Hp Pavilion XT963 four beep startup and nothing
I changed my power supply and turned on the cpu. I get four beeps then the montoir goes black.
    Problem Solver:
  • 5 Answers
Since iam not sure about the beep noise that u get....becos there are different pattern for it.
so iam pasting this link and let me knw the pattern plz..
http://www.computerhope.com/beep.htm
or else it could be the power supply which is not placed in properly try unplug and placing it back again.
or let me knw the exact noise that u get is it a beep noise or clunking sound or very, quiet jet taking or Noisy fans.
Thank you.
Posted on Oct 01, 2008
When powered on unit only beeps. continuous beeping- approx 1 every two seconds. nothing boots up at all, only beeps! Tried removing memory thinking it may be a memory issue but that was not the issue!...
Hi
If you have a Gigabyte MoBo then the CPU fan has stopped running.
Open the casing side cover and see if the CPU cooling fan is running or not.
If it does not run, the go into BIOS and disable "HDD S.M.A.R.T. Capability" in Advanced Bios Features
also set "CPU smart fan control" to disable in PC Health Status
OR
This may be a power supply problem.
The voltages of the power supply are going out of limits.
change the power supply and see.
May 20, 2011 | HP Pavilion Media Center a1510n PC...
Old Hp Pavilion 763n PC, cleaned it out thoroughly, replaced power supply, redid heat sink with silver paste, and added RAM. It worked fine, little slow, but working for about three days and now nothing....
Here is a listing. From what I read, it seems to me the problem is in the CPU and that it is overheating. This can be caused by a multitude of issues but first ensure the CPU fan is running. Second, if you applied too much siver heat sink, this can cause overheating as well. Make sure you only have a thin layer between the CPU and the heatsink. Hope this helps.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07107&cc=us&lc=en&dlc=en&product=90823#N3704
Jul 17, 2010 | HP Pavilion 763n PC Desktop
My PC is making a beep sound and nothing is showing on the monitor. it is an hp tower desk top
Whenever you hear a system beep it means the system is hung due to a hardware error. How many beeps does it make? The number off beeps can help you dtermine what the issue may be. It could be a video card failure, cpu failure, ram failure, or even a power supply issue. The beeps aren't very specific but they can give you a starting point. Given that it is such a generic error code I would suggest taking the PC to a repair center. I wish I could be of more assistance. If you have any further questions please feel free to reply in this thread.
Quick question, did you upgrade any components prior to the error beeps?
Jul 06, 2010 | HP Pavilion a1610n PC Desktop
I have a HPD 2537F3R. When I try to start the computer the green light on the psu goes out and nothing happens
draw the power supply from cabinate then short green and black wire at o/p of power supply then give the power if fan is rotating then power supply is ok if not then faulty. fault may lies between cpu draw the ram and listen the beep contineus beep should be heard then ram is faulty if no contineus beep then motherboard is faulty
Mar 04, 2010 | Hi-Pro (HP-P401W) (HPP401W) Power Supply
Laptop powers on but will not boot. Keyboard lights remain on. Disk light comes on for a second and then goes out.
For all troubleshooting, have the notebook connected to the DC power supply.
Does the power stay on? if the power goes off are you getting any beep codes or do the leds flash in a specific pattern? if no beep/led codes, and system turns off, then it's likely to be a bad system board or cpu. if power stays on, but you see nothing on the display, the lcd could have gone bad. can you connect an external monitor to this unit?
Oct 03, 2009 | HP Pavilion ZV5260US (PF144UA#ABA) PC...
I have a mecer computer, LGA 775 motherboard asus and the problem is the computer turns on when switching on and there is no display it beeps non stop . CPU and power supply fans are working ,lights goes...
continuous beeping is Power supply, motherboard, cpu, or keyboard problem. somecases it can also be the memory.
start with the memory then cpu and powersupply and finally motherboard.
let me know if the beep code changes as you change components, count the short and long beeps.
Jan 07, 2009 | ASUS P5VDC-X Motherboard
4 beeps at startup and black screen
take out the RAM , THEN insert it again , or
if still the beep error, change the RAM
Nov 21, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Hp motherboard startup problem!!
hmmm my sussgestion in yourr case is that, don't attach all things at once. do the following step bye step.
Step 1). Attach SMPS (power supply to the board), Front Panel Connectio, and an in built speaker and CPU (don't add RAM, HDD, FDD, VGA Card or any thing els)
Power on and watch/Listen carefully:
Case 1: if you can hear a long beep, then your CPU and board is OK
Case 2: No beep means CPU or board is faulty. Try to Reconnect CPU again and do step 1.
Step 2) Now power off and add RAM only.
Power on and watch/Listen carefully.
Case 1: if you can hear the ok beep it means till now your RAM is Ok
otherwise clean your RAM connection and add it again.
Further you can add your VGA, HDD CD-ROM/DVD, PCI Devices etc. and easily short-out your problem.
For your help here is picture of general moherboard with connection details. 86c6af2.jpg
Thanks
Iqbal
Mar 19, 2008 | HP Compaq Motherboard
E machine no power
Make sure the RAM is seated, the CPU, any video card and the Power supply is properly connected.
If you power it on, still get no POST (beep at startup from the PC speakers) its time to replace the motherboard.
Feb 01, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
172 people viewed this question
David Payne
David Payne
