Question about HP Computers & Internet
I installed a new power supply when i push the power button yhe monitor comes on for 5 seconds and then goes black
    Scholar:
  • 67 Answers
So could you please tell me what exactly was wrong with your previous power supply. I know it wud sound bad to you but sometimes faulty power supply causes permanent damage in your other hardware. So may be try to remove one hardware at a time and try to restart your PC without that hardware. If you would have same problem then install that hardware and try it with another one.
When you start your computer just start with basic hardware i mean only with keyboard, mouse , monitor and power supply.
But before anything please make sure your new power supply is giving right voltage and you have applied all connection. Some motheboard have special 4pin port for your CPU fan and for those motheboard you need a power supply with four pin wire only for ur CPU fan. Make sure your CPU fan is running. If not then you need that power supply
see these images
http://images.google.com/imgres?imgurl=http://www.playtool.com/pages/psuconnectors/12v4pinadapter.jpg&imgrefurl=http://www.playtool.com/pages/psuconnectors/connectors.html&h=365&w=355&sz=22&hl=en&start=1&um=1&usg=__smTu4Xc7VDpTb8XZI8Sm_Yv8AfA=&tbnid=p8hrXAAr7Uog9M:&tbnh=121&tbnw=118&prev=/images%3Fq%3Dpower%2Bsupply%2Bwith%2Bfour%2Bpins%26um%3D1%26hl%3Den%26rlz%3D1T4GFRC_en___CA204%26sa%3DN
If you are not sure please call any computer technician or take your power supply to him to check output voltage.
Good luck and hope it helps !!
Posted on Oct 01, 2008
I have a Westinghouse monitor Model # LCM-19v SL the monitor keep turning off. Unplugging then replugging gets it working then it shorts out again. Can I replace the power Supply cord - Potrans ITE Power...
i also have a 19" westinghouse monitor the screen on mine goes black i just turn the monitor of then back on the problem is it's overheating and from what i understand it's caused by faulty or worn capacitors the ones that are bad are vented on top so it's easy to tell the bad ones. you can see what they look like on line!
Nov 18, 2010 | Westinghouse LCM-19v1 Monitor
Monitor comes on for a brief milla second then
hold the power button for 5 sec : if the picture appears replace the button. ELSE check the chimic capacitor if damadged replace with new
Jun 21, 2010 | Dell E173FP 17" LCD Monitor
Viewsonic VX710 Monitor scrren goes black
replace all caps on power supply board check values
should not cost more than 20 us. and 1 hour soldering
easy fix but new monitor goes around 100 us.
can you do it???
May 10, 2010 | ViewSonic VX910 19" LCD Monitor
Acer LCD monitor goes black after 1 second
More likely to be bad caps (bulging top), look for that first, the caps may be out gassing, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Jan 21, 2010 | Computers & Internet
Acer monitor AL1706 Power On problem
You are more likely to have bad capacitors problem in the power supply, inverter circuits. I would look for bad caps first. Look at some of the sample here: http://s807.photobucket.com/home/budm/allalbums
Jan 02, 2010 | Acer AL1706AB LCD Monitor
Screen goes Black about 1 or 2 seconds after powering up.
you have problem wit the lamp just plug in another once you removed the back cover and if the lamp stays on the it is 100%. you do not need original lamp. Any 15" lcd lamp that fits will do the job. HA HA well done
Ahmad
COMPBITS.COM.AU
Jul 06, 2009 | Computers & Internet
Monitor goes black after 5 seconds but has power.
Power Supply inside the monitor is bad, needs replaced. Compare cost of replace or repair. Usually best to just go get a new monitor.
Mar 17, 2009 | HP Compaq FP5315 15" LCD Monitor
Monitor Issue: 5 seconds of picture the monitor goes black.
I had this similar problem. I found out that there was a bad 1000uf, 16V cap on the power supply board. The cap is too close to a heat sink and over heated. I bought the cap at radio shack for $2, installed it so that it is far away from the heat sink. Monitor now stays on when powered up.
These monitors are difficult to open.
After removing the stand, you need to insert a flat screw driver at the bottom of the screen where two slots are located. Then work the screw driver around until the two plastic pieces are separated. Remove the cover plate and unscrew the push buttons. Unplug the monitor cords from the driver board. Unscrew the mounting screws from the power supply board and remove. You will need to pinch the plastic support in the middle of the board to remove. Unsolder the cap. It is located near a copper heat sink and the value will be on the cap. It will be buldged up on the top. You will see burn marks on the board surrounding the cap. Install the new cap and solder. Be careful not to solder across joints.
Reassemble and turn on. Should solve the problem
Dec 16, 2008 | Computers & Internet
Does a bad power supply look like this?
i suggest that you buy a new monitor coz your current monitor is too old...there's some electric component is weaken...its better to buy new than to repair the old one..
Mar 08, 2007 | Mag Innovision LT776s 17" LCD Monitor
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
