Question about HP Photosmart 2575 All-In-One Printer, Scanner, Copier
Cannot get the scanner to work. can't access scan menu to scan directly to computer
I have a hp photosmart 2570 all in one series printer it did not have the windows cd with it how can i get the printer to download or can i get the cd to down load
Posted on Oct 01, 2008
My PIXMA2520 only prints document when scanned,and is not able to scan TO my computer Need to scan and have it appear on my computer.How can I do this?or is this printer-scanner not able to Than you
Scanning to the computer is done through the printer menu of the software you loaded to the computer when you installed the printer in the computer. The menu item you want is called "MP Navigator" and it is in printer "Canon Utilities" menu
Feb 24, 2017 | Canon PIXMA Office Equipment & Supplies
UNABLE TO CONNECT TO MY PC
I am not sure this machine has an automatic Scan to PC option. Brother seems to like to avoid this part of most machines. Depending on your Operation System you will still be able to access the scanning system. The operation system would define which method it uses. Win XP you can access the scanner through the Printers and Faxes option on the start menu. Go to printers and faxes and then from there access scanners on the sidebar. Find your machine and open the inbuilt scanner software to scan your photos and save them to your computer. Then e-mail the saved files.
Aug 13, 2014 | Brother MFC 240C All-In-One InkJet Printer
How do i change scanner settings
left click start menu left bottom corner of desktop
find all programs listing
Look for a program called hpscan
https://h30434.www3.hp.com/t5/Scanning-Faxing-and-Copying/HP-Officejet-8600-Pro-how-to-change-scan-resolution-presets/td-p/2721003
Jun 26, 2017 | HP Officejet Pro 8600
I have a C7250 all in one. I am trying to scan pictures to my computer and the instruction manual says to press the scan menu and then scroll down to scan to comuter. The scan to computer is not an...
You have to download and install the full feature package
for your windows system to make the scanner work on your pc.
When you have downloaded and installed the software
click on Hp solution center and select scanner options.
Down load it here:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=3382185&
Remember to select the system you are running 32 or 64 bit.
Hope this was helpfull.
Mar 14, 2011 | HP Photosmart C7250 All-In-One Thermal...
I have a Kyocera KM-2560 printer/scanner/copier that is accessible via LAN for a number of computers. When the vendor intially installed the system he assigned "scanning" to only one computer...
It sounds like the vendor set up only one scan destination. That destination is accessed by other computers on the network. You would have to have to create a different scan destination for each computer if you want to be able to scan documents while that computer is off. This is a link to instructions for doing that.
http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?pid=18154&rid=19484
Feb 28, 2011 | Office Equipment & Supplies
Can't get the scanner to scan
HP units typically scan BEST when operated through the computer, rather than the unit itself. You MUST have the software installed on the machine, and not use plug and play, as that only gets "some stuff" going, specifically NOT scanning, I have found.
Go to HP.com and download the latest install directions, for your printer and OS. You may have to delete the old printer on your system, but, follow the directions exactly, from HP and plug the machine into your computer when directed to do so.
THEN run the scanner from the software installed on the computer, tons easier....
As a side note, next printer (all in one) should be a network printer, works TONS easier, with each computer allowed to scan, etc., like they hosted the unit. Can also be accessed wirelessly, all for the same money..... Cool.!
Feb 13, 2011 | HP OfficeJet k60 All-In-One InkJet Printer
I have a cannon printer that I always could scan with my old computer. I have a new laptop and I don't know how to make it scan now.
Yeah, something changed and some older scanners do not work with new OS and hardware. Fortunately new printer/scanners are not very expensive. I think the programming standards changed in terms of scanners. One cool option of new stuff is wireless printing and scanning, so this means that you no longer have to go to the host (sharing ) system to scan, but you can scan and control from the laptop. I prefer HP. Set up works fairly easily, but you do need to have access codes for your router. FOLLOW install directions EXACTLY, and specifically NOT plug an play.
Oct 03, 2010 | Office Equipment & Supplies
I am trying to figure out how to use my Brother MFC-8440 scanner. I would like to use it to scan documents to email out. When I go to Brother.com and look at the direction book, it doesn't have directions...
It is part of the Network User's Guide (section 10) and the Software User's Guide (section 3 for a PC using Windows, Section 8 for network scanning), not the User's Guide. The directions below are for XP and Win2K primarily. Slight changes may exist with other OS versions. (Full software is not available for Win7 so the buttons on the unit will not work. You will need to launch scans from the computer only. You can use Windows Paint or Fax and Scan without needing third party software. Then attach the file to an email either in the email software or by right clicking on the file and choosing Send to Mail Recipient.)
For either use, put the document face down on the glass or face up in the ADF.
If you use a directly connected computer, you need to set the destination for the Scan to E-mail in the Control Center (section 4-4 in the Software User's Guide). Open this program and make sure the correct machine is in the drop-down menu. This program needs to be running to hear the buttons being pressed. Click on E-mail to set which program will get the scanned document as an attachment for your e-mail. You can also set the resolution and type of attachment. If you do not want to use available file formats, you will need to scan in PaperPort (or other software) and then use that to attach the file to the e-mail. Then click Scan to launch the scan from the unit. Hit Set when ready to send.
If you have the unit set up on the network, then you can enter the LAN setup in the Front Panel (or a browser). Hit Menu 6 (and then the appropriate number for the next feature), such as TCP/IP, DHCP or Static IP (these are under 1), SMTP, POP3, Mail Address (Menu 6 2). Setup the Scan to email with Menu 6 7 1 for color and Menu 6 7 2 for black and white.
This automatically sends the item to the email server or PDF as either a PDF or JPEG. Then you need register the PC that will get the file to the unit, if you use scan to email (PC). (Your version of Windows will matter for exactly where the information is: Control Panel > Scanners and Cameras or Control Panel > Printers and Other Hardware > Scanners and Cameras.) Right click on the icon for the unit and select Properties to see the Network Properties box. Go through all of this set up including the Scan To Button. Then the Control Center will launch the e-mail program when it "hears" you press Scan, select Scan to Email, press Set, then choose PC and press Set again. (or select the destination PC which has e-mail access and press Set again). Scanning will start.
If you have set the POP3 and SMTP servers and the unit can directly access them, then you can scan to e-mail and enter the recipient address. Press Scan, select Scan to Email, press Set, choose Email Server and Press Set again. Adjust the scan quality as desired pressing Set at each step. Once you go through all of the layers, the LCD screen will prompt you for the recipient's email address. Then press Start.
I hope this helps.
Jul 20, 2010 | Brother MFC-8440 All-In-One Laser Printer
Cannon capture perfect 3.0
Check the location where you are directing the scanner/computer to store the scanned image. If it is full, obviously it cant store. Change the location where there is space.
S. Mohan
Oct 14, 2008 | Canon DR-9080C Path-Through Scanner
HP Photosmart 2575 All-In-One Printer, Scanner, Copier Logo
186 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
