SOURCE: Error Message E91:01
Press Menu button
togle across from REC Mode to setup
togle down thrice from camera to setup 1
togle across into sub menu
togle down from four times to Initialize
togle across again to the sub-menu
togle up from cancel to OK
press center button to accept the OK choice
Screen changes and so press okay again
It should restart the camera
Opening on the 'Clock Set' screen
togle down to cancel and use the camera and make sure that you have the camera to flash, if it works try again in the Auto function.
If it is still not working do not worry follow the steps again two or three more times, As this is generally a software error message and not a hardware malfunction.
If it is working then don't forget to set your Clock.
SOURCE: Sony T5 is flashing Error E91:01 and the pictures are blurry
My Sony cam was woring fine but suddenly it started giving an error E91:01 which is continuously flashing
SOURCE: E91:01 Constant flash sign on Cybershot DSC-W80
Press Menu button
SOURCE: E91:01 error code W80
I will forward a link to a page where you can get the information regarding this error message.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C1002686
SOURCE: flashing E91:01 on screen
Hi!
Try initializing the camera. Error 91 is a flash error in Sony cameras. It is probably a dead flash fuse on the motherboard (most common problem) or a faulty flash board. If you have a multimeter, I can help you locate and test the fuse and if you have a soldering iron - even fix it. My e-mail is [email protected]. Otherwise, you should contact your local Sony service center or other local camera service center.
Hope this helps!
Tom
