Question about Canon imageRUNNER 3300 All-In-One Laser Printer
I am reciving error code e000064
I get the error message when i take back to back printing
  • ravineelu Oct 03, 2008
    Thank you very much for your suggestions. It worked.
  • 37 Answers
Error code e000064 indicates machine having problem with transfer roller , black roller found underneath drum unit. it may require replacing or needs cleaned being soiled . this area require technical experts as transfer roller operates on high voltage . hope this helps
Posted on Oct 02, 2008
HP 4350 ERROR MESSAGE: 49.2F90
"the printing operation has been aborted.
The issue can be caused by a firmware error, invalid print commands, corrupt data, invalid operations, poor quality parallel cables, poor connections or specific applications.
Action :
1> Press Cancel Job to clear the print job from the printer memory.
2> Turn the printer off and then on to clear the error message.
3> Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job, contact the software vendor for assistance.
If the above action does not solve the issue, contact HP or authorized service provider."
Mar 15, 2008 | Office Equipment & Supplies
I installed a new color cartridge in my printer but it comes up with cartridge missing and i can't get to print in color
Power off the All-In-One and remove the power adapter (brick) from the back of the unit. Wait 20 seconds, reinsert the adapter, and power the unit on.
Did the error message return?
Yes: Continue to step 2.
No: Print a test page. If the test page prints, the error is resolved. 2
Reset the All-In-One's factory defaults (click here for instructions).
Yes: Continue to Checking the Cartridges.
Open the top cover of the All-In-One. Remove both cartridges. Close the top cover. 2 Power off the All-In-One and remove the power supply brick from the back of the unit. 3
Reinsert the power supply brick into the back of the All-In-One and power the unit back on.
Does the error message reappear?
Yes: Skip to Contacting Lexmark below. There is a hardware issue with your printer and you need to contact our technical support center.
No: Continue to step 4. 4
Clean the cartridge contacts (click here for instructions) and the AIO carrier contacts
(click here for instructions). Continue to step 5. 5
Power the AIO on, reinsert the black/photo cartridge, and close the top cover. Power the All-In-One off and then on again.
Yes: Power the unit off and try step 5 with another black/photo cartridge. If the error persists with the new cartridge, proceed to Contacting Lexmark.
No: Continue to step 6. 6
Power the AIO on, reinsert the color cartridge, and close the top cover. Power the All-In-One off and then on again.
Yes: Power the unit off and try step 6 with another color cartridge. If the error persists with the new cartridge, proceed to Contacting Lexmark.
No: Try printing a test page. If the test page prints, the error is resolved
Oct 28, 2010 | Lexmark X7170 All-In-One InkJet Printer
103 service ITU ERROR
lexmark basically has said that if this error doesnt clear by powering off the machine and powering it back on again then it will need to have a service call. this error means there is a problem with the itu belt assembly.below is what they say. the steps were to pwoer it off and back on again using a grounded wall socket
This error normally requires a service call. However, certain rare occurrences, such as a stray static discharge in the vicinity of the printer or a power fluctuation, can cause a false 103 ITU error message to appear. In these cases, the error is only temporary and can be easily resolved without service. Follow the steps in the table.
Step Action 1
Power the printer off, wait ten seconds, and then power the printer back on.
No:
Print a test page. If the page prints, the printer is functioning correctly. 2
If possible, connect the printer's power cord directly into a grounded wall outlet. In rare instances, a surge protector or uninterruptible power supply (UPS) can generate false error messages.
Yes: Continue to Contacting Lexmark below.
No: Print a test page. If the page prints, the printer is functioning correctly.
Nov 19, 2009 | Lexmark C760 Laser Printer
Error 50 c
  1. Power off your printer.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the printer on. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
Hope this helps.
  1. Lower the scanner unit until it is completely closed.
  2. If you receive the error message again, replace both cartridges.
Jul 29, 2009 | Lexmark X6170 All-In-One InkJet Printer
Action :
3> Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job,.
Mar 15, 2008 | HP LaserJet 4350 Printer
Canon i320
Try unticking ENABLE BIDIRECTIONAL SUPPORT on the Ports Tab under Printer Properties accessed through control panel / Printers and Faxes. Try to print - get error message Enable Bidirectional Support. Reverse back into Ports Tab and re-enable Bidirectional Support and try printing again.
Jan 13, 2008 | Canon BubbleJet i320 Printer
Error Message problem
Try to find anything that prevents the printer form moving the paper or print head. If everything is fine try reinstalling the printer driver.
If that does'nt work... get your printer serviced.
Oct 18, 2007 | HP PSC 2355 All-In-One InkJet Printer
Error message; no printing of text
What application were you trying to print from at the time. Does the printer give this error message all the time or only from this program? I need this info to assist you bzoe...lilacgerry
Aug 30, 2007 | Xerox WorkCentre M940 InkJet Printer
Canon imageRUNNER 3300 All-In-One Laser Printer Logo
470 people viewed this question
old marine
old marine
