Question about Sharp XR-10X Multimedia Projector
Sharp XR 10X lamp replacement issues
I replaced the lamp in my XR-10x due to age. A while back the projector refuesed to come on, and the lamp light flashed (Don't know the color, I am colorblind) I assumed the bulb had given up the ghost, as it was nearing the end of the 3000 hour cycle.
I finally replaced the bulb this evening, after putting the new one in VERY carefully following what little instructions that I have, I powered the unit back up, the power light comes on, the lamp light flashes 14 times, takes a 7 second break, and does it again. This cycle repeats for approx 8 cycles, then the power and lamp lights flash wig wag style for a short while.
I am unable to get the projector to power back on and light the bulb.
Not sure if I have a bad bulb, or if the projector has failed out on me. I am in dire need of this for a presentation this coming Sunday. any help would be appreciated.
  • 3 more comments
  • Bartholomew9 Dec 05, 2008
    I have the same problem, except we've never replaced the lamp.
    The flashing light scheme as described is accurate - the colors are green at first, through the 14 flashes. Then the middle LED turns red, and the wig-wam flashing is green for the power LED, red for the middle LED. Once the lights burn steady, they are both red.
    During the 14 flash sequence, I can hear the lamp module trying to power on, but unsuccessfully (a momentary whir, which repeats at intervals).
    Hate to buy a new bulb if it is the ballast or some such...
  • zak6912 Dec 19, 2008
    I have the exact same problem with a new bulb that I bought. The new bulb worked for about 4 hours and then when I went to turn it on again I got the same exact problem. I would love to know how to fix this. I dpn't really want to buy another bulb to find out it was something else.
  • Kid Capri Dec 28, 2008
    I have the EXACT same problem as the original poster... I'm stuck... just forked out $300 on new OEM bulb, carefully handled the bulb installation like a surgeon and still got nothing!!!! The lights just flash every 7 seconds or so then after about 5 minutes or so of alternating between green solid and flashing states, the power and lamp leds both turn solid red forever until i unplug. Putting the plug back in restarts the fiasco
  • Yedifix Jan 06, 2009
    Same problem here. Have emailed Sharp support for an answer. They want to charge huge prices if you send the projector in. Mine is out of warranty. If I understood or recall correctly, I pay shipping, $50 diagnosis, $300 lamp, and $125 to install the lamp.
    Now if my bulb is bad, just tell me. I assume this projector just doesn't randomly put out this code of flashing lights for nothing. Yes 14 green lamp, yes attempts to start, yes ends in double red lamps. I just want someone to tell me what all this means in a nutshell, or explains why it doesn't mean something.
    Still searching for a solution. Sharp XR-10X projector.
    PS: Mine did start in a shade of blue and held for about 10 minutes. When I went to the menu to hit reset, the projector went dark. Fan cooled as usual. I'll let you know what they say. Sending it in seems way to expensive. Trying to learn my options to make a reasonable choice here. What fun.
  • usafcountryb Jan 12, 2009
    I have the same problem as well. Been doing some research on this, and I'm assuming it is the ballast. Not sure how to fix it, or how much a new one costs.
    Problem Solver:
  • 9 Answers
I sent mine in. They changed the bulb and cleaned the unit. The one thing they did suggest that seemed helpful was to upgrade the firmware. They did this as part of the service. That may be your problem, but I don't know that the firmware is upgradable. Yes indeed, they do charge an outrageous price!! I went through Sharp because they would guarantee the work, and I didn't want to buy two bulbs.
Posted on Jun 07, 2009
Problem with Sharp XR-10X The power light blinks red
According to the manual, a red blinking light indicates that the lamp cover is open. Try reseating the lamp and making sure everything closes up right. If the light is still blinking, it is most likely a problem with the projector itself and you may need to find out about getting it serviced.
Jun 27, 2011 | Sharp XR-10X Multimedia Projector
XR-10X/XR-10S - Can't find a way to open up the lid!
maybe your Sharp XR-10X are damage so you want to know what will you do??
Sep 17, 2009 | Sharp XR-10X Multimedia Projector
New bulb in now wont work - no power - wont turn on to reset lamp
first, make sure you have the correct lamp. the lamp for the xr-10x-l looks like the xr-10x, but the plugs are different (common mistake). make sure you have the AN-XR10L2/1, not the AN-XR10LP/1. to reset the lamp timer (with the projector plugged in but off), hold down the enter, down arrow, and menu buttons and press the power.
May 30, 2009 | Sharp XR-10X Multimedia Projector
XR-10x bulb timer has timed out. How do I reset the projector?
you need to reset the lamp timer see http://www.ercservice.com/PDF/Lamp-Sharp-XR10-XR20.pdf
Apr 07, 2009 | Sharp XR-10X Multimedia Projector
Projector shuts off sporadically
1. Pls check the airflow of the cooling of the projector, or just service the all unit.
2. As you told that the lamp life is 76%, Check the inner
reflector have shiny surface of dimmy, If not shiny, then replace
the lamp unit.
Enjoy
Viren
Jul 20, 2008 | Sharp XR-10X Multimedia Projector
need to replace the lamp. i could have diminished not as much to frequent on and offs, but excessive dust. it's heating up too much and shutting down.
May 31, 2008 | Sharp XR-10X Multimedia Projector
Xr-10x
Hold "Down Arrow"+ENTER+MENU/HELP, then press STANDBY/ON. That will reset the counter if done correctly.
Nov 22, 2007 | Sharp XR-10X Multimedia Projector
Sharp XR-10X Multimedia Projector Logo
960 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
