Rca tv power button turns tv on, but sometimes it works immediately and sometimes it turns the tv on after a while later when you are not pushing the power button
    Champion:
  • 252 Answers
Your power button is in trouble so , change it with a new one.
Posted on Oct 01, 2008
How can I program my RCA universal remote to my element tv , what button to press for the light to blink and the code to put so it can work on my tv
RCA does not have for a code Element TV. With that being said there is a work around:
Turn on your TV.Then push the code search button until the LED still ,when the LED keeps on let go the button now push and release the TV button then push and release the power button until the TV goes off, when the TV turn off stop to push the off button now push the set button the code are already set on the remote control( you might have to push the off button almost 100 times or more until you get the right code for your TV. Best of Luck
Aug 26, 2015 | RCA Televison & Video
RCA LCD TV gets stuck on one channel
sounds like you have an intermittent defective main board. ebay rca model for replacement board.
Jan 11, 2015 | RCA Televison & Video
Power button on my rca tv wont turn on sometimes
A number of possible reasons for this---failing part in set or even bad connections on main board in the set----model listed is prone to going dead with high pitched squeel etc.
Oct 31, 2012 | RCA TruFlat 27F520T 27" TV
RCA P56950 Powers on then 10 mins later powers off, repeats cycle. Then channel display in TV changes by itself
may be some thing is stuct on the controt pannel power button or others check. try this it may work
Jun 04, 2012 | RCA P56950 56" Rear Projection Television
We have the RCA HD52w59 projection tv. The tv shuts itself off at different intervals. It takes approximately 1 minute to be able to turn the power button back on, however, I have to do that many times...
A problem in the deflection board. Could be a Cap. Resoldering the deflection board may take care of the problem. You need to call a TV man to do this kind of work.
Best of luck
Nour Sabre
WWW.AAATVSERVICE.COM
Jul 28, 2011 | RCA HD52W59 HDTV Projection Television
My 52 rca hdtv takes a while to turn on.. I push the power button a view times to turn on. sometimes it takes 20-30min to turn on. whats wrong with the tv, and is this an easy fix..
Depending on the model of the TV some projection TVs have a soldering problem. There could be a short on the Main Power Supply. It maybe necessary for a professional to do this work if you don't have the tools or if is not soldering issue.
Apr 30, 2010 | RCA D52W19 52" Rear Projection Television
CHANNEL CHANGES BY IT SELF.POWER WON'T TURN OFF.
I would suspect it has bad switches at the front panel behind the push buttons. If it is an RCA or GE tv, change them all at one time. They aren't expensive and will avoid later problems.
Oct 14, 2009 | RCA Televison & Video
RCA 27v520t will not turn on
That's because somehow the lightening caused a fault in the power board.
Ypu can try an unplug for 2 hrs and then reconnect and start again If that dosn't work you will require intevention to replace the power supply
Aug 17, 2009 | RCA 35V432T 35" TV
1999 RCA mm36100 TV The buttons on the front panel are all messed up sometimes they work and sometimes not. The menu keeps popping up from time to time randomly and sometimes runs though the menu items all...
Bad push button board, best thing to do is just unplag the board and use remote to operate TV, board is mounted under front cover where button are.
Aug 09, 2009 | RCA MM36100 36" TV
36 inch RCA 36v430t
Mike-It looks like the power supply is going on your tv-it can be replaced. This happens, usually, when little kids are playing wth the remote or power button on the tv. Turn it off and on a whole bunch of times in a row, kids love to do that, and it burns out the power supply part- to make a CRT tv like your RCA36 incher- which is a beautiful machine- I have the RCA/PROSCAN 36 incher-LAST longer...You should always wait 5 min between turning it off and on. Don't ever sell it. This one is worth fixing. It has better color and sound Than the new plasmas and lcds-The Pros know this. Be carefull, they might try and talk you out of it-so they can fix it and have it for themselves. So what if it's not High Deff. It's a great set.
Jul 02, 2008 | RCA F36650 36" TV
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
Electro Med Services...
