Question about Motorola Mobility Slider Bluetooth Headset Black Wireless Headset
Hiptop Slide I just purchased a new Hiptop Slide (the red and black one) and i cant for the life of me figure out how to change the general ringtone for incoming calls... in the manual it says to go to the phone, select settings and then general and its in there that you can change the settings.. but my phone doesnt give this option.. is there something wrong with my phone, or is there just something wrong with me? Thank you
  • dcl87210 Jan 24, 2009
    I have the same problem...I aquired the phone as my teenage son couldn't manage the bill...and I can't figure anything out...the settings for all on this phone is complicated!
  • emmacase2568 Apr 16, 2009
    i have just purcashed a hiptop slide phone and imtry to change the rigtones. i would like to use my own music that i have install onto my hiptop but do not know how to and in solution 1 it says to go into the icon above phone messaging click on the far left button then settings and there is a music symbol there and there is not. how do i do this?
i got a red hiptop slide and have some problems.
when i connect the cable to the computer, it shows up with removable disk and everything that its supposed to, but when i click on it it says to insert a CD into the Edrive.
i dont no why it does this and all the instructions dont mention inserting a CD into any drive. am i supposed to buy an installation CD or is there another way to access the information without a CD? please help!!
Posted on Jun 28, 2009
Great..thankyou for your solution...I spent 2 hrs..and in 2 mins after reading your solution I found all the settings...
Posted on Jan 24, 2009
Yep i know how.. go to the phone icon Above SMS Click on that tab then press the options button (far left button) then select Settings with a little music note and wallah!
Posted on Oct 06, 2008
How do I access ringtones on alcatel one touch 2001x
To change the ringtone, follow these steps:
Ringtone for all calls
  1. From any Home screen, tap the All apps icon.
  2. Tap Settings.
  3. Scroll to 'DEVICE,' then tap Audio profiles.
  4. Under 'PREDEFINED PROFILES,' tap General.
  5. Tap the General Settings icon.
  6. Scroll to '[INCOMING CALLS],' then tap Phone ringtone.
  7. Tap the desired ringtone from the scrolling list.
  8. Tap OK to confirm.
Ringtone for calls from one contact
Note: You cannot assign a ringtone to contacts stored on the SIM card or Phone (device memory).
  1. From the home screen tap all apps.
  2. Tap People.
  3. Tap on the specific contact.
  4. Tap Menu.
  5. Tap Set Ringtone.
  6. Tap on the ringtone, then tap OK.
Mar 27, 2016 | Alcatel Cell Phones
How do I connect a ge rocker on/off with slide dimmer switch? It has two red wires , one green and one black wire. Never seen this before. I want to install it in my dinning room. I have in my old wall...
You bought a three-way switch, but that's OK you can use it. Connect green to green (that's the ground). Connect black to black (that's either your incoming or outgoing hot wire). Connect white to one of the reds (that's either your incoming or outgoing hot wire.) The other red wire will not be used BUT you must put a wire nut (and/or tape) on it to insulate the bare end, because if the black wire in the box is your incoming hot wire, then this extra wire on the switch will be hot when the switch is OFF.
Jun 23, 2010 | General Electric Ge Deluxe Lighted Slide...
Describe your how do I change the ringtone on samsung ultra touch
To change the ringtone, go to settings -> Phone profiles and click on the double arrow button. Here you can change the ringtone. You can also change the incoming message tone. to do that, you can select "new messages" in the upper right corner.
May 04, 2010 | Samsung S8300 Ultra Touch platinium-red...
Hiptop slide dropped in water, Need some software :]
Do you remember getting a hiptop account when you first got your phone? If so , sign onto 'www.hiptop.com.au' and sign in with it. I hope you know your account details. Your username should be what your hiptop email address was. Once you're signed in you should find all of your contacts ,etc on that site.
Sep 23, 2009 | T-Mobile Sidekick® 3 Cellular Phone
I cant change the volume or set ringtones
Go to settings, user profiles, select a profile (general) and then click on customize. There it will let you change the volume and/or ringtones.
May 19, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
HipTop Slide music
you guys r silly go to computer, then you will c removable disc j im pretty sure thats it or if using a memory card removal disc h then transfer it p.s any1 know how to send stuff from bluetooth on it?
Oct 03, 2008 | Motorola Mobility Slider Bluetooth Headset...
Sidekick slide
You have to download them from the download catalog. Once you do that, then you just click on the phone icon, open up the settings and click on general and go down until you see the incoming call ringtone, click it and scroll down the import, and select the song you want.
If you are wondering if there is a way to add in your own custom made ringtone to use, then as of now there isn't.
Mar 21, 2008 | T-Mobile Sidekick II
LG TU55O vIDEO TELEPHONY
there are some settings in your handset
-menu-profiles-select the current profile-than personalise-than click on tune set up, than u can select your mp3, you can select your tune mode/volume
Oct 13, 2007 | LG CU500 Cellular Phone
Motorola Mobility Slider Bluetooth Headset Black Wireless Headset Logo
368 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
