Question about Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman Lawn Tractor - 6 yrs old
The right spindle arm (L shaped) has broken closest to the inside of the rim. Due to someone not keeping it greased I'd imagine. I wanted to know a rough estimate of what the replacement part should be.
  • 48 Answers
Just go to sears .com and put in the modle number . youll get the exact price
Posted on Oct 17, 2008
Grease fittings for spindles
Some cheaper mowers don't have grease zirks for the spindle bearings. If you cleaned off the deck and you can't see them, the only thing to do is remove some shields and keep looking, or check with manufacturer details to see if it even has them. A simple call to a craftsman repair shop should be able to answer that question.
May 22, 2013 | Craftsman 20 Hp 42" Deck Lawn Tractor
Grease fittings
I remove spindles,drilled and tap housings for fitting. In middle of housing. Remove inner seals on bearings. Light oil on idlers.
Need to change the spindles on model 917.273220 craftsman tractor
The job is much easier and safer with compressed air and an impact. I would try really hard to find someone with air to borrow but if no air is available then wedge a piece of 4x4 between the blade and deck to keep the blade from spinning. BEWARE, the board can pop out and the spinning blade can be dangerous. Remove the deck from the unit. Remove the pulley first, hold the blade with your hand ( only if you have air/ impact) to prevent the spindle from spinning. Note the washer under the pulley. Then remove the blade, then the spindle bolts. Most AYP replacement spindles now come pretapped but if not place spindle in a vice and use one of the old spindle bolts ( they are self tapping) to make threads in the mounting holes. Then mount the new spindle in reverse order being sure to instal the washer between the spindle housing and the pulley. Again hold the blade with one hand and securely tighten the pulley nut with an impact. Also the unit probably has a blade brake arm and the spring holder is mounted by one of the spindle mounting bolts. Pay attention to its positioning before removal. If you have a heavy duty replacement spindle the notch on the bracket may not fit the new spindle. with a file or grinding wheel enlarge the notch on the bracket to fit.
Nov 25, 2012 | Craftsman Garden
The bolt holding the blades is broken off
Your st bet is to replace the entire spindle assembly.
It's not as cheap as drilling out the old bolt and using an "easyout" tool to remove it, but the outcome is certain.
Better yet do a web search on "137645, 137646 Shaft Kit For 130794 Mandrel, AYP" and you can find the shaft only with bearings.
On Amazon:
Sep 06, 2010 | Craftsman 21 Hp 42" Lawn Tractor Riding...
I have a Craftsman lawn tractor 21.5hp (hydro stat. trans.) I've noticied a small loss of power over a few yrs. Now I have no forward gear at all, I still have reverse, fluid level is up no sign of loose...
If you had included model no. I could have been more help but you probably will have to replace drive plate and or more in transmission. If you go to and in model number type in, hopefully you will get parts breakdown of the transmission showing parts.
Oct 22, 2017 | Craftsman 20 Hp 42" Deck Lawn Tractor
My YS4500 (3 yrs old) has recently been loosing power in the hydro transmission. The engine runs great, but the drive stinks. I have to ease it into drive and as it gets going it will pick up speed, but if...
Yes, what I believe you have, is a loose drive belt. this can be due to several things,1st, the drive tensioner spring may be broken, 2nd,the drive belt tensioner pivot arm may need lube, or the belt is worn out.
You did not mention the hydro making noise(whining) if that were the case i would have you check to see if the brake were sticking.
Sep 23, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Steering is difficult....
Put some grease in the grease fittings located on the steering knuckle using a grease gun.
May 13, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Hi. I have a 19.5 HP Sears Lawn Tractor, model # 917.270821. The problem I'm having is with the steering in that it has become increasingly more difficult to steer. I greased the two fittings with a tube...
jack up front of tractor and remove clip at top of spindle move steering wheel back and fourth to get spindle to slide down clean and grease then reassemble this will fix most of them unless you have a bushing priblem you will see when removed .
May 12, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Loud screech noise from deck area
This can be due to a belt slipping or a bad spindle bearing.
And on the difficulty scale,10 being extremely difficult, The belt would be a 1 or 2 and the spindle about 6 or 7 (because the deck usually needs removed for this job)
Apr 04, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Can't get front wheel back on lawn tractor Craftsman 52-inch
Make sure you are putting the wheel on the right way. The rim may be off-set. The longer part of the hub should be on the inside.
Jan 29, 2009 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Craftsman 20 Hp 42" Deck Lawn Tractor Logo
145 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
