Question about Frigidaire PLHS267ZA Side by Side Refrigerator
Starter relay wiring
I recently bought a new starter relay for my plhs267za but it did not come with directions on how to connect the wires. Does the red wire go to the L side or the N side. part number 218721119
Red wire goes into the L side.
Posted on Oct 09, 2008
2010 Patriot won't starter key works lights horn new starter & battery checked 30 amp fuses starter
WHAT ????? want to try again .
2010 Patriot won't start ,key work's , light's ,horn ,new starter and battery ! checked 30 amp fuse's starter ?????? Maybe you should take it to a qualified repair shop .Sounds like you have no clue.
Feb 01, 2017 | Cars & Trucks
When the temperature is in the mid to low 30's, 92 Honda Civic will not turn over. No griinding or anything, not even a click. I've been told the battery, starter and carburator are ok. Help! Taxi's are...
Let's see if I can explain it. Pretty simple start circuit, but starting issues are very common to Hondas and Toyotas of the '80's and early'90's. Lots of guys used to rewire their start circuits with new wiring and relays from ignition switch to the starter solenoid just to stop those no starts.
From the ignition switch is the black/white start wire, it is hot only in start, goes direct to the "starter cut relay"- a 4 pole starter relay, the black/ white wire (black with a white stripe) is both the power feed and the coil power to the relay. Before the wire enters the relay it is spliced. one wire goes to power feed at relay, other wire goes to coil side of relay. Here's where the clutch switch comes in: the clutch switch acts as the ground for the relay's coil side. Okay, you turn key to start, power goes to the relay on both the power side and the coil side. When clutch is depressed, it grounds the coil side of relay, this energizes the relay, so power goes out of relay on the power side, as a black/red wire...and goes direct to the starter solenoid. Somewhere before it reaches the solenoid, it turns back into a black/white wire. But nothing else is in a wiring diagram for your start circuit. Buy a can of CRC electronic cleaner. Spray all connectors in the start circuit. Pull off the solenoid wire at starter-that connector. Also the starter relay , pull it out and clean the relay terminals where it plugs in. Get all clean connections in the circuit. If no help, swap in a different relay. If still no help, get a voltmeter (or a test light), when the starter doesn't want to work, check for power at the starter solenoid with key held in start, and clutch depressed. If power there, the solenoid is the problem. If no power, work back to the relay. Pull relay out. With key held in start, two terminals for the relay should have power-the coil plus side, and the power feed from the ignition switch. If both have power, may be the clutch switch not grounding the relays coil side. If no power to relay, check the start wire out of the ignition switch.
Need a wiring diagram? This site is awesome-free wir. diagrams and TSB's for every make and model:
Dec 26, 2013 | 1992 Honda Civic
Wont start sometimes
NO. Fuel pump relay controls the fuel delivery. You should NOT be hearing ANY clicking sounds when starting. If you have a manual tranny, you have a starting system that includes: a starter relay, a clutch safety switch, ignition switch, starter, battery.
On my \'91 Integra, I by-passed the normal starting system by running 2 separate 12-guage wires to the dash (thru the firewall, mounted along the firewall over across to the starter and to the under-hood fuse panel). I connected 1 wire to the under hood fuse panel (for power), and the other wire directly to the starter relay. Then, at the dash I connected both wires to a high-quality "momentary-on/off" toggle switch - this is my starter switch. I turn the ignition key to when the dash lights come on, then flick the switch, and BINGO the car always starts right up.
BUT, this is somewhat unsafe because it doesn\'t use the clutch safety switch - which is nothing more than a spring-loaded switch on the arm of the clutch pedal connected to the ground. IF you are using the standard starting system, you MUST engage the clutch for the starting system to make contact with the ground in order to engage the starter. So, check this switch first for a good connection to ground. It usually fails first before anything else. If it checks out, THEN check the starter relay, located waaaaaaay up underneath the dash, right in the middle. To get at the starter relay, you\'ll have to remove the glove box, and plastic & metal kick panels on the passenger side. The relay is located way up underneath the dash, next to the Blower housing. You\'ll need a long socket extension to reach it. Someone at Acura/Honda decided this was the best place for it. Boy would I like to whack him with a 2x4.
See this diagram for reference - the starter relay is #15.
Nov 13, 2013 | 1994 Acura Integra
Where is the starter relay on a 1990 Camry with 2.0L 4-cylinder and automatic transmission?
There is no starter relay on the 1990 camry 4cyl . If you check the fuse panel by the drivers left ankle you will see that there is a socket for a relay but it is missing. On the manual transmission cars it has a relay in that socket. The black and white wire goes directly through the neutral safety switch to the ignition switch.
You can see that same wire on the plug in connection of the starter. If you are having intermittent cranking it is probably high resistance in that circuit, If you are handy just install a relay before the starter connection and have the black and white wire just power your relay coil. The new relay must then be connected to the battery plus and the out put to the plug in wire you cut to install the new relay.
Aug 23, 2012 | 1990 Toyota Camry
Nissan Altama Starter Relay electrical problems or a fuse?
Double check the battery positive connection wiring carefully as it commonly has connection problems when the battery is changed.
Apr 08, 2017 | 2004 Nissan Altima
I need a wiring diagram for my 1975 iron head harley. Especially from relay to seliniod
I think I can help with the wiring diagram. Contact me directly at wd4ity@bellsouth.net The earliest drawing that I have is for a 1979 model but it can be used.
You starter relay has three connections on it. Usually two large connections and one smaller. One large connection is the hot wire from the main breaker or battery. The other large connection goes to the small connector starter solenoid. The small connector on the starter relay is from the starter button.
On the starter solenoid, the positive battery cable goes to the solenoid long connector. The cable to the starter comes off the shorter large connector. The small connector has the wire from the starter relay.
I hope this helps, if not, drop me a line directly. Good Luck
Feb 08, 2010 | Harley Davidson XLH 1000 Sportster...
1994 Camry wont turn or do anything for that matter
The red wire is the starter wire, this is the main wire that connects to your starter switch to tell the relay to turn over that starts your car, the other wires are the ingnition wires, these wires is what allows the vehicle to turn on (lights, radio, engine,)
What it sounds like he did when he removed the alarm module was disconnect the power wire that supplys the starter switch.
Try tracing the wire back to where it is connected and see if there is any wire cut the same way as the other end.
try connecting a a remote starter switch from the battery directly to the starter solenoid. this will allow you to see if the wiring inside the car is disconnected or if it is the starter.
Oct 09, 2009 | 1994 Toyota Camry
Starter relay hot wire only works when bipassed
needs a new wire or the lugs might have a lot of corrosion but i would still get a new starter relay also.
Oct 04, 2009 | 2000 Suzuki VL 1500 Intruder LC
Frigidaire PLHS267ZA Side by Side Refrigerator Logo
416 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
