Windows tries to configure photo gallery and Microsoft .net framework pops up and tells me an unhandled exception has occurred in a component in my appliciation. Click continue and appliciation will ignore this error and attempt to continue. Object refrence no set to an instance of an object.
    New Friend:
My own assessment concurs with Joe Diaz's because the OS's, Reader Versions and web browsers are identical on both desktop computers. The stack seems to point to .NET Frame. The latest version is 4.0. One computer may have a different version. I'll will check that and try the fix. I won't know if it works until I do. Thanks Joe.
Posted on Apr 01, 2013
  • 4,338 Answers
Cancell out the install. It will take several time, but it will stop.
Then:
Go to Microsoft's web site and download the newest version of .Net Framework. I believe 3.0 is latest.
Please remember to rate all users who assist you for free :)
Posted on Oct 01, 2008
Fatal error unhandled c00000fdh exception at 30119435h in autocad 2011
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Fatal-Error-Unhandled-Access-Violation-Reading-0x0000-Exception-at-bcbdad73h.html
Fatal Error while opening AutoCAD Dec 05 2014
Applies to AutoCAD 2009, AutoCAD 2010, AutoCAD 2011, AutoCAD 2012, AutoCAD 2013, AutoCAD 2014, AutoCAD 2015, AutoCAD Architecture 2009, AutoCAD Architecture 2010, AutoCAD Architecture 2011, AutoCAD Architecture 2012, AutoCAD Architecture 2013, AutoCAD Architecture 2014, AutoCAD Architecture 2015, AutoCAD Civil 3D 2009, ...
See More
Issue:
While in the process of starting AutoCAD , a Fatal Error occurs.
Causes:
Fatal errors usually indicate program corruption or a corruption somewhere within the operating system.
Solution:
There are several ways to address the problem: Note: A fatal error can be caused by DisplayLink Core software. If you have this installed on your system, try uninstalling it and then see if this resolves the issue. Additionally, some antivirus or desktop locking programs can cause errors in AutoCAD as they lock the system environment from working. Your antivirus may even need to be uninstalled.
Sep 16, 2010 | Autodesk AutoCAD 2010
When inserting a raster images, receive the "FATAL ERROR Unhandled Access Reading 0x0000 Exception at 10b0961eh" message.
See More
Issue:
Causes:
Solution:
If all of the above solutions fail to resolve the issue, and a full uninstall and reinstall of AutoCAD does not help (see Remove All Products from a Windows System), then you may need to reformat your hard drive and reinstall the operating system.
Article ID: kA230000000tTXu
Sep 15, 2010 | Autodesk AutoCAD 2010
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.ArgumentOutOfRangeException: Cannot anchor...
Not sure whether this is a Q.
To enable just in time (JIT) debugging, the config file for this application or machine (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: <configuration> <system.windows.forms jitDebugging="true" /> </configuration> When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the machine rather than being handled by this dialog.
In VS the way to enable/disable that is: 1-On the "TOOLS" menu, click Options. 2-In the Options dialog box, select the Debugging folder. 3-In the Debugging folder, select the Just-In-Time page. 4-In the Enable Just-In-Time debugging of these types of code box, select or clear the relevant program types: Managed, Native, or Script. To disable Just-In-Time debugging, once it has been enabled, you must be running with Administrator privileges. Enabling Just-In-Time debugging sets a registry key, and Administrator privileges are required to change that key. 5-Click OK.
It has to be done by the developer and its his responsible to guide the application error reporting to the system event handlers. If this is an issue which occurs in a certain app, have to check for the .net version (specially in vista). Many 1.0 and 1.1 based apps give the problem. To install dotnet fw 1.1 on Vista will give an error. Most of the time caused by DEP (Data Execution Prevention). But the thing is some software forces the installation of .net framework (older versions). How ever Vista is packed with .net 3.0 and 2.0. Even if you allowed to install will not be able to uninstall 2.0 (possible to remove 3.0 though).
