27 in.lcd tv ilo power wont come on using remote, or set button?
  • Anonymous Mar 31, 2009
    on power supply modular replaced 3 1000mfd and 3 470 mfd played 2 hours now will not power up
Lcd tv 27inch wide screen, mo. 1lo lct27ha36, no power, power lite stays red, if i hold power on lite just flickers. this type set has no on off pulling the wall plug is the only way to kill the power to the set.
Posted on Oct 01, 2008
No response to any button on remote or tv except power button
Press the 'Favorite' button on the remote. You may have accidentally pressed it. It locks the channel. Pressing again unlocks.
Apr 22, 2009 | iLO 3200 32 in. LCD Television
Screen is blue says composite, no signal.
TRY AND FIND VIDEO BUTTON ON TV REMOTE AND PRESS VIDEO BUTTON. ON THE MENU USE UP OR DOWN ARROW ON REMOTE TO CHANGE FROM COMPOSITE TO ANALOG TV.
Feb 01, 2009 | iLO 3200 32 in. LCD Television
ILO 27" LCD don't start up.
check batteries in remote, does it click back into stand by when u press power button?
Dec 11, 2008 | iLO 3200 32 in. LCD Television
Tried connecting DVD player to ILO 27 in, no go
go to video on your remote, then go to composite... it should work on composite mode. Took us a while, don't feel bad. Hope that works for you.
Nov 14, 2008 | iLO 3200 32 in. LCD Television
Ilo-27 lcd
I CAN,T GET IT TO CHANGE CHANNELS. I DON,T HAVE THE ORIGINAL REMOTE SO I HAVE TO USE A UNIVERSAL AND IT WON,T PROGRAM.
Jan 13, 2008 | iLO 3200 32 in. LCD Television
ILO LCT27HA36 No Manual
This is a very low end low quality made TV set. I would suggest you take it back and see if you can exchange it.
From my experience, I would suggest getting a good quality brand name TV set. Most of the Sony LCD TV sets have earphone jacks, external outputs, and come with a full set of instructions. They are also strongly supported for service during the warranty period.
Jerry G.
Oct 15, 2007 | iLO LCT32HA36 Television
TV WONT TURN ON
try pressing the channel or volume buttons. They turn on the tv as well. Maybe the the remotes might cooperate with the tv.
Jul 22, 2007 | iLO 3200 32 in. LCD Television
Using my universal remote to control my iLo 27" Wide-Screen LCD TV
I have a ILO 27" TV Comcast had no suggestions for programming their remote. I went thru the ENTIRE code book and finally came up with one that worked: Emerson Code #0463 for my COMCAST universal remote.
Jul 14, 2007 | iLO V27DMBX Television
ILO universal remote code
I had the same problem trying to program my satellite remote to work with the ILO tv. I found that the emerson codes DO work. Yes local cable remotes will work as long as you have the code and the brand is getting more popular. The code that worked with both cable companys, Charter and DirecTv was 10171 I believe. You can find it under the Emerson codes. Hope this was helpful.
May 23, 2007 | iLO 3200 32 in. LCD Television
Volume/ channel/ remote not working
I just used the following instructions from this site on my 'totally dead' Ilo remote and it worked like a charm! I did step 2 twice on each key and put the batteries back in and it worked great! Hope this helps you too. "Dead" Remotes Can Be Saved How to Re-Start Your "Dead" Remote Control This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls. Good Luck! Step 1- Pull the batteries out of the remote and leave them out until Step 4. Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once! Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2. (When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!) Step 4- Put the batteries back into the remote, being very careful to install them correctly. New batteries should be used if you're not sure about the old ones. Step 5- Try the remote. If it works, Great! If not, it's time to call 1-800-Remotes or use this website to order a new remote.
Dec 01, 2006 | iLO 2600 Television
Televison & Video Logo
114 people viewed this question
Top Televison & Video Experts
