Question about Logitech X-540 Computer Speakers
Centre speaker I just finished setting up my new logitech x540 speakers and after testing it out i noticed that the sound is coming from everywhere except the centre speaker. Also Im noticing that when listening to music im getting the odd popping sound. Can anyone help me out? my sound card is the crative audigy II. any advice is much appreciated. Thanks
  • 728 Answers
Your center speaker is probably busted since you say you here an odd popping noise from it. You will need to get a new center speaker. It is not your sound card unless the same happens if you buy a new center speaker.
Posted on Nov 08, 2008
How to connect laptop speakers logitech X540 5.1 sound to hear
Connect the green (or black) cable to the Headphone Jack
Mar 08, 2011 | Logitech X-540 Computer Speakers
Centre Channel speaker has stopped working
connect any speaker instead of center speaker if you get the same result you will have a problem in amp itself if the problem fixed change center speaker with a new one
Apr 11, 2009 | Audio Players & Recorders
Im trying to connect my Logitech X-530 to my PS3.
You need a digital decoder that is compatible with the ps3 and the speakers.
You would then run a digital optical link from the ps3 to the decoder and the normal speaker cables from the decoder to the speakers.
Decoders can be quite expensive and it can sometimes be easier to buy a set of 5.1s with the decoder either built in or included with the package.
Apr 10, 2009 | Logitech X-530 Computer Speakers
Logitech X540 PC speakers, rear speakers only working; LAPTOP
Goodday remmember that you have to have a 5.1 sound card to be able to use a 5.1 sorround sound system.the 5.1 has more plug inputs to plug all the speaker FRONT REAR and SUB.
Jan 03, 2009 | Logitech X-540 Computer Speakers
Centre Speaker No Sound
i can think of two things., you may need to do the update on your sound card and computer and make sure you have the correct codec's installed or also you may need to go to the web site of the makers of your logitech speakers and see if they have a common solution for this problem...... i also wonder if you should bypass the sound card and directly connect your speaker system to the out put port on your computer ..... give it a try what can it hurt .... if all else fails maybe there is a faulty wire in the speaker system ....... ahy ?
Jul 17, 2008 | Logitech Z-5500 Computer Speakers
How does Logitech X-540 speakers connect to a laptop? Do you connect them through the headphone jack? Do you need to buy any extra cables?
see it is a 5.1 speaker system if your laptop comes with 3 audio jacks with colours green black and pink then all your speakers works if you have only two jacks tht is one jack for audio and other is microfone then u only your woofer and 2 speakers works in speaker cables ther will be two cables connect the green one to green jack your sound plays if u have totally 3 jacks connect the 2nd cable to black one(non microfone jack)check this out this works
May 07, 2008 | Logitech X-540 Computer Speakers
Logitech x540 speakers- rear speakers distorted on matrix mode
I installed my soundcard which is the sound blaster SE audigy but when i try to test the sound i see that it does not sound separately.What i have to do to make them sound saperately when i'm testing it ?
Apr 16, 2008 | Logitech X-540 Computer Speakers
Logitech mm50 very little sound coming from right speaker
Check the cables and see if there is a tear, or unscrew the cover of the speaker (if possible) and see if the contact is frayed or only holding by a couple of wires. This will reduce the sound quality.
If not, the speakers are faulty, and they are not worth replacing. Just purchase a new set.
Dec 31, 2007 | Apple Logitech Inc MM50 Portable Speakers...
Logitech X-540 Computer Speakers Logo
134 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