How to solve the installation issue: This issue is resolved in Microsoft .NET Framework 1.1 SP1, however you will need to use the following procedure to install both the .NET Framework and the Service Pack at the same time: Download Microsoft .NET Framework 1.1 Redistributable Package and Microsoft .NET Framework 1.1 Service Pack 1 using links below: Dotnet Framework 1.1 Redest Dotnet Framework 1.1 SP1
Save both installations in the same directory Ensure that the Microsoft .NET Framework 1.1 Redistributable Package is named dotnetfx.exe. If not, change its name to dotnetfx.exe. Ensure that Microsoft .NET Framework 1.1 Service Pack 1 is named dotnetfxsp1.exe. If not, change its name to dotnetfxsp1.exe. Open command prompt as Administrator, and change to the directory where the two installations are saved. Run the following commands using the order shown below dotnetfx.exe /c:"msiexec.exe /a netfx.msi TARGETDIR=C:dotnet" dotnetfxsp1.exe /Xp:C:dotnet etfxsp.msp msiexec.exe /a c:dotnet etfx.msi /p c:dotnet etfxsp.msp Install both Microsoft .Net Framework 1.1 and Service Pack 1 by running C:dotnet etfx.msi
The systems must be backed up before trying this specially the system state. How ever the keys can be repaid in a damage This thread will also be helpful http://blogs.msdn.com/b/astebner/archive/2007/03/26/how-to-repair-the-net-framework-2-0-and-3-0-on-windows-vista.aspx...
May 29, 2010 | Dell Studio XPS 16 Notebook
FixYa Expert Utility - .Net Framework unhandled exception
try to uninstall the latest update of the .Net framework and then download and install again.
in most cases it will solve the problem
Apr 04, 2010 | FixYa Service
.netframework unhandled exception error
Hope this might give you a rough idea..... i think there is a way in which we can make the program not to show any error when any error occurs in the program that we write...,
the code for that would be something similar to
.NET CODE
"On error Resume Next"...
Oct 05, 2009 | Computers & Internet
Unhandled e0434f4dh Exception at 7c812a6bh. cannot run AutoCAD software.
Try to uninstall any version of .NET framework installed on the system and install latest version of .NET. You can try to install 3.0 version.
Oct 01, 2009 | Microsoft Windows XP Professional
An unhandled win32 exception occured in svchost
Windows error from some component of your browser most likely. Try reinstalling the web browser (and rebooting if it's Internet Explorer).
Apr 07, 2009 | Computers & Internet
Error 1935 occured during installion of microsoft office
This issue may occur if a Microsoft .NET Framework file is being used when you try to install Office 2003. For example, this issue may occur if the Mscoree.dll is being used when you try to install Office 2003.
To work around this issue, restart the computer. Alternatively stop Windows Installer.
If these actions do not resolve the problem, repair the existing installation of the .NET Framework. Alternatively troubleshoot .NET Framework installation issues.
For more information about how to restart the computer and about how to stop Windows Installer, click the following article number to view the article in the Microsoft Knowledge Base:
308096 (http://support.microsoft.com/kb/308096/ ) BUG: Error 1935 during install of the .NET Framework For more information about how to repair an existing installation of the .NET Framework and about how to troubleshoot .NET Framework installation issues, click the following article numbers to view the articles in the Microsoft Knowledge Base:
306160 (http://support.microsoft.com/kb/306160/ ) How to repair an existing installation of the .NET Framework 824643 (http://support.microsoft.com/kb/824643/ ) How to troubleshoot Microsoft .NET Framework 1.1 installation issues in Windows XP or in Windows 2000 For more information, click the following article number to view the article in the Microsoft Knowledge Base:
926804 (http://support.microsoft.com/kb/926804/ ) Error message when you try to install a 2007 Office program: "Error 1935. An error occurred during the installation of assembly component" APPLIES TO
  • Microsoft Office Small Business Edition 2003
  • Microsoft Office Standard Edition 2003
  • Microsoft Office Student and Teacher Edition 2003
  • Microsoft Office Professional Edition 2003
  • Microsoft Office 2003 Personal Edition
  • Microsoft Office Basic Edition 2003
Please donot forget to rate these suggestions.
Mar 19, 2009 | HP Pavilion dv2000t Notebook
AiOsoftware
That is software for your HP All-in-One printer. Try reinstalling the software for your printer and it may go away.
Mar 26, 2008 | Microsoft Windows XP Professional for PC
Computers & Internet Logo
106 people viewed this question
David Payne
David Payne
