Question about RCA D61W20 61" Rear Projection Television
RCA D61W20 has become a big useless decoration
The t.v. began acting up a month or two ago, we had a problem getting it to turn on, it would make a loud squealing noise then turn on after a few minutes, next instead of making the squealing noise when turned on, you could hear the tv but no picture for a while. Next problem and the current issue is the picture is continously going out (horizontal lines running vertically on the screen) more or less flickering, you can see hints of the picture behind the flickering but barely. The only way I have been able to get it to stop is by either continously changing the channel until it stops or by switching between the inputs.............HELP please.... what is the likely culprit? Oh it's a 2004 I believe
  • RCA Master
  • 5,138 Answers
I know exactly what is wrong with your TV I charge 315.00 in my shop to repair here i get paid 0$$$$
I get paid $50.00 up front to look at set and then determine what the problem is Defection board 125.00 plus 190.00 labor - 50.00 repair cost 265.00 plus tax SSB board 325.00 plus labor/ wondering can you solder if so start out by resoldering everything on Deflection board solder all pinns on Flyback transformer squealing noise is caused by coil in high voltage area LL037 resolder it then take glue gun and glue on top and around it. all so check second ribbon connector that feeds over to SSB board make sure it is installed good and there is 3 capacitors that go bad on same board 2200uf 16v two 220uf 35v located in front of board they are green with gold writing you can try all of this or order new Deflection board 1-800-648-6657 union electronics's
Posted on Oct 01, 2008
My rca d61w20 rear projection television will not turn on. green light indicator will come on for 5 sec. then go out. any ideas?
Replace the CP150, CP120 and CP114 capacitors you can get the RCA repair kit by that same name from www.tvrepairworld.com which contains the caps and the CD with instructions.
Feb 17, 2011 | RCA D61W20 61" Rear Projection Television
D61w20 rca turns on and off
I have a RCA D61W20 chassis ITC222, I had the same problem and my repair guy found out the blue bulb was the main problem, along with replacing some transisters on one of the power boards, He also had to adjust the service convergence (not auto convergence). Works great now!
Aug 27, 2009 | RCA D61W20 61" Rear Projection Television
Trouble turning on RCA D61W20
the green light blinks three times but does not come on
Aug 16, 2009 | RCA D61W20 61" Rear Projection Television
D61W20 RCA 55in
most probable solution is to replace the flyback 259296 you can get one at the fllowing link with free instructions
http://servicemanuals.vstore.ca/
Feb 26, 2009 | RCA D61W20 61" Rear Projection Television
New Problem with RCA D61W20
Donna, the 52 and 62 inch are both ITC222 chassis so the parts are the same for both models. Did the solder get shorted when you instaslled it or perhaps the HOT was shorted, as usually only a dead short will cause that type of arching. If it didnt burn a hole through the circuit board, the board should still be salvageable. Please respond to this same post and let me know wether the board is burned through our not.
Jul 08, 2008 | RCA D61W20 61" Rear Projection Television
Rca 61 inch not working properly
The vertical heigth is too high. whats the model number of your set?
Jun 12, 2008 | RCA D61W20 61" Rear Projection Television
D61W20 RCA TV 1080i image problem
Theres most sistem pal/ntsc not a set of this menu seting www.wehot.biz
Jun 06, 2008 | RCA D61W20 61" Rear Projection Television
D61w20 big screen tv
You will need the service manual to be able to properly align the new tube after installation, that will also give you important info such as discharging the old tube as well as removal instructions. Post the chassis number on your set and I can post the link to get a good service manual if you would like. rca are crossed by chassis number that should be located on the tag next to the model number
Mar 20, 2008 | RCA D61W20 61" Rear Projection Television
RCA D61W20 61" Rear Projection Television Logo
198 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
