We have a Panasonic HDTV compatible 1080i. The screen shows white fuzz when it is on. You can make out some of the picture, some color still shows through. Is this an easy fix?
  • 927 Answers
Good Day;
Yes, this is may be an easy fixya. Brand, Model number. Call a Factory Authorized Service Company to service the TV. Good Luck, big IRISH.
Posted on Oct 01, 2008
Panasonic hdtv 1080i picture bright
It could be your main board going bad.
Jun 01, 2013 | Televison & Video
What is the picture quality setting for a panasonic 1080i HDTV
Adjust the video output settings on the devices connected to your Panasonic HDTV. To view 1080p programming, enter into the service menu on your external device and change "Video Output" to the appropriate resolution. By default, the Panasonic TV is always displaying content in the resolution provided for it by the external device. If your cable box is set to output in "1080i," for example, your TV will display content in 1080i.
Let me know if this fixes the issue.
Regards,Suhail
May 11, 2012 | Vizio VO37LHDTV10A 37 in. LCD TV
How do I change my W2613 TV resolution to 1080i? I just bought this TV a few weeks ago and I want to be able to play my XBox360 in HD and when I connect all 6 wires (Red, White, Yellow & Green, Red,...
use just the red green and blue wires for the picture and NOT the yellow wire. That is why it is messed up.
XBOX games only play in 720, but it will still look great.
Aug 09, 2010 | Televison & Video
Convergence panasonic HDTV 1080i bbe hi definition
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 17, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Screen has too much green all of a sudden
Try balancing the tubes out, turn your color all the way down and the brightness in the middle, then find the focus block, it will be a block with 6 controls one row will say screen the other will say focus near the picture tubes, adjust the screen controls(one control for each color) until the picture has a good black and white look to it, then turn your color up and it should look fine. This is how i balance out the picture. But there is another method that allot of techs use, the other method is to adjust the brightness up until you see what is called retrace lines it is a jagged line going down the screen, once you see these lines back the adjustment down just until they disappear. Do this for all three colors. This method works but on an older set can throw the white balance off because of tube wear.
Sep 03, 2009 | Hitachi 57F500 57" Rear Projection...
Blury screen on panasonic 1080i hdtv
seeing double and a lot of green on my panisonic hdtv 1080i what do i need to replace?
Aug 23, 2009 | Panasonic Televison & Video
Dont know the contrast ratio of this tv
Specifications
Panel Type: 32" Diagonal (31.5" Viewable), 16:9 Wide Screen, Color TFT Active Matrix LCD
Panel Specifications: Anti-Static and hard coated surface
Pixel/Dot Pitch: 0.507mm (H) x 0.5107mm (V)
Display Compatibility: HDTV (1080i)
Signal Compatibility: 80i (SDTV), 480P (EDTV), 720P (HDTV), 1080i (HDTV)
Response Time: 8 ms (typical)
Colors: 8 bit 16.77 Million colors
Brightness: 500 cd/m2
Contrast Ratio: 5500:1 Dynamic Contrast Ratio
Viewable Angle: 178° (horizontal and vertical)
May 23, 2009 | Vizio VW32L 32 in. LCD HDTV
My picture is dark and have changed the brightness
Hello!
Well it seems that your lamp is about to go out, replacing the lamp might jus do it ! Also make sure you get a Philips lamps, they work like a charm.
And regarding the long plastic cover just be a little bity patient and you'll make it come off, just make sure you do remove all the screws.
Apr 18, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Panosonic 50" LCD 1080i HDTV screen picture faded
try setting your menu;s to adjust the picture settings
Aug 23, 2008 | Panasonic PT-47WXC43 47" Rear Projection...
GREEN DOTS ON SCREEN PANASONIC PROJECTION HDTV 1080I
Ah, big no-no.
This is the result of the coloring being pulled to the front of the screen.
This is caused by magnets. Anything magnetic will cause this, even a small one.
Hopefully you have warrenty, this is pretty expensive to replace.
Jan 02, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
