Question about Epson Stylus RX680 Color All-in-One InkJet Photo Printer
Epson RX680 Startup Printer Error
I just bought the printer, turned the power on to install printer cartridges, and I get a Printer error on it's front LCD.
Apparently a common problem. I thought there might be an easy fix, such as cardboard or a piece of tape somewhere to be removed.
After fiddling with the power trying to reset it a couple times, it seems like it's trying to feed paper to get the error. I added paper, did not feed it, but there was nothing blocking it. Still acts like it is a hardware issue, not a software issue, but I cannot find any solution yet. Suggestions?
  • 2 more comments
  • tuttie4u Oct 09, 2008
    I have intstalled the software that came with the printer on two computers.Using the USB port on the side. Neither computer recognizes the plug and play device. The error on the screen says unable to recognize this device. I have uninstalled several times and am lost for answers. I didn't realize that this would be such a hassle to get a printer to work.
    I have tried it on both computers on is Windows XP and the other is Windows 2000, neither one will recognize it !!!
    Thanks for your help...
    nancy
  • Mitchka Oct 12, 2008
    Try using the software port inside for use.
    My computer did the "does not recognize device" error, but it worked fine. A reboot, and a windows update solved all the problems. I am not sure which one did it, but the next day, I had no problems!
    - All drivers from the CD are on the Epson website, go there.
    My error was an internal software error of recognition of the printer heads. Epson sent me a new one at no cost, got here quick, only 4 days!
  • Anonymous Oct 25, 2008
    Triple checked by two people for tape/cardboard. None.
    Power unit on to install ink cartridges and after a few seconds a "grinding" sound and a resulting error message on the LCD screen telling me to turn the printer off then back on. No help. Tried with and without duplexer and front paper cassette - zilch. Although the USB cable was NOT plugged into my computer yet, I even unplugged the USB cable entirely without any success. I setup one of these printers a week ago and all went smooth. I was bummed when this one appears to be defective right out of the box.
  • MAGGERS415 Nov 23, 2008
    ERROR: A PRINTER ERROR HAS OCCURED. TURN OFF PRINTER AND TURN IT ON AGAIN.PLEASE SEE YOUR DOCUMENTATION.
    i HAVE NO PAPER JAM, IT MAKES A LOUD NOISE THEN GIVES ME THAT ERROR, ANYONE HAVE ANY IDEAS?
I had the same issue when the printer arrived. I powered the unit off, moves the ink cradle to the left about 1/2 " then powered it on. Then it worked from there.
Posted on May 05, 2010
  • lkkk Feb 06, 2011
    GVerdi, you were right on.
    Can't believe it.
    I must have turned this piece of sh** on and off like a total moron about 15 times.
    I remember instructions specifically stating DO NOT MOVE THE PRINT HEAD OR IRREVERSIBLE DAMAGE WILL OCCUR. "
    Thinking logically, "If it doesn't work at all, what the hell am I going to damage?"
    Just stuck my fingers in there, shifted it to the left, and the damned thing came right on!
    THANKS.
    Staples just ripped me off another $80 for ink and I can't return it.
    Almost threw it on the street...
    Guess I don't have to...
I'M LOST CD
Posted on Oct 05, 2008
Epson RX680 Printer - How do I reset the firmware to defaults?
you will need the adjustment program to be able to reset your printer to the factory setting.. and it's really not recomm to reset the firmware as you risk of damaging the unit further.
what about the panel light.. how does they blink when the moment you switch it on?
Jun 08, 2010 | Epson Stylus Photo RX680 Printer
I have an Epson RX680 printer. When I turn the
Press the stop/clear button then press the maintaince button(spanner) and the ON button all at the same time in that order.That will reset it.
Jan 31, 2010 | Epson Stylus Photo RX680 Printer
Won't reconize new ink cartridge rx680 printer
hi friend,
Run the Head Cleaning utility to clear any clogged ink nozzles. To run the Head Cleaning Utility, follow the instructions below.
For Windows users:
1) Make sure that your printer is ON and the error light is off.
2) Access the printer software.
3) Click the Utility tab, then click the Head Cleaning button.
4) Follow the on-screen instructions
5) When the power light stops flashing, click Print nozzle check pattern in the Head Cleaning dialog box to confirm that the head is clean and to reset the cleaning cycle
If you find that any segments are missing from the nozzle check pattern, you may need to repeat the head cleaning and print the pattern again.
Or u could consult the user manual
u should let the ink settle for 12-24 hrs???
hope this helps u
please rate me..........................
thank u for using fixya
regards
sivaranjini
Nov 25, 2009 | Epson Stylus RX680 Color All-in-One InkJet...
Rx680 epson ink cartridge error
I was changing my cyan cartridge and got this error. I thought for sure it was that cartridge. Tried a few things including pulling them all out and putting them all back in. Didn't work.
Finally, I found a place in the software that showed the info on all the cartridges. Turned out the light cyan was not reading. Took it out and rubbed the contacts with a pencil eraser. Voila! Problem solved.
Sep 21, 2009 | Epson Stylus RX680 Color All-in-One InkJet...
Epson rx680
one ink cartridge is out of ink but...
when we try to replace one of the color ink cartridges we get this error message:
ink cartridges cannot be recognized. make sure ink cartridges are installed correctly - how do I get the printer to recognize my full ink cartridge?
Sep 18, 2009 | Epson Stylus RX680 Color All-in-One InkJet...
Epson RX680 Scanner Error msg and noise
If you only purchased it on the 8/9/09 then it is still under guarantee so the cheapest fix is return it for replacement.
Aug 24, 2009 | Epson Stylus RX680 Color All-in-One InkJet...
Epson RX680 startup error
New problem?Always worked before on this same computer?  Have you tried reinstalling the computer and driver?
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Overview&oid=90584
Jan 14, 2009 | Epson Stylus RX680 Color All-in-One InkJet...
RX680 Printer Error
Try turning it off and taking out the ink cartridges and putting them back in. If that doesn't work it could be defective. If it's new then it should be under warranty.
Oct 07, 2008 | Epson Stylus RX680 Color All-in-One InkJet...
RX620 "Ink Cartridges cannot be recognized"
Found the solution at
http://www.fixyourownprinter.com/forums/printer/54833
Try pressing down on the cartridges after inserting them and closing the top of the cartridge carriage. Worked like a champ on my R320 printer!
Cleaning the contacts on the cartridge with a soft tissue may help too.
Mar 21, 2008 | Epson RX620 All-In-One InkJet Photo...
Epson Stylus RX680 Color All-in-One InkJet Photo Printer Logo
756 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
