Question about Zenith Z46Z83D 46" Rear Projection Television
Zenith tv power button does not turn tv on
  • barbjones16 Feb 10, 2009
    my tv wont come on when you mashes buttons or remote since electrical socket problems.
  • Zenith Master
  • 5,138 Answers
There is alot of reasons as to why set will not come on you need a repairman.Check ac fuse see if it is ok., which i dout but you might get lucky .
Posted on Oct 01, 2008
I have a Z42PJ240 42 in. Zenith Plasma television I canno.v.t find anywhere to manually power on the t
hi the power button might be underneath the tv or a touch screen panel
Apr 21, 2014 | LG Z42PJ240 42 in. Zenith Plasma TV
Samsung AK59-00123A remote to a M261VP vizio tv
[1] Switch your television on
[2] Point the remote control towards the
[3] Press and hold the TV POWER button, and
then enter the two-figure code in the table
to the right that corresponds to the brand of
your television by pressing the appropriate
number buttons.
If your television is compatible with the remote
control, it will switch off.
The remote is now programmed to operate
the TV.
The code for Zenith TV is [TV POWER + 63]
Sep 20, 2011 | Zenith ZEN700 Remote Control
Tv wont turn on... light blinks yellow as if its going to power on.. and just shuts off... for my zenith dlp 52 inch tv
I had this same problem. The Zenith rep told me to unplug the TV, hold the power button down for 30 seconds, plug it back in and then turn it on. It worked and I haven't had a problem with it since. I hope this helps. Good Luck!
Mar 06, 2010 | Zenith D52WLCD 52" Rear Projection...
The Zenith Digital TV Converter DTT900 needs reprogramming
1) While pressing & holding down the TV POWER button, press CHANNEL UP or CHANNEL DOWN repeatedly until your TV is turned on or off. 2) Release the TV POWER button when your TV is turned on or off. *Each press of the channel button sends a manufacturer code (1-45) to your TV, one after the other. Note: You may have to do this every time you change or remove the battery, as the remote will reset itself to the default code.
Nov 25, 2009 | Televison & Video
Need instructions to add TV button to AKB36157102
1. While pressing and holding down the TV POWER button, press the CHANNEL UP or CHANNEL DOWN repeatedly until your TV is turned on (or turned off if you had it on). 2. Release TV POWER button when the TV turns on or off. The remote's TV POWER button will now control the TV.
Jul 19, 2009 | Televison & Video
How to program
I could not find the code for my Sharp TV but the Code Search Method Worked.
1. Manually turn on the TV
2. Press and hold the Power and Mute buttons until the red light remains on.
3. Release the buttons.
4. Press the Power button to begin the code search.
5. Press the Power button repeatedly until the TV turns off.
You might have to press the button 100 times or more to find your code.
6. When the TV finally turns off, press and release the Mute button to save the code.
Jul 18, 2009 | Zenith ZENSP Remote Control
Zenith remote will not work tv, need code
hello here is how you get your remote to work...make sure tv is on
step 1.hold down code search button till you see the red light
step2. let go of code search button and hit TV once light should blink
step3. press and release the power button while pointong a TV u ((may have to press the power button several times)) once the Tv powers off press the enter button once
step4. press tv button and hit power
May 16, 2009 | Zenith DBZN-311 Remote Control
Zenith TV
automatic code search. this may take a while to do but it works. hold the directv button and tv power until the red light stays on. while its on press the channel up button (this will search for a code). release and test with the tv power button. if the tv does not turn off, press the channel up button again and test with the tv power. when the tv finally goes off, press the enter/last button (bottom right corner of the remote) to store the code
Aug 31, 2008 | Philips DSR708R DirecTV / TiVo DTV...
I need a code for an older zenith tv 13"
Here is what is called a power scan. It will go through all the codes in the remote and find the right code for your tv.
1)hold down tv button next to sat button in top left corner
2) when all buttons illuminate press 500 into remote
3)press pound sign
4)Hello, please help..
5)hold town tv button again.
6)when all buttons illuminate press big red power button
7)press up arrow once a second until tv shuts off
8)press # pound sign
9)try to turn tv back on w/ big red power button
10)if tv doesnt turn back on try again from step 2 but use down arrow instead
Aug 01, 2008 | DISH Network IR Remote Control
Tv will not turn on after sudden power outage
you most likely blew a fuse the only "reset" is to unplug the t.v. and leave it unplugged for a few mins, then make sure that you hold down the power button to drain the power out of the t.v.then turn it back on.... only other reset sequence is for removing the parental code
Jun 24, 2008 | Zenith C27A24T 27" TV
Televison & Video Logo
99 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
