Rank: Wiz
Rating: 83%, 189 votes
hi there,
sounds the pressure switch is not sensing the water level, so the machine thinks it's still filling. check the pressure switch and pressure switch cable. it's most likely just the cable itself. the pressure switch is located behind the drum and accessible through the back panel.
Comments:
Oct 01, 2008
- yes, it still does. the older Maytags were mostly mechanical, as opposed to electronic. the pressure switch looks like a small metal box and the wire is probably about 3 ga maybe smaller. some of the older machines actually have the cable attached to it.
