Question about HP Computers & Internet
Will not start up
I just put a am37 motherboard in my tower and hooked everything up to spec and when I turn it on it comes up and says set up f1 or system recovery f10. I push f1 and it comes up in bios and that is it when I exit out of it it does the same thing. I have the hd that came with the board hooked to it so it would boot.What could the problem be. Thank you for your help
    Guru:
  • 859 Answers
Did you assemble everything at once? Normally we only install the display adapter and the network card.
If everything is the same, Windows does realize you have a new board, with new chip sets among the many. Since your machine won't boot, I'll bet your primary HD partition needs to be set as active for the System Bios to load the Boot Strap phase properly. You can do this more easily by using the Windows CD to boot from. Choose Repair when prompted early on. You get a Dos Emulation screen. Type HELP and press enter. You see a list of commands you can use. Choose FixMBR, and then FixBoot. Now reboot and don't press any keys while the Windows CD is still in your drive bay.
Should that fail, boot from your Windows CD b y pressing a key when prompted, and let it proceed to install, on the second stop screen Windows tells you a version of Windows is already installed. At this point you can choose the alternate Repair option. This installs Windows, but by repairing the OS that's there now. This works pretty good, you have to type in the Product key at the end and you will have to activate windows again. Don't try to do that on Weekends, the activation server is usually in use and your place in line numbers in the thousands.
Regards,
Worldvet
You will need your special drivers on a floppy or CD if you have two CD drives, a memory card may work too. In the bios setup pages you may find an option to choose Save Configuration. This allows the bios, which has no clue it was just installed, to realize the old drive has an OS, you want to set the bios up to read the primary hard drive and set the boot configuration to the proper hard drive as well.
Then, if you get the F10 for System Recovery you give that a try, but I would tap F8 until you get the boot menu and then choose safe mode. While in Safe Mode you can install the board drivers for your new system board.
Sorry for rambling around. Its late and I'll be going to bed shortly.
Regards,
Worldvet
Posted on Oct 01, 2008
Start button would not respond plug disconected unsure were it goes e machine c 1940
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
You want a Front Panel header pinout.
(See? Know you can go around, and brag to your friends!
"So,......mrcat_grave,.........do you know what a Front panel header is? What about a Front Panel header pinout? How about you Sally?"
Lol! )
Hmmm, I do not find an eMachines C1940 desktop computer.
Could this be an eMachines C1904, or S1940 desktop computer?
If so they both use an FIC AM37 motherboard,
(First International Computer, { Inc } AM37 is the model number of the motherboard)
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=bph07941&lc=en
(Scroll down for Motherboard Layout illustration, and Motherboard Photo )
Provided I am on the right track;
Motherboard installed in computer case:
Processor to the Top, Ram Memory slots to the Right, white long PCI slots to the Bottom;
The Front Panel header is at the Bottom/Right corner.
It is rectangular in shape, and situated Vertically.
Two columns of contact pins.
There are 4 pins on the Left side, 5 pins on the Right side.
(Do NOT get it mixed up with the IR header above it. 6 pins)
The pins are numbered EVEN on the Left side.
The pins are numbered ODD on the Right side.
Starting on the BOTTOM of the Left side, going towards the Top;
Pins 2, 4, 6, and 8. There is NO pin 10.
Starting on the Bottom of the Right side, going towards the Top;
Pins 1, 3, 5, 7, and 9.
A) Pins 1 and 3 are for the HarDDrive activity LED. (Light)
[LED = Light Emitting Diode ]
Pin 1 is for the Positive ( + ) wire.
If the HDD LED is dim when the harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C.
Not Connected. Probably a 5 Volt power source, used by the factory to test with.
D) Pins 2 and 4 are for the Power On LED. (Light)
Pin 2 is for the Positive ( + ) wire.
If the PWR LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
Zip file PDF motherboard manual, for the FIC AM37 motherboard.
There is a version 1, and a version 2.
FIC AM37 v1, and FIC AM37 v2.
Doesn't matter which one you choose, as far as the Front Panel header pinout info is concerned.
You may however need info that is in the version 1, or is in the version 2.
You can download both.
Zip file. A compressed file used to send large amounts of information, more easily.
It needs to be decompressed, or 'unzipped'.
You have Winzip on your computer. It is an 'unzip' program.
If it is out of trial time, or not usable, suggest you download, and install the free 7-Zip.
Let's use the AM37 v1 manual as an example;
After you click on AM37 v1, a small window will come up on the right-
Opening am37_v1_manual.zip
Make SURE there is a Green dot, in the small circle to the left of Save File.
If not; click in the empty circle to the left of Save File.
Now go below in the small window, and click on OK.
A small window will come up on the left.
Allow the file to fully download in this small Download Window.
Then DOUBLE-click right on the file name.
In the next window go to the far left, and click on - Extract all files
At the bottom of the next 3 small windows, click on -
Next, Next, and Finish.
In the last window DOUBLE-click right on the file name.
(It is next to the red Adobe PDF icon)
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 17, 2012 | E-Machines Computers & Internet
MY DESK TOP TOWER RED LIGHT IS ALWAYS ON THESE DAYS. ALSO I NOTICE AFTER I START MY PC AFTER A FEW SECONDS ,THE SCREEN SHOWS STUFF WHICH INCLUDES PRESS F1 TO CONTINUE THEN AND ONLY THEN THE COMPUTER...
It seems a bad CMOS BIOS battery, normally this is a "coin" type alkaline battery located inside CPU, to replace it, you must have access to the motherboard.
Feb 15, 2011 | Computers & Internet
Where can i get a hook up spec on a am37 motherboard .
Do you mean as specific as specifications can get? If so, I was able to retrieve a pdf technical doc for am37. reply to this post to confirm.
Sep 18, 2010 | FIC AM 37 Motherboard
Jumper settings
Thanks for the link you posted, helped me a lot. I had to exclude am37_a0_eng.zip from the link to make it work.ftp://ftp.fic.com.tw/motherboard/manual/socketa/am37
Mar 07, 2010 | Cornerstone FIC AM37-L Socket A XP...
Am37 motherboard
What the name of your tower
Aug 28, 2008 | FIC AM 37 Motherboard
Power button wiring
A quick google determined your emachines model w2040 is equipped with FIC motherboard AM37. Download the manual from
http://www.fic.com.tw/support/motherboard/motherboard.aspx?model_id=107
You'll find the pinout info for your wiring on page 13.
Most motherboards also have the pinouts silkscreened onto the board itself.
May 10, 2008 | E-Machines eMachines Desktop PC
Fic am37 manual
I found exactly what I was looking for at this link, ftp://ftp.fic.com.tw/motherboard/manual/socketa/am37
Sep 03, 2007 | FIC AM 37 Motherboard
Not powering up
Did the CPU and cooling fan come pre-installed or did you have to install it? Did you forget the separate 4 pin power connector from the power supply to the motherboard? Is the speaker hooked up and are there any beeps? Do all the fans spin up? Do you have a video card that requires additional power connection and forgot to connect it?
Jul 08, 2007 | Foxconn 661FX7MI-RS (661FX7MIS)...
Computers & Internet Logo
91 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
