Question about Nintendo Wii Console
Wii do you have a wii?if you do icant figure out internet settings.
  • 25 Answers
If you go to wii options on the bottom left of the wii menu, hit wii settings and then keep moving to the right until you see the option "internet," click on it and select connection settings and search for an acces point. If you can't find one that is unsecure, go back and buy a Nintendo wi-fi usb connecter, (I got mine @ walmart), and then install the software into your computer and follow your instruction manual. then connect with the Nintendo wi-fi usb connectewr on the connections screen, then you should be good to go!
Posted on Nov 28, 2008
I cant figure out how to connect my wii to the internet so I can play a game on the internet
You need to setup your connection settings first. Watch this video:
Aug 09, 2011 | Nintendo Wii Console
First off we have to make sure that your unit is properly connected to your router.
Note : Please note that Non-Nintendo manufactured USB LAN adapters will not work with the Wii console system.
1) Unplug your modem first for about 90 seconds and then plug it back in before continuing.
Note : You need to unplug the cable going to your computer when you wish to connect your Wii console online.
2) Insert the Wii LAN Adapter into the USB port on the back of the Wii console. The Wii should be turned off when you do this
3) Connect an Ethernet cable from your wired router to the Ethernet port on the Wii LAN Adapter.
4) Turn on your Wii and go to the "Wii Main Menu," then select the Wii icon (on the bottom left)
5) Select "Wii Settings" then "Wii System Settings"
6) Scroll to page two (using the arrow on the right) and select "Internet."
7) Select "Connection Settings." and then "Connection 1." ( connection 1 should say " None" if it says otherwise, click on Connection 1 and choose " Clear Settings")
8) Select "Wired Connection." then "OK" - It will now run a conncetion test
If the connection test is successul, it will do an update and will ask you if you agree to the User agreements. After agreeing to the terms, that's it. You should now be online.
I hope I was able to help. Hoping to hear good results.
All the best to you Mr. Edwards.
Cheers :)
Jul 27, 2011 | Video Game Consoles & Games
Wii says needs update in order to connect with Wii Store which would allow me to download NetFlix Ap. It is connected to the net but I keep getting error message that says update could not go through. It...
Hi there!
There are two ways to connect your Wii to the internet; you can connect to your wireless network (if you have a wireless modem set up in your house), or you can connect using a wired connection directly to your modem.
If using a wired connection, you will need to purchase a Wii LAN adapter and connect that from your WII into your wired router.
Once you have figured out what connection type you will use (and if using a wired connection, purchased and connected your Wii LAN adapter) you will need to take the following steps:
  • Turn on your Wii and click on the "Wii" button on the bottom left of the screen
  • Click on "Wii Settings"
  • Click on the arrow on the right side of the screen and select "Internet"
  • Select "Connection 1 : none" (if you don't see "None" in Connection 1, click the Connection 1 button, then choose "Clear Settings")
  • Click on "Wireless Connection" and then "Search for an Access Point"
  • Select "OK" and the Wii will display all the wireless networks it finds.
  • Select the wireless network that is yours.
  • If it asks you to enter a password or key, then your wireless connection is password protected and you will need to enter the password that was setup to allow access to your network.
  • Select "OK," "Save Settings," and then "Yes."
  • Your Wii will test the connection and you should get a message saying connection was successful.
  • Connect your Wii to the Wii LAN adapter and connect that to your modem or broadband adapter. Please not that you will need to unplug your modem for a few minutes to reset the connection and you will also need to unplug the connection to your computer when you want to connect your Wii to the internet.
  • Turn on your Wii and select the Wii icon on the bottom left
  • Click the arrow on the right side of the screen and select "Internet"
  • Click "Connection Settings"
  • Click "Connection 1 : none" (if you don't see "None" in Connection 1, click the Connection 1 button, then choose "Clear Settings")
  • Click "Wired Connection"
  • Click "Ok"
  • Your Wii will now do a connection test
  • You should see a message saying the test was successful
Hope this helps!
Jul 06, 2011 | Nintendo Wii Console
When I go to get Internet soo I can play online it says that I can't use the connection and there is Ann error code it is 52230.I have the right password for the router and the Internet but it just won't...
What is happening is your router is not able to assign an IP address to your Wii. More than likely one of your units, either the Wii or the router, is set for automatic assignment, and the other has been set for static IP addresses. Both of the units should be set for automatic assignment of the IP address.
Go to the Wii Settings screen, and then go to page 2 and select Internet. Select Connection Settings, and choose the connection file you are currently using which should have a red box highlighting it. Then choose Change Settings, and click the blue arrow until you see Auto-Obtain IP Address. Your next step would be to set the IP address of the router you are using. The more common routers use the following IP's:
  • Linksys - enter:
  • Netgear - enter:
  • Belkin - enter:
  • D-Link - enter:
  • Apple - enter:
  • 2Wire - enter:
  • Actiontec - enter:
  • SMC Networks - enter:
From here you then have to ensure that your router has been set to Auto Assign the IP addresses as well. The setups differ from router to router. If you are unable to figure out how to change the setting to auto message us back with the brand name and model of your router and we can then supply you with more assistance.
Apr 05, 2011 | Nintendo Wii Console
Icant get my wii to read the netflix disc
Your wii has to be modded to read dvd discs. However you can rent netflix over the internet with your wii where no disc is required.
So you have 2 options. 1. Turn your wii into a dvd player by having it modded at
2. Get netflix on your wii and download the movies directly to the wii.
May 21, 2010 | Nintendo Wii Console
I cant figure out how to connect my wii to wifi internet
mate i do not own a wii but my cousin does .. theres wireless internet on the WII !!! thats really cool so you might wanna go to configurations or settings check on wireless and your wii will search for acces points
Apr 10, 2010 | Nintendo Wii Console
Having problems getting my wii on line can not figure it out
not sure what your problem is exactly but here goes. on your main screen go to wii options (bottom left)then into wii settings after that across to page 2 and click on internet then connection settings. pick a connection 1,2 or 3 then wireless connection (i presume you've got wireless) then put it your router info and it should connect
Jan 22, 2010 | Nintendo Video Game Consoles & Games
Icant even get rock band started
no just go to settings on the game and configure your guitar drums ect.
Jan 08, 2009 | Nintendo Rock Band for Wii
When you are not able to connect with Internet from Your Wii, means there is something wrong with the settings. You may go to Wii Fix Guide and check out the guide available there, This DIY guide will show step by step pictures to fix the problems yourself without any technical knowledge.
Dec 14, 2008 | Nintendo Wii Console
Wii internet connection
is this the first time you encounter this problem?
have you even connected the device before to your wii..?
thank you & kindly please provide additional information which can help us to figure out the problem...
May 13, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
90 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
