Question about Admiral Washing Machines
Need to replace the timer - Admiral Washing Machines
  • shelngav Oct 01, 2008
    My washing machine started having problems with the spin cycles. Finally only one of the spin cycles would work. Then that spin cycle became finicky. I had to push on one corner of the collar around the knob to get it to spin. Then it became trickier and more difficult to get it to do it until it no longer will spin at all. I was told it is likely the starter. I opened the control panel and see lots of wires and I am not sure how to unhook the timer to replace it. I was wondering if there was some type of diagram of how to replace it or some visual with instructions that would help, without buying a manual. I have an Admiral Designer Series Model # LNC6759A71
  • john gagnon
    john gagnon May 11, 2010
    hi thanks for the question . why
  • 943 Answers
Hi.. thanks for the question the timer knob unscrews .pull the knob off 2 5/16 screws. remove them timer is free. unplug wiring ,replace timer. thanks the appliance doc
Posted on Oct 01, 2008
Intermatic t10004rt3 pool timer cycles a loud hum/buzz noise like bad contacts or relay
T10004R control center has one T104 240V timer, with extra space for another timer or freeze control etc.
You can clean up the timer and replace clock motor to stop most noises.
The T104M (M for mechanism-only, snaps into the control center enclosure.
The T104 also snaps out of enclosure using thumb spring located top inside box.
Take image of wires before disconnecting from timer.
The T104 is identical to WH40, same parts, same trippers, same appearance, except with different override lever.
Here are photos of WH40 showing how to take apart timer and clean it, also with links identifying replacement parts:
http://waterheatertimer.org/Photos-of-WH40-timer.html
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T104
If you need to replace timer, it is cheaper to buy the ordinary T104 that comes inside a box and can be snapped out, instead of buying T104M (M for mechanism-only)
Gene
h
Apr 10, 2014 | Intermatic Hardware & Accessories
Tries to drain water when its empty.
The timer is out of sequence and will need to be replaced. Here is the new timer you need.
Here is a video to walk you thru the replacement process.
Oct 19, 2012 | GE WBSR3140DW Top Load Washer
Dryer timer will not advance in any mode.. timed, or auto mode. Dryer works, but will not turn off unless you open door or advance timer. Do I need to replace the timer?
the timer will need to be replaced if it's stuck in the mode as you stated. the timer is built with cog teeth gears that rotate slowly as the timer operates normally. If a cog tooth breaks off the timer is stuck in that position causing your problem here
Jul 11, 2011 | Whirlpool LEB6200 Electric Dryer
My ge washer wbvh6240hww wont advance in time
the timer motor on the timer that advances the timer is defective,replace the entire timer as a motor for the timer will be just as much as a timer if its available separatelyanyway
May 16, 2011 | General Electric WBVH6240HWW Front Load...
The timer knob is no longer moving when drying - so the dryer never shuts off. Do I need to replace the whole timer
Yes you will need to replace the timer with a new one.
Timers are not rebuildable
Please rate me
Dec 09, 2010 | Maytag PYE2300AY Electric Dryer
Timer runs backwards
looks like the timer is starting to fail,hope this helps
May 27, 2009 | Kenmore Dryers
How to replace clock in intermatic timer
I need to replace the timer on a model #ML600TW
Apr 29, 2009 | Hardware & Accessories
How to reset lamp timer
Go to the menu and you'll find lamp timer section.
Aug 27, 2008 | Vivitek V37835 46 in. LCD Television
Ge timer on washer is broken
If it no longer clicks, the timer assembly will need to be replaced. If just the knob broke off, the timer should be good.
Mar 16, 2008 | GE WDSR2080D Top Load Washer
Washing Machines Logo
197 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
