Question about Asko Dishwashers
Our asko dishwasher won't stop pumping out. The drip tray underneath fills with water and floods out. It doesn't matter where you turn the dial it is stuck in the pump cycle. When you empty the drip tray it works again for a while then the same happens again.
    President:
  • 1,462 Answers
You have a leak. only way forward is to take of the panels and look for it
Posted on Oct 01, 2008
Hi, I have a dishwasher model sgs5022gb/07 that won't fill with water. Also the dial doesn't move round as the program progresses. This has happened before but it corrected itself. It's like...
The flood switch is tripped. This is located under the unit. Unplug or flip the breaker to the dishwasher, take off the black kick plate under the door, 2 screws, and you will see the white plastic "pan". The flood switch is located where you can't really see it but it is on the left hand side wall and is made of styrofoam. The best thing to do is to put some rags in the pan, this is not easy because there is little room to put them, and soak-up the water that has filled the pan. Eventually you will get enough water out that the float will deactivate the switch. What you hear "running" when you turn it on is actually the drain pump, it get activated when the flood switch is tripped.
Jun 30, 2011 | Bosch Dishwashers
What does the F2 Error mean? I got that error thsi morning. The engine was buzzing so I turned the power off. I have cleared what appears to be calcium and/or soap build-up in the 3 filters and in the...
The F2 error means the tray underneath the unit has filled with water. You will need to pull out the dishwasher (remove 2 screws at top left/right when door open that prevent tilting). Unplug and pull out dishwasher. Remove 4 screws on bottom rear panel and you will see tray underneath. Sponge out water and F2 error will reset.
However, you should not get water in this tray. There may be a faulty valve, pump or leaking pipe. Run diagnostic mode (described in user manual) to see if leak occurs during filling, draining or circulating.
Sep 19, 2010 | Asko D1876 Dishwasher
Overfilling fault
I believe the washer has had a flood type situation.there is normally a flood switch in the very bottom of the dishwasher right at the very floor,if water get into the bottom tray it floats a piece polystyrene foam wich triggers a little micro switch wich will run the pump continually & show Overfilling fault at the same time..The water in the tray needs to be mopped out with a rag or spunge so that the styrene foam can drop back down.The blockage you had may have caused this flood situation some how.The overfill fault was probably due to the washer not pumping out,So that may be ok now that you have cleared the blockage.hope this helped.
May 13, 2010 | Asko 24 in. D3530FI Built-in Dishwasher
We have a neff dishwasher and the pump is draining all the time (even when the door is open) but there is no water in the dishwasher. Is there a way to stop the pump and reset the setting for the flood...
The water which has activated the antiflood device is actually underneath the appliance it is held in the sump tray and this has to be drained before the A.F.D.will cancel.You will have to remove the dishwasher to get at the underneath but when you have got rid of the water you will still have to trace what caused it.The seal on the circulation pump could be a suspect or a pin hole in the drain hose.
Hope this helps.
May 09, 2010 | Neff 24 in. S5409X0 Built-in Dishwasher
Asko D1706
I also had this problem. Support person couldn't tell me if the pump was supposed to run even when setting the control knob to 'off' (bar before (1)). After draining the pan, the control knob functioned normally. So apparently any power to the unit will run the pump when the overflow pan is filled, no matter the position of the knob.
Sep 10, 2008 | Asko D1706 Built-in Dishwasher
Pump continuing to run -Asko D3100
Micro switch was actually faulty,moisture had entered the switch and caused internal tracking and shorting out the micro switch ,making the pump run continually as it thought it was still in flood mode.
Flood appears to have been caused by a pin hole in the water fill hose in the base of the dishwasher,causing water to spray on the micro switch and eventually biuld up in the base of the machine.
Aug 05, 2008 | Dishwashers
Water flooding out
Hi KellyW,
The dishwasher drain hose may be clogged.  When the dishwashr starts up can you hear the water running into the Sink faucet drain. If not inspect the hose that attaches to the Sink Drain for restrictions.  Also in the bottom of the dishwasher you should have a filter.  If this filter is clogged you cannot expel water.  Clean the filter.
Oct 23, 2007 | Asko D1776 Stainless Steel Built-in...
Asko 1605 cycle stopped, pump keeps running, water pumps out but will not progress to the rinse and wash cycles. Timmer will turn and detergen dispenser will open. Pump keeps running
Thanks my Asko did the same and tilted it forward, drained excess on the floor, even though I thought i'd bailed the whole lot and woolaa fixed - thanks x
Oct 18, 2007 | Dishwashers
Overfill protection tripping
Is there water in the drip pan? My asko developed a leaky inlet solenoid, which would fill the drip pan eventually causing a failure. If the water evaporated, the washer would run. Normally, there should be no water in the drip pan.
May 01, 2007 | Asko 24 in. D3250 Built-in Dishwasher
Dishwashers Logo
453 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
