine easy and fast the one that is bad. that is a fast repair good luck
caypianan@yahoo.com
May 10, 2009 | Sanyo DP42746 42 in. Plasma Television
Finding AV channel to connect DVD to TV
first check if you are plugged in the right place,(you're tv as 2 a/v inputs).then you should be able to acces a/v by the menu button on you're remote,or even on the t.v. itself.well good luck then buddy,hope this helps.. btw,are you plugged in a/v (yellow,white,red) style,s-video(1cable)style,componentstyle(green,blue,red).check that out man!
Nov 16, 2008 | Sanyo DP42746 42 in. Plasma Television
Vertical Tilt on Screen & Occational Blue Spot
firstly check the 1000micro farad near the ic vertical,u have to change it.
secondly for the blue green change the positor,if you dont know where it is!!!! it the near the degassing plug
Apr 20, 2008 | Sanyo DS24425 24" TV
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
Electro Med Services...
