Question about Whirlpool ET8GTMXK Top Freezer Refrigerator
Whirlpool model et8chmxk005 serial no. es3019458
Where the control settings are, the control unit runs from the front where you set the fridge and freezer temp.towards the back of the fridge, iam getting water dripping down the back of that unit, i keep the fridge and freezer settings about 4 for each
dididsaythat
  • 291 Answers
SOURCE: freezer too cold, fridge to warm
so what is the problem or question? talk to th company u bought the refrigerator from and deman and refund or replacement
Posted on Sep 08, 2007
docjohn174
  • 943 Answers
SOURCE: Leaking Whirlpool fridge
Thanks for the question When this happens if the evaporator is all frosted up you have a derost problem could be your timer or your defrost thermostat which is located on the coils of the evaporator you can check this with a volt meter these meters are cheap you dont need a very expensive for ahout 20 dollars or the defrost timer one of the two is your problem thanks for the question The appliancedoc
Posted on Sep 11, 2008
huuum
  • 750 Answers
SOURCE: fridge/freezer not cool.
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
I believe your problem is an old thermostat or compressor !
How old is it?
My advice is do not put good money into bad!
A new fridge will pay for itself in a few years by using a lot less electricity!
Here is an interesting report I just read!
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please remember to leave me a rating before you sign off!
Thank You, HUUUM
Posted on Sep 29, 2008
aborcass
  • 2651 Answers
SOURCE: refrigerator whirlpool model wrx38rwh6
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Posted on Oct 26, 2008
  • 7 Answers
SOURCE: water is dripping into refrigerator
If it's the same as our GE fridge, there's a tube in the back of the fridge on the outside with an S shaped curve in it that may be plugged up with dust and/or dirt. Clean it out to let the water get through.
Hope this helps.
Johnnyczar
Posted on Mar 20, 2009
Hi i have a wirlpool fridge the freezer and fridge works fine but it seems the motor keep on running and dont switch off or is it the fan that is running please help
Hello Sandra;
My name is Peter. I am a retired field service refrigeration technician.
You just have a simple operational and maintenance issue.
Neither your compressor or fans should run continuously.
First, you need to clean your condensing coil. You did not provide a model number so you either have a flat cooling coil in the front bottom, or a canister type in the back right hand side. This coil dissipates the heat. If it is plugged up your compressor and fans will run trying to keep up with the unit temperature settings. This can make a difference as much as 40 degrees. The toe plate, bottom front is either held in place with a screw on each end. If no screws, there is a clip on each end. Just pull and it will pop out.
Second, You only have only one cooling source and that is your freezer. The freezer will try to satisfy itself first before the fresh food section. If you set the temperature controls beyond the unit design settings your compressor and fans will keep running. Set your freezer to -2 or +2 Deg. F., and set your fresh food section to 35-40 Deg. F.
Third, Check your door gaskets. make sure there are no gaps.
Dec 21, 2014 | Whirlpool Replacement Refrigerator...
Where can i find a wiring diagram for whirlpool control board w10135090?
Normally unit technical sheet is hidden for technician reference inside the front bottom kick plate or just under it. Please put it back after using it to the right place. Next guy working on your fridge need to refer that.
Sep 03, 2014 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
The Whirlpool fridge part of the fridge /freezer is freezing up it should be an auto defrost and the only solution at moment is to switch it on and off.please help Allan
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Hoping that this will help to solve the problem of the refrigerator...
Aug 08, 2011 | Whirlpool Refrigerators
I have a two year old whirlpool side by side refrig and it is freezing things in the refer side no matter what setting it is on. Can you tell me where to start to troubleshooting?
Good luck in solving the problem......
May 12, 2011 | Whirlpool Refrigerators
Whirlpool refrigerator was accidentally turned off last night and today morning when we turned it back on, it seems as if the fridge is not working while freezer seems to be working. What could possibly be...
I would wait 24 hrs from when you turned it back on , to tell if there is a problem . Also , set both controls mid-range , and feel at the back vent on the left side , to see if you feel and air blowing to the refrig section . May be slight air flow . Leave the settings there ( gets cold no quicker if turned up completely ) , and at the mid setting , you are not obstructing any air flow .
Aug 15, 2010 | Whirlpool Refrigerators
Fridgerator is freezing everything even at lowest setting it is an whirlpool energy star side by side
Check the plastic air deflector at the top rear of the frig had been knocked off. I replaced it and all is OK. I thought you might add this to your suggestion list. As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control, which is now functioning properly.
Hope this helpout in solving your problem
Aug 01, 2010 | Whirlpool Refrigerators
Freezer works - refrigerator does not
evap fan between the two units is more than likely out. What this fan does is use the cooling from the freezer to cool the fridge. This fan is located in the space between the freezer and fridge and has vent slots in front of it for the transfer of the coolong from the freezer. This fan is more than likely on the same channel as the temp control setting for the fridge. To remove the fan motor you will need to remove that moulded channel and as soon as the channel is off presto there is the fan. Take model # and serial # to an appliance parts store for replacement. Good Luck hope this helped you
Dave
Jan 07, 2010 | Refrigerators
Unit ED2FTGXKQ04, side-by-side fridge not cooling
hello my is leroy, have u check the freon levels for the unit.
Mar 08, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool ET8GTMXK Top Freezer Refrigerator Logo
418 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
