Westinghouse LVM-37W3SE PC Monitor
PC resolution is perfect at 1920x1080 which is the native resolution of the new 37" monitor. Problem: everytime I turn the PC again the fonts and images are a little bit blurry. I can only solve it by resetting the resolution to another seting then go back immediately to1920x1080. If I shut off the PC then later turn it on, the blurry image appears again and I have to reset the resolution again. Help!
  • 65 Answers
1. Genaraly 14" and 15" Monitors supported Up to 800by600 some monitors 1024by768pixels 17"monitors supports 1024by 768 to 1280by960 pixels and Other 19",21" are supported 1280by1024 pixels at the same time change the screen Refreshrate at display properties.
Posted on Oct 06, 2008
Dotted lines across the top of the screen and flicker in other video ports.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Mar 05, 2017 | Westinghouse LVM-42w2 Television
Monitor has stretched images. I use CAD programs that require equal vertical & horizontal. I am using only a VGA cable plugged into my HP Pavilion. AOC suggests DVI cable, but did not include one...
You should set your PC video resolution to the native resolution of this monitor: 1920x1080 at 60Hz . Right now you do not have it set to the correct aspect ratio for this wide sceen monitor.
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Oct 28, 2010 | AOC F22 Monitor
Can I restore native resolution on my Compaq without a manual?
HA! ya'll should check this out!...
1. First, ignore any advice that you should disable any monitor driver that was supporting a second monitor. Keep your monitor driver(s) enabled, even though it means multiple monitor mode remains "on".
2. As long as multiple monitors is "on", your advanced settings dialog will have more available settings than otherwise (through Properties>Display>Settings tab> Advanced button). So instead of 4 tabs (in one row), you should see 12 tabs in two rows!!
3. Select the Displays tab and click on Panel. Un-check (a blue radio button) "Scale image to panel size".
4. Then select the Adapter tab. Click the button "List All Modes". The list will now include ratios: 640x480, 600x800, 1024x768, 1152x864, 1280x768, 1280x1024, 1600x1200, 1680x1050, 1920x1080, 1920x1200, 1920x1440, and 2048x1536.
Ta DA!!
Jul 21, 2010 | HP Compaq nc8230 Notebook
Westinghouse keeps shutting off randomly
Power supply board finally dies.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply for the replacement.
Apr 17, 2010 | Westinghouse LVM-37w1 37 in. HD-Ready LCD...
I have the westinghouse monitor ( modeL # lvm-37w1) nad the picture keeps going nuts on the left side of the monitor only. anyone know what could be wrong?
Hello, this model has two ribon cables that run from the t_con board to the panel, it sounds like you might have to replace one of them if not the whole t_con board. You can find parts for this at www.shopjimmy.com, I would recommend you taking this unit to a certified repair center if you are not atleast a bit technical because you have to did a bit deep in to the set for this one.
Nov 21, 2009 | Westinghouse LVM-37w1 37 in. HD-Ready LCD...
Screen resolution on powerpoint cannot be locked at high res. Changes when connected to my projector. Monitor screen res. also changes everytime the projector is plugged in, In power point display (2nd...
I just checked the specs on your Benq PB 6110, which has a native resolution of 800X600 and will simulate 1280X1024. When you connect it to your computer, the computer goes to 800X600, right? That is the resolution of the BenQ. How high a resolution do you want? THe highest I have seen in projectors is 1024X760, which is not that much higher. Projectors seem to lag behind monitors and Plasma/LCD/LED TVs for resolution. They must have a very small market share therefore low developement.
May 07, 2009 | Microsoft Office PowerPoint Home and...
Computers & Internet Logo
560 people viewed this question
David Payne
David Payne
