Question about Dell 924 All-in-One InkJet Printer
PAPER JAM !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
My printer is working fine ; until i put in paper and then the paper doesn't go all the way to fully complete the job. In other words i mean that when i put in the paper the paper gets jam right in the middle of the job. Please help!!! My pritner is a Dell All-In-one Photo 924 ( i think it is the printers roller thing)
Please help thank you
  • mechdude Oct 03, 2008
    I have the same printer and the same problem.
  • dmontun Nov 20, 2008
    Same problem. paper feeds in and gets crooked and jams up.
    Guru:
  • 558 Answers
Since when the printer not picking up paper from tray or sheet feeder.
Check if the Cover are firmly closed, also look out for any piece of paper jammed the printer.
If it is ok, then check to move the carriage of cartridge/roller and clean it out if you can.
The spring of tray attached on both side may be need to check.
Let me know if I can assist you further.
Posted on Oct 06, 2008
My Gestetner- DSm415pf has an error code 121. How do I clear it so I can use the machine?
The only way to reset the jam code is to find the tiny scrap of paper that is still caught in one of the sensors. The 121 jam code is "Exit Sensor Off", essentially it means that the paper did not reach the exit sensor. This would not cause the machine to still think there was a jam, as the paper obviously never made it there.
Check and make sure you have fully closed all the doors, including the front. If that is good, then open and close all the doors one by one. If that doesn't work, then there is a scrap of paper still stuck in the machine somewhere.
If you can't see one anywhere, then it probably is a scrap stuck at the registration sensor, which is just below the registration roller. I've seen this many times, and unless you really get in there and look closely (Flashlight helps), you will never see. It's a major pain to fish it out, so good luck.
Oct 09, 2012 | Gestetner DSm415pf Digital Imaging Sytem
Hello my CanonPIXMA MX410 has been working fine until yesterday It always says paper jam and I check there is no paper I dobn't know what to do please help me
Hi
Try disconnecting the printer completely from power and from the PC.
Reboot the PC.
Connect everything again.
Clear any print queues.
Make sure the paper feed tray is not filled to capacity.
Hope it helps.
Feb 23, 2012 | Samsung SCX 4200 All-In-One Laser Printer
I have a Canon MP210 scanner/ printer that is telling me I have a paper jam but there is no paper in the machine. I've turned off the power and turned it back on, I've looked for a small piece of...
Your printer might be out of paper.. so try this..... press Black/Color button... if it doesn't work turn off your printer and press paper feeder on the back side and press the power button with holding the paper feeder. Don release it until the process of printer is complete... thanks
Aug 26, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
Hp 309n false paper jam
just fixed mine! So easy, just cut a piece of poster sheet down to paper size and pushed it through the printer. Works fine now. (I had the false paper jam error message, The printer doesn`t know the difference between a stiff roller and a paper jam!)
Dec 06, 2010 | Office Equipment & Supplies
Brother MFC-8840D printer w/false paper jam indication.
With my Brother 8840D I have had paper jams that when cleared would not delete from the display nor would the machine operate until I unplugged the machine for around eight hours. I guess it is a sort of reset or reboot.
Jun 06, 2010 | Brother MFC 8840D All-In-One Laser Printer
Cartridge cradle can't move, says paper is empty when it's not
OK....try removing the carts, close the printer, turn off, then disconnect...alot of the problems with the newer HP printers has to do with their ROM memory....if that doesn't work, then there is defintely something in the paper path, no matter how small. Try to eliminate the copy function....does the error happen as soon as the printer is finished powering up??
Jul 23, 2009 | HP Deskjet F2210 InkJet Printer
Paper jam
try another photopaper of less weight. It could be that the rubber of the paperfeeder is stained with paper dust.
What you also can try is:
take paper tray out.
use a sponge with a rough side (to clean very dirty pans) to scratch
along the grey rubber and to give the rubber more grip.
Mar 22, 2008 | Brother DCP 115C All-In-One InkJet Printer
Paper Jam
I have exactly the same printer, here's how to remove jammed paper.
1. Unplug printer from mains and your computer. 2. Turn Printer around 3. There is a darker-grey panel with a knob in the middle of it. Turn the knob anti-clockwise to release the panel 4. The jammed paper should loop around the roller. Gently pull on the loop slowly until it has released fully. 5. Put the panel back on the printer and turn knob anti-clockwise to lock it into place.
Hope this helps.
BurntLime
Oct 29, 2007 | HP DeskJet 960c InkJet Printer
Paper Feed Problem
This is caused by the solenoid that is activated when picking up the paper. The solenoid is activated and the device goes through the motions of picking up the paper. It fails to pick up the paper or fully feed it past the leading edge sensor resulting in a jam error. You should replace the pick up solenoid assy and also the pick up roller and friction pads.
Jun 27, 2007 | Konica Minolta magicolor 2300DL Laser...
Paper jam at the Transfer Roll
Place a few papers in the tray.
Open up the top, pull out the main (green handle) thingy.
In the very bottom you will see a bar with a single large round rubber wheel in the middle, and white gears on both ends of the bar.
Manually turn the right side gear toward you.
As you do this, you will see the paper lift up and as the rubber wheel turns you will see that it has a notch on the bottom side.
Turn the gear, and watch the rubber wheel until the notch on the rubber wheel is facing up and away from you (and the paper is fully engaged).
Then put the green-handle thingy back in, close the printer, and it should work.
Apparently this resets something.  I have done it a number of times - usually after a paper jam.
Apr 10, 2007 | Konica Minolta magicolor 2400 Laser...
Dell 924 All-in-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
