Question about Motorola Mobility PEBL U6 Cellular Phone
My battery broke so I ordered a new one. As soon as it came I put it in and used it for a day. Since I just got it it died quickly, so I went to charge it and it said on the screen "unable to charge." I didn't know what to do so i ordered a new battery and got it for free because I said my old one was broken. I repeated the same process and when it died, I charged it. Once again it said "unable to charge." How do i fix this problem?
    Genius:
  • 2,035 Answers
This not the problem with battery you need check the changing pins in the mobile , they may be defective you need to replace them get it done by the company if your phone is still under warranty ....
Posted on Oct 01, 2008
Why are the batteries dying so quickly in my Kodak 12MP?
The main complaint against compact digital cameras used to be battery life. This was in the days when a 4 or 6MP would have been top-of-the-range.
The life of standard zinc-carbon batteries could be measured in minutes rather than hours and decent alkaline batteries might last the duration of a wedding but might not.
Manufacturers rushed to produce better batteries to meet the booming new market and the camera manufacturers began fitting rechargeable lithium batteries as standard in basic and lower cost cameras and with further developments in technology batteries now last much longer.
Leaving the batteries fitted into the camera when it wasn't being used didn't help much as the circuitry had to be kept alive to retain the settings.
Your camera might have a fault causing the batteries to discharge quickly but if it is working ok, probably not. If you have long experience with your camera and it has suddenly started costing lots of batteries it might be a good idea to update it. It has certainly been many years since Kodak cameras had the reputation for quality...
Meanwhile I suggest you use only high-capacity lithium batteries and remove them when the camera is not going to be used for a while.
Feb 28, 2015 | Kodak Cameras
It depends, if you are using regular Alkaline batteries, those are known to go dead really fast. Better if you try some rechargeable batteries with a rating of at least 2100mAh, anything smaller than that will drain just as quick as Alkalines.
Feb 28, 2015 | Kodak Easyshare C182 12MP Digital Camera
Battery completely drained after 45 mins of listening to cd player without car running,
a healthy battery will take a charge and discharge and be o k -you have several things going on-the ticking noise is some kinda rely that is turning on and off probably because of low voltage-the voltage jumping around sound like the alternator is giving up and is not fully charging battery-you may also have a drain on the battery that doesn't stop when you turn the key off like an extra power amp for the radio- you can take your car to autozone or advanced auto and they will check out the charging system for free and tell you what is going on-cheers Denny
Nov 23, 2013 | Cadillac DeVille Cars & Trucks
I purchased a new battery for my Toshiba Satellite L505D-55983. The second time I turned it on it went as far as the desk top and then shut itself down.
as soon as you turn your coputor on it f1,if your battery is any good you should get in stroll down to start windows normally the programs you had should reload and it should be the way you left it. if doesnt work go trough the same proedure but hit f8 restore your computor to factory condition or restore it the day before it broke just follow instruction .you have a drop down menu with your name on it or the ststem itll ask for a password that would be the same as you use to get inthe computor be patient if its done right it take time to configure your windows .if computor doesnt turn on than the new battery is not any good
Nov 26, 2011 | Computers & Internet
Alternator went out while driving 1998 town and country van,,,in order to get off the highway had to drive untul it completely died ,,van was jerking and the service soon engine light came on ,,as soon as...
I'm thinking you disconnected a wire putting in the alternator, or vacuum line.Try removing the negative cable on the battery for a while, as you check those connections.
Apr 06, 2010 | 1998 Chrysler Town & Country
Water
Sometimes when electronics are dropped in water, you can still use the. Circut boards have a silicon coat over the circut boards for instances like this. Depending on how long it was in the water, you may be able to still use it. Let the phone dry out for about 24 hrs (take out battery and back cover) then try to replace the battery and start it back up. If it doesnt turn on the circuts were affected and it broken.
Jun 24, 2009 | LG Vu CU920 Cellular Phone
My K800i battery dies very quick
Dear Friend,
                 U are saying that u have bought this mobile 2 yrs back so check wither ur battery has been expired and change it.Otherwise switch off ur mobile and put it in charge and check it out the normal standby for any mobile is 2 to 3 hrs.Kindly check it and revert back
Regards,
Aysaam
May 06, 2009 | Sony Ericsson K800i Cellular Phone
Everything works but the touch screen.
caring for the touch screen includes touching the screen with clean and DRY hands., if your phone fell in the water, it will likely damage the touch screen.. contact your nearest LG repair center.. i hope your phone will soon be fine..
May 01, 2009 | LG Vu Cellular Phone
BATTERY WENT DEAD, CLICKING WHEN TRIED TO START IT. PUT NEW BATTERY IN NOW R WINDSHIELD WIPER WONT GO OFF AND AC WONT WORK
battery went dead because the rear windshield wiper didn't go off during the night, as soon as you put a new battery, the wiper start to working and won't stop. probably the switch out of order, A/C doesn't work, check the fuse.
Jul 27, 2008 | Dodge Grand Caravan Cars & Trucks
Motorola Mobility PEBL U6 Cellular Phone Logo
149 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
