Samsung model HL-85086W projection tv
The set will come on as soon as it is plugged into wall outlet. The picture will come on and start working but just for a few seconds and then it seems as the picture is frozen and I can't change channels, turn off or on, the power indicator led is off. The led that indicates reception of remote control signal still works. I do know that the light and power company has been working in the area before this occurred. The sound came on for about the same length of time as the picture. The screen was a full screen. I did notice that after leaving set on for a few more minutes that it tried to move the image on the screen just a little and then immediately freeze again.
SOURCE: Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Posted on Jul 19, 2007
SOURCE: Samsung HL-P5663W, picture goes black after some time
I fixed it. Went back in after a twenty min. break, figured if it's broke I can't break it again, might as well try to fix it(out of warranty, so much time on 1st. bulb, after fixing I found out had 8463 hrs. on 1st. lamp! WOWW most i've seen on any strings out there,and I'm really cheap and inquisitive) But this is how I did it. pulled off covers. looked around pulled light box out checked connectors and resistors visually for burns, none found, then I see a clear plastic sleeve covered group of wires it was plugged up at the ballast where i was working earlier but not the other end, so i looked around for the plug to insert it, couldn't see any where. I felt on top of a silver polished panel w/holes allover, there on top, at the right side of the silver panel was a plug for it. I plugged it in by removing fan and cooling fin assembly, for room to work(and good chance to clean dust from the fins and fans. I tilted silver panel down to see the top, after some removing spring loaded screws holding cooling fins, (the screws ave very light spring tension and won't pop out, I swear, keep track of springs for reassembly later) plugged it in(only goes one way, don't force it, flip over if it doesn't fit nicely) replace all removed parts in reverse order and reinstall covers, plug up, and mine powered on almost instantly. After that and spending 2 hrs. online trying to go through all the strings everywhere about these problems. It came down to trial by fire. I hope this helps, reply if it doesn't.
Posted on Nov 15, 2007
SOURCE: Samsung projection TV intermittent shut-down problem
I just called 1-800-samsung & choose the parts dept.
For the replacement lamp it cost $149.99 plus tax & shipping .
My total was 167.08 for Fl. You give them the lamp code ( red sticker on the side of the tv) , they send it out 5day shipment.Local tv repair services can install it for an installation fee. This will save money apposed to ordering through a tv repair shop who charges an order part fee plus etc...
Posted on Jan 23, 2008
SOURCE: DLP no image at time - no chime - lamp light blink but no image - sometime 3 front panel lights blink
i have the exact same issue.
have you found the cause?
Posted on Apr 02, 2008
quang123
  • 107 Answers
SOURCE: Sony KDF-E50A10
If the lamp is new it could be the ballast the one is supply high voltage for the lamp you can order that ballast from Sony
Check the lamp if is not damage any where
Cheers
Posted on Dec 11, 2008
My 67" samsung tv work well when its on but when you turn off tv and turn back on you get sound and no picture unplug tv and plug in again picture come back on
First thing I would try is to remove set and a box or receiver if used from power for a while and then plug all back up--should reboot all units that way--cannot hurt and may very well help. Not just the set but any unit between signal source and set.
It might also be a good idea to see if when the screen is black if the lamp can be seen--is it on or not?
Dec 12, 2012 | Samsung HL-67A510 67" DLP HDTV
TV stopped working samsung model UA32D5000PM
Check and replace its main system control memory IC. Before replacing it, just make a hard reset to this set. Unplug the TV from AC mains wall outlet, and re-plug it back after 1 minute or so. This must make the set a hard reset.
Sep 01, 2012 | Samsung Televison & Video
Where can i buy a transister for a samsung 50" dlp
you should be able to get any part needed from www.tvrepairworld.com
Sep 25, 2011 | Samsung Televison & Video
Tv shuts off and on by itself dlp 5064 tv only seems to do it when the tv is on for a long period also when the power is on the standby/lamp is illuminated
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. I
Jul 26, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
Tv will not turn on
Check to see if there is a problem with the internal fuse. Your user manual should have a troubleshooting section that will address your particular symptoms.
You should also plug a different appliance into the outlet where your TV is plugged in to make sure there isn't anything wrong with the outlet.
Though this probably isn't the case, I have sometimes seen outlets that are controlled by a wall switch, and sometimes, the wall switch is accidentally turned off.
Jun 20, 2009 | Samsung HL-R5656W 56" DLP HDTV
Snowy picture
.u need to replace the tuner of ur tv set...its a technical work better call service technician
Jun 28, 2008 | Samsung HL-R4266W 42" HDTV-Ready...
567 people viewed this question
jasbo
jasbo
