Question about Kenmore 63662 / 63664 / 63669 Microwave Oven
F2 WArning light on Kenmore Microwave oven
My microwave shows an F2 warning light and none of the buttons will work.
  • Anonymous Mar 23, 2014
    Get F2 warning and vent shuts off
The light bulb already works, so this isn't the problem.
Posted on Oct 01, 2008
Microwave door warning light
If this is a built-in wall oven with microwave on top, it is probably the 20-amp fuse located above the microwave. It is wired in series with 1 of the door switches, hence the "door" message. The only problem is that you have to pull out the microwave oven (at least part-way) to be able to get to that fuse.
Dec 08, 2013 | Kenmore Microwave Ovens
Shows error 2
If you are using a Kenmore (or similar), "Error 2" is most likely a warning that your microwave hasn't been plugged in long enough to begin cooking with it. Press "Clear" and wait a few minutes (five to ten), then try again, and it should work.
Jun 17, 2011 | Microwave Ovens
GE PEB1590 microwave oven. Interior light burned
Remove the screws from around the rear of the oven and slide the cabnet off to the rear. You should be able to access the bulb from here.
WARNING: any time you work on a microwave you have to be careful of the capacitor. Unpluge the microwave and discharge the capacitor with a large screwdriver with a plastic handle.
Be careful.
Dec 31, 2009 | General Electric PEB1590SMSS Stainless...
Kenmore microwave model 63792 displays F2 error message
The F2 error code on your microwave oven is a membrane failure.
It is recommended that you replace the membrane first & if you still have problems to replace the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 21, 2009 | Kenmore 63792 Microwave Oven
I have a Kenmore Elite Speedcook microwave model 63792-The display light beeps every few minutes and stays on rather than dimming after use. I unplugged and a message "call Service F2" came up-I used the...
Jul 13, 2009 | Kenmore 63792 Microwave Oven
All looks good but no heat
could be a bad, diode, high voltage capacitor or the magnetron itself.
these parts do brake anytime without warning.
tnx 4 using fixya,
drcool
Oct 14, 2008 | GE Microwave Ovens
Kenmore elite microwave oven displays "Locked" and will not respond
My Kenmore Elite microwave (don't have the model number in front of me) also mysteriously locked its own keypad (we were sitting in an adjacent room, heard a strange beep, and got up to find the LED reading "Locked."). I pressed and held down the Stop/Clear button for ~10 seconds and it returned to normal.
Mar 01, 2008 | Kenmore 62622 Microwave Oven
Kenmore microwave
If this has a controller that runs a microwave and an oven, then the problem F2 means a temperature related fault such as a bad temp sensor / thermostat or a defect in the control board. If it's just a microwave, then the problem is likely a failing keypad. In many cases, those can be replaced economically. If you repost with your exact model number (62622 is not a complete model number) then we can advise you further and more specifically.
Nov 22, 2006 | Kenmore 62622 Microwave Oven
Kenmore 63662 / 63664 / 63669 Microwave Oven Logo
292 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
