Question about Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Polaroid tv dvd combo
I have a polaroid tda 03211c tv dvd combo and when i put the disc in it displays (loading)and nothing happens but a clicking niose. after about 2 or 3 mins it displays no disc . any ideas? This thing is less than a year old
  • clarkk15 Nov 16, 2008
    yes i have same problem put in disc says loading then says no disc
    do you have a solution
There is a belt cable that leads from the DVD pc board to the laser module. This cable can buckle and get in the way of the moving laser as the laser attempts to scan the disc. the clicking sound is the gears turning, but the laser module is jammed. by placing a small adhesive to hold the cable to the DVD housing will fix this problem.
Posted on Feb 17, 2009
On the bottom of my lcd tv there is a red light tht stays on, i know it means that it is working, however the red light is no longer on what could be wrong. this is basicly the power button, can it be fixed
Posted on Feb 13, 2009
I had this but i had the extended warranty they put in a new optical sensor(laser. ) But they also scratched and dented my tv like garbage when they fixed it. I am getting a lawyer
Posted on Jan 07, 2009
Dvd polaroid tv/dvd combo tda-o3211c dvd stop
Not worth repairing,just get a seperate DVD player hook to the tv.It very cheap these day.
Dec 05, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
When I put a DVD in, it stays on loading for a few minutes and then it says -no disc. I can not use the DVD player. It is a 32" HD Widescreen LCD TV/DVD Combo...TDA-03211C. Thanks.
With the dvd loaders in these particular units the laser tends to fault in them relatively fast. Replace the laser loader assembly, which is the entire assembly containing the laser, the mechanism where the disc slides in and out as well as the small motor that spins the disc. Good Luck.
Nov 26, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
I''ts the same problem dvd says no disk
I have a working DVD unit from my 03211c and I part with it for $30.00 you pay the postage. This DVD 3003391292478080_1.jpg Polaroid TDA-03211C DVD MECH 926-V00-DSL900Dhas no markings but was built into my 03211c in June of 07.
cell: 1-717-781-7907
I also have anything else you you need for his TV. I'm parting it out because the LCD screen is cracked.
Jun 20, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Screen black. polaroid tv 32". have sound TV/DVD Combo TDA-03211C
sounds like inverter board. What it sounds like is happing is your LCD is working ut the backligkt board that allows you to see is kicking off. (as you still have sound) Which could be the (most likely) inverter board, or the power supply board. You can take apart and check for voltage at your power supply. The power supply has a pigtail with large white wires and a connector. Power up with the center back cover off and check your voltage at the white connector on the power supply before and after the screen gos out. If there is no large voltage loss it is your inverter board.
You can used boards on e-bay or
www.rns-systems.com
Can't get universal remote to work for polaroid tv/dvd combo
read here
http://www.fixya.com/support/t225581-code_polaroid_tv
May 19, 2017 | Polaroid TDA-03211C 32 in. LCD HDTV
Have a Polaroid TDA-03211C tv with dvd player. Won't play DVDs
As long as you know a disc is not stuck inside I recommend taking it to your local svc center to be looked at.
Feb 28, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Tv doesnot power on
two options _bad backlight inverter or the main board ;eed to be change.
Oct 23, 2008 | Polaroid TDA-03211C 32 in. LCD HDTV
Sharp Aquos LC-37GD6U 37 in. LCD HDTV Logo
127 people viewed this question
Top Sharp Televison & Video Experts
Dave Naylor
Dave Naylor
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
