Question about Toshiba CX36H60 TV
Loss of video and audio
Turn on cold TV,after few seconds,get aloud audeo pop and fluttering screen. Then more audeo pops complete loss of video and audeo.
When i push cable towardsTV ,it returns to normal, may last a minute or so befor it happens again. Tried switching to ant 2, same problem.
After TV is copletely warm problem goes away, no more simptoms.
Is the RFswitch The problem? Is it reparable? I see it is no longer available in parts
    Champion:
  • 252 Answers
Your tv have lose connection, so if know how to re solder then do it. but be careful of short circuit an you may damage your tv.
Posted on Oct 01, 2008
Today my 55" vizio screen popped and then turned red. I unpluged and restarted everything and now the audio is on, the chanels change, but the screen is completely read. some images are readable.
If this is a VO47LFHDTV20A TV set, the problem is most likely your LVDS(cable from the main board to the t-con)cable is faulty. When you turn the set on, do you have a red screen instead of the standard blue screen? Do you also have red tints on all images on all inputs? If this is the case, your LVDS cable is bad. If you are comfortable opening up your set, track down where the LVDS cable goes into the t-con board. Turn on the set, and wiggle the cable, if the red tinting goes away, you will need a LVDS cable, about $24 part.
Dec 09, 2012 | Vizio VO47L 47 in. LCD TV
There was a pop and then my tv picture went black there is sound but no picture
Most likely the pop sound was the loss of your lamp module, due to normal burnout, causing immediate loss of video without affecting audio.
You'll want to do an internet search to price a new lamp for your projection TV.
Here's a YouTube video how-to describing lamp replacement for a Sony Wega Projection TV:
http://www.youtube.com/watch?v=b31IYV3IYKs&feature=related
Oct 18, 2011 | Televison & Video
I left the gas in the tank for almost a year, while i was undergoing chemotherapy, when i started it, it has aloud popping, no missing no loss of power, just the popping.
Sounds to me, like at least one of the cylinders is not fireing and the noise you are hearing is the cylinder attempting to come in, after a while does the popping stop?. Poss a new set of plugs will sort it out, it may even sort it self out with use
Feb 20, 2011 | 2003 Honda VT 750 C2 Shadow
Menu Screen keeps popping up, interrupting cable stream on tv
You have it in the demo mode go into menu and turn it off.
Aug 06, 2009 | Televison & Video
No picture when first powered on; aperiodically needs reboot
Can you switch to another input such as DVD to see if the loss of audio is occurring there as well? This would let you know if the problem is only happening with the Comcast receiver or if it happens with other inputs as well.
Mar 16, 2009 | Toshiba 42AV500U 42 in. LCD HDTV
Pioneer SD-582HD5 - screen went black, no sound, Poor remote feed
The blue tube might be leaking coolant in the high voltage area, that is the cause of the POP. This repair might not be a DIY because of the lethal high voltage surrounding the CRTs tubes.
The slow response from the remote could be because the coolant has affected the main board where the IR signal are going to the remote sensor.
Let me know if you require further assistance.
Dec 20, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Staandard 20
the plyback of your tv had a problem, there's a leak that's why you heared a sound.
Oct 01, 2008 | Emerson EWF2004 20" TV
Intermittant white line with subsequent shut down
You have a vert ic problem very common tv problem.
POSSIABLE SOLUTIONS
1 COLD SOLDER JOINTS ON IC REPAIR COST IS 95.00
2 REPLACEMENT IC 120.00
CALL LOCAL TV SHOP AND ASK FOR PRICES ON A VERTICALE IC REPLACEMT. THANKS DOCTOR VIDEO
May 17, 2008 | Hitachi 36UX59B 36" TV
Popping sounds
Do a complete overhaul of the regulated power supply===solder any/all bad connects,replace any weak capacitors.HB Electronics kit #103-088 will help you locate which parts go bad===get on it before it crashes hard!
Sep 26, 2007 | Daewoo DTQ-27S3FC 27" TV
RCA 27" TV F25432
You apparently have a high voltage arc. Possibly the anode lead to your picture tube. Also the flyback transformer could be arcing. If you're not experience with tv repair, you need to have a tech check it for you. The circuits operate at very high voltage and if you get into it you can get a possibly fatal electrical shock. Be careful !!! Stargazer
Jan 11, 2007 | RCA F27645 27" TV
Televison & Video Logo
48 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
