Nov 21, 2015 | Goodman Heating & Cooling
Feb 16, 2015 | Gibson KG7TC060D24B 60,000 BTU 95.1% Gas...
1. On a call for heat
2.The draft inducer motor starts.
3.The pressure switch which has a small plastic or rubber tube attached yo it senses the
negative pressure produced by the draft inducer and
closes.
4.The draft inducer runs for 30 seconds to a minute before you hear the gas making a hissing sound. The ignitor did not glow,therefore the flame sensor (a small
metal probe about 1/8" in diameter, with a white
porcelain base) does not sense the flame, so after 8
to 10 seconds the gas hissing sounds stops with no
ignition of gas to heat your home. Your furnace shuts down and goes into a lock out condition until you turn your power switch back
off and on again. Then the sequence starts all over
again with no ignition of the gas.
Solution:You probably need to
purchase and install a new ignitor. I would suggest that you inspect your
ignitor closely for cracks. Please Make sure you do not
touch the ignitor with your bare hands. If you do not
visually see a crack, then you could possibly have a furnace control board problem or a
bad limit switch or rollout switch problem.
Mar 10, 2011 | Heating & Cooling
Feb 17, 2011 | Heating & Cooling
1.
Thermostat calls for heat.
2.
Draft inducer motor starts.
3.
Pressure switch attached by a small plastic or rubber tube senses the
closes.
4.
Draft inducer runs for 30 seconds to a minute before you hear a gas hissing sound. The ignitor did not glow, the flame sensor (a small
to 10 seconds the hissing sounds stops with no
ignitor closely for cracks. Make sure you do not
visually see a crack, then you could have a furnace control board problem or a
limit, rollout switch problem. The furnace's control board
might not be supplying the voltage to the ignitor. If your furnace
lights and the gas stays on for 8 to 10 seconds, then shuts right back off, then
you need to clean your flame sensor with light sand paper or steel wool. You
might need a new flame sensor, but most of the time they can be cleaned an will
work well after cleaning.
Dec 07, 2010 | Heating & Cooling
1. Thermostat calls for heat.
2. Draft inducer motor starts.
3. Pressure switch attached by a small plastic or
rubber tube senses the negative pressure produced by
the draft inducer and closes.
4. Draft inducer runs for 30 seconds to a minute
not glow, the flame sensor (a small metal probe about
1/8" in diameter, with a white porcelain base) does not sense the flame, so after 8 to 10 seconds the hissing sounds stops
with no ignition of gas to heat your home. Your
until you turn your power switch back off and on
again. Then the sequence starts all over again with no ignition of the
gas.
Solution: You
probably need to purchase and install a new ignitor. I would suggest that you
inspect your ignitor closely for cracks. Make sure
you do not touch the ignitor with your bare hands. If
you do not visually see a crack, then you could have a furnace control board
problem or a limit, rollout switch problem. The furnace's
control board might not be supplying the voltage to the ignitor. If
your furnace lights and the gas stays on for 8 to 10 seconds, then shuts right
back off, then you need to clean your flame sensor with light sand paper or
steel wool. You might need a new flame sensor, but most of the time they can be
cleaned an will work well after cleaning.
Nov 26, 2010 | Heating & Cooling
Jan 06, 2010 | Goodman GDS80904BNA Open Flame Heater
Dec 04, 2008 | Goodman GMS90703BXA Heater
Nov 08, 2008 | Goodman GDS80703ANA Open Flame Mid-Size...
63 people viewed this question
