Question about HP DeskJet 5550 InkJet Printer
Printer Spooler service!
I am trying to install my printer but I keep getting a message that says "The printer spooler service is not running". Can you please help me fix my problem? Thank you!
spooler service not working Printer Spooler Service not working SPOOLER SERVICE NOT WORKING
    Novelist:
  • 169 Answers
Click on "Start, Run", type "services.msc"
On the right side of the services window, scroll down to "Print Spooler". Double-click it.
If startup type is "disabled", click the drop-down and set to "Automatic" and then click "Start". If already on automatic, click "Stop" to stop the service. Once stopped, click "Start" to restart the service.
Reboot and try again :)
Hope this helps - remember to rate!
Posted on Oct 01, 2008
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 23 Answers
** Spooler Problem fixed **
I had the same Problem before and now I have it solved help of this follwoing article please click below and follow their mentioned steps and get your problem fixed.
Click here to open solved Solution for this problem How to repair Print Spooler (Solved)
http://www.techsupportall.com/print-spooler-is-not-running/
Posted on Mar 08, 2013
ohms
  • 1879 Answers
SOURCE: Printer Spooler service!
click on the start button -> run -> type services.msc then hit OK
look for Printer Spooler and make it run
Posted on Jan 03, 2008
Go here.
Posted on Jun 27, 2008
  • 202 Answers
hi,buddy
you have to start printer spooler by this.
click "start btn"
click on "run"
write here "services.msc"
double click on "print spooler"
select status type "automatic"
than click on "start"
now install your printer.
Posted on Jul 27, 2008
hemantraj
  • 638 Answers
to make spooling work its necessary to make it work
this is the procedure .if you do this it will work properly. till it is not done it will just ignore printing
1)click the start in the left sice of your computer screen
2)go to control pannel
3)click performance and maintainence
4)click system
5)click data execution prevention
6)turn on DEP for essential windows program and services only.
7)click the spooling services a tick mark sign will appear beside that means it has enabled.
now your printer will work properly.
pls do rate the solution if helped. thanks.
Posted on Aug 16, 2008
  • 5 Answers
That doesnt work for me as soon as i go to install the printer again, the window pops up and says the spooler is not working causing the download to quit before it starts....
Posted on Sep 13, 2008
The print spooler service is not running.
Reinstall the printer drivers will shore it up quickly the spooler has to do with the printer so do that and you should be fine.
Apr 23, 2009 | HP OfficeJet 4215 All-In-One InkJet...
"Error 1068 Could not start the Printer Spooler on local Computer"
I appreciate the opportunity to help you. Try the following:
Check dependency services on Print Spooler
1.Click "Start", input "services.msc" (without quotation marks) to Start Search bar and press "Enter".
2.Double click the “Print Spooler” service.
3.Choose “Dependencies” Tab and remember the services name.
4.In the service list window, find the dependency services and try to start them.
5.Please try to start the “Print Spooler” service again.
See if this helps. If it does, please fill in the rating of my service to you. Thanks for using Fixya.com
Jan 27, 2009 | Office Equipment & Supplies
This will provide you with the most common default settings.
  1. Restart (reboot) your system [to assure a clean reinitialized starting point].
  2. Log on as any Windows user that has 'administrator' privileges.
  3. Open your 'Services' console [Start button > Run... > type "services.msc" (without quotes), then hit 'Enter'].
  4. Locate, then open "Print Spooler" [double-click it OR right-click it, then choose "Properties" from the context menu].
  5. Modify the settings on the "General", "Log On", and "Recovery" tabs according to the following images.
"Today's the best day of my life...and NOW you're part of it!"
Dec 11, 2008 | Lexmark E120 Laser Printer
HP Laser Jet 1018 printer problem
To start the service:
  • Go to your Control Panel -> Administrative Tools -> Services
  • Find the Printer Spooler service
  • Right click it and choose Start and wait for the service to start
To make sure it is automatically turned on the next time you run your machine:
  • Right click the Printer Spooler service and choose Properties
  • Select Automatic under Startup type and hit the Apply button
Note: You will need administrator privileges to run those steps.
Oct 26, 2008 | HP LaserJet 1018 Printer
1) Click the Star>Run, type in "Services.msc" in the Run dialog box.
2) A services window popup, find the service name "Print Spooler", double it and change the Service Status to "Start".
Now u can use your printer now.
YBC (/\)
Aug 04, 2008 | HP LaserJet 1018 Printer
hi,buddy
click "start btn"
click on "run"
Jul 27, 2008 | Lexmark Z645 InkJet Photo Printer
click on start ..RUN.....type cmd......type sc config spooler depend= RPCSS......click on start ..RUN......type services.msc.......look for ptrint spooler......it will be started if not then double click on print spooler and click on start.
Now try installing the printer.
May 31, 2008 | Lexmark X4270 All-In-One InkJet Printer
Dec 25, 2007 | Epson Stylus CX4600 All-In-One InkJet...
HP DeskJet 5550 InkJet Printer Logo
307 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
