T.v. philips trouble shooting won't work
The MC44603AP don't have volt, making the t.v. dead
    Champion:
  • 252 Answers
Check the resistor from the main capasitor thru that ic and check also the FET transistor (P6n60)
Posted on Oct 01, 2008
Fencer has not output...fence is dead.
Do you happen to have a volt-ohmmeter? They can be had fairly inexpensively at Harbor Freight, maybe Radio Shack. Switch to DC voltage range above the expected battery voltage, black lead on negative and red lead on positive.
Sep 03, 2014 | Patriot Solarguard 50 Fence Charger 6V
Trouble shoot heater fan on a 1996 Plymouth Voyager Van
Check for 12 volt power to resistor under dash on passenger side. Follow wires from under glove box (from blower motor) to resistor, which will be where wires are connected on duct work. You should be able to test for 12 volt DC power there.
Dec 26, 2013 | 1996 Plymouth Voyager
VIZIO VS470 WON'T TURN ON
do you mean the power indicator at the front panel doesn't light.ok this kind of trouble is in power supply section since the stand by doesn't work. the first place to be check is the fuse if blown. if blown with darkened color that was an indication that has other component part that get shorted. at this time you will need a proper trouble shooting using the a device like a digital or analog tester. if you don't have enough idea on how to do the job and necessary tools, just send it to the trusted service shop to fix the problem.thanks for using the fixya.
Aug 13, 2012 | Vizio VO370M LCD TV
With new battery john deere toy tractor wont work. Any ideas for an trouble shoot?
check tha battery and charger with a multimeter and make sure they are showing at least 12 volts
Aug 30, 2011 | Peg Perego 12 Volt Rechargeable Battery
The AC condenser fan on my 1990 Plymouth Voyager does not switch on even though the compressor clutch engages and condenser fan runs fine when connected directly to 12 volt source. Would appreciate any...
You're going to need a wiring diagram to be able to follow the logic of the cooling fan circuit. Working on electrical without a diagram is like going to a strange town without a road map....won't take much to get lost.
Aug 28, 2011 | Chrysler Voyager Cars & Trucks
My Acer Aspire one notebook ZG5 won't turn/boot on, help?
1. Dead AC adapter
2. Dead battery
3. Broken AC-socket on laptop, so no power is received, and battery is not charging.
4. Dead ON/OFF switch
5. Dead motherboard
Take your computer to a qualified technician, for professional trouble-shooting & remediation.
Jul 19, 2011 | Computers & Internet
Kenmore 80 series electric dryer Model - 110-60882990 The dryer won't turn on. Once the start button is pushed it makes a single clicking noise. If I open/shut the door and push the start button...
check the actual door switch,, you can jumper it to see if this is the problem, Just connect the 2 wires together , if this cures the problem replace the switch
May 25, 2011 | Dryers
I have a dead PHILIPS 42pf5320/10 PLasma TV that I need your help in order to obtain the Service MANUAL and Schematic Diagram. Thanks a lot, Joao
There are only Flow charts available for most sets today. Without some basic trouble shooting skills in electronics your going to have a rough time.
Dec 04, 2010 | Philips 42 in. Plasma TV
I have power to my fema trailer, and 12 volts to the fuse box, but my lights still won:t work Why?
some vehicles have fuses for veh lights and trailer lights in dif locations /some have relay boxes under back of veh lots of trouble shooting
Jun 18, 2010 | Electronics - Others
Dptv335 Philips 55PW9363
i would send the board in for repair... ptscorp.com
Feb 13, 2008 | Philips 55PW9363 55" Rear Projection...
Open Questions:
I have horizontal white lines across the display of my LCD Tv, I've included more info in the details section below I have an Insignia model# NS-46L780A12 LCD TV MFG date July, 2011 , recently the display has been acting very strangely because the issue comes and goes consistently dependent to whether or not there's caption writing on the screen - examples being programming information , channel , time etc.....these info blocks are each in their own particular areas on the display , where this gets odd is when your watching live TV ,these info blocks are always filled in with whichever program that's on, the best description of this issue is from these individual blocks of written captions on the screen example - from the top , there will be a continuous vertical row of horizontal lines starting directly underneath said caption all the way to the bottom , this will happen consistently wherever there happens to be writing on the screens display, so you get multiple rows of these horizontal lines from top to bottom of the display and they'll stay there for the entire time you watch your show , some shows have more ,some less ,depending on the writing for that show , this is all on cable TV / live TV I guess you can call it , and when I use my Fire TV stick with certain apps , I'll get no vertical rows horizontal white lines on the display with the exception that I push the mute button or change the level of the volume and the lines start to want to show up and do partially just for a little while ,but almost as soon as the info on the screen disappears as far as mute/ no mute or the volume level , the vertical rows of horizontal lines go away , I should also say that in either case Fire TV stick or cable , these vertical rows of horizontal lines take a little time to develope all the way from where the caption lettering begin and same process for when they go away , it's not instant in either case , it can take up a couple of minutes for either process to happen , one other oddity I guess you could say , in watching a cable tv program where you may get let's say 5 vertical rows of horizontal lines top to bottom at the beginning of the process , if you happen to try to watch that show ,those individual vertical rows of horizontal lines of varying widths will eventually connect with each other horizontally across the display
Feb 18, 2018 | Insignia Televison & Video
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
