Samsung model tc2550s no remote need to program
I have a samsung model TC2550S television that I have lost the remote. I need to program the tv for my cable system, otherwise I get only 12 channels. How can I do the autoprogramming without the original remote?
  • beejboy Oct 14, 2008
    did you ever get any answers for this ??? i have the same trouble
  • noesp Nov 02, 2008
    I have the same problem! someone please help!
SOURCE: Lost factory remote
you need the remonte control original bath this situesen you need the selection deader cod four your remont controler
Posted on Jul 12, 2007
SOURCE: Old Samsung Tv Problem CT-5029v - Channel Auto Program
You might try a oneforall remote instead of a whatever :) They support a lot of old and new tv's.
Posted on Jan 15, 2008
MikeMaierTV
  • 206 Answers
SOURCE: Magnavox TV accessing menu without remote
There may be away but need the model number to narrow it down, most remotes can be found at www.vancebaldwin.com and for usaly under $20.00
Posted on Feb 13, 2008
SOURCE: TIVO DVR : Won't Change Channels
Set up your infrared blasters connected from your IR port on the Tivo and by placing the two lead lights in front of your cable box so it (the cable box) can read the signal.  Then go to Channel settings accessed through Tivo Central and follow the questions. It will ask you to change channels until the remote is working correctly.  This all worked on a different "input" on my Mitsubishi TV (it has multiple inputs.  I have the cable input on a different "input" to make it work.  Hope this helps.  Call TIVO tech assistance because they are the ones who talked me through this.
Posted on Jan 15, 2009
SOURCE: i need the instrution and
You can easily download the manual as pdf. from their website
http://www.pansat.com
Posted on Feb 12, 2009
I have a Samsung TV iamuseing a ermsom remote need codes for this remote
Search Results
    Remote Control Codes
    support-us.samsung.com/.../pop_troubleshooting_fr...
    Samsung ElectronicsAug 11, 2011 - ... all televisions. If you encounter problems, use the television's ownremote control. ... While the television is on, press and hold the TV Power button and enter the corresponding two-digit code. ... SAMSUNG ... EMERSON. 64.
    Remote Control Code List
    www.jumboremotecontrol.com/remote_control_code_list.html
    ... codes for the remote. If you do not see your device listed, you can use the codesearch feature to program the device into the remote. TV Codes TV Code List ...EMERSON ... SAMSUNG, 004,005,009,015,104,105,106,109,172. SAMSUX ...‎Guide to Programming the ... - ‎Download the Manual - ‎8 Device Learning Jumbo ...
    Remotes - Device Codes - HiFi Remote
    www.hifi-remote.com/codes-tv.shtml
    TYPE, BRAND, CODES ... TV, Emerson, 0463, 0236, 0019, 0180, 0280, 0179, 0154, 0177, 0178, 0038, ... TV, Samsung, 0019, 0060, 0030, 0056, 0178, 0032.
Feb 05, 2016 | Samsung 50 in. Plasma TV
Need the programming code for samsung dvd-vr375 thanks
Go to this site and put you make and model number in the search bar and you will be able to get the manual for your dvd player. http://tv.manualsonline.com/support/other/flat-panel-television/instruction-manual
Dec 17, 2014 | Samsung DVDVR375 DVD & VCR Combo Recorder...
I lost my remote for my brand new Samsung Blu Ray player model BD-F6900 and I tried to program my Xfinity remote but it still won't allow me to select English on the On-Screen Language screen. I cannot...
There is a free app called the Peel Universal Smart TV Remote that will allow you to turn your phone into a remote control that will operate both your television and your Blu-ray disc player.
Sep 20, 2017 | Televison & Video
Just moved and lost my samsung remote. I have direct tv but I'd like to watch movies. Will a universal remote fix my problem? Also, where is the model number on a samsung LCD tv.
The model number (label) is usually located either on the back of the TV, or on the r/hand side of the TV.
To obtain the best from your set, you ideally want the original factory remote. However, some Samsung remotes share the same functions.
Generally, the remotes are specific to each brand, but some brands of remotes have been known to transmit similar frequencies (i.e. Philips & Samsung).
You can only use a Universal remote, if the remote supports the Samsung programming codes (check the remote's user guide to see if Samsung codes are supported).
Cheers,
Sep 04, 2011 | Samsung Televison & Video
I lost the copy of the codes for my cybertec q-x33e universal remote. i need to program my remote control to my samsung tv. please help.
Here are some codes you can try for Samsung brand TVs:
008, 011, 018, 021, 024, 025, 033, 037, 039, 040, 049, 050, 051, 091, 113, 123, 375, 378
To program the remote:
1. First turn on the television.
2. On the remote, hold down SET until the indicator light turns on.
3. Type in one of the three codes above (I would just try them in order).
4. If the code is accepted, the light will turn off. Press the power button on the remote; if the TV turns off, then the code is correct.
If the TV stays on, repeat steps 2 through 4 until you find a code that works.
Jun 14, 2011 | Televison & Video
I have a samsung tv model # LNS2351W with a samsung remote control model # BN5900545A and I can not program it to the tv. I do not have the code or the users manual for the remote control, so I can't...
Have you been trying to set the program by manual (by TV buttons). If you can set it manually, aim the remote straight forward at the TV sensor and press then notice the light is responsed (blingking each pressing time). If it does not response, the problem may come from the sensor or remote. You need another good remote to isolate this problem. Alternatively, you can try this remote with another Samsung TV (if possible) to see how it works.
Jun 11, 2009 | Samsung LN-S3241D 32 in.LCD HDTV
Trying to find remote or is there another way to get all stations on this t.v without the remote
You can try to buy a samsung universal remote, buy a samsung vcr which has a tv/vcr switch, and this will let give you control of the tv and also allow you to program the channels. Because the vcr acts as a tuner.
May 11, 2009 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Using my universal remote contol,lost sound on 2 TV channels
The solution is to change the audio input from SAP (secondary audio programming - default on TV sets sold in Canada) to Stereo or Mono. Your remote will need to be able to access the "Menu" settings screen for your television set.
May 07, 2009 | Samsung TV Remote Control
Universal - remocon settings
I need the code for the Sumsung Universal Remocon for my Samsung TV model TXN2726. It is an older TV 2003 model. It was given to us recently but the remote needs to be programmed and we weren't given the programming code.
Jan 20, 2009 | Samsung TXL2767 27" TV
VIdeo Problems with television.
If these are diagonal green lines then one of two things is wrong. You either have a bad video driver transistor for the green on the CRT board or the IC the controls the CRT (jungle IC) is bad. The possibilty of a bad green gun in the CRT is there as well.
May 24, 2008 | Televison & Video
Televison & Video Logo
194 people viewed this question
Top Televison & Video Experts
