Question about Maxon MCB-30 40-Channels Base CB Radio
When I Press the mic to talk, others hear me key down, but no sound is transmitted
I have a Maxon MCB-30. When I push the button to talk, the TX light lights on the unit, others say they hear a click, but my voice is not transmitted. I can hear them fine, but no sound comes through to others. Any ideas?
Thanks,
Chuck
  • lummox30 Nov 08, 2008
    I did check the mic in the end. There was a broken wire which I repaired. The unit is working now. I just hope the repair lasts.
    Thanks for your help though, I appreciate it.
    Chuck
    Genius:
  • 1,139 Answers
Hello lummox30,
Check you mic first to see if it is indeed working. Then if it is the below advice is applicable.
It sounds as if your TX audio amplifiers might be malfunctioning or the TCXO might be bad. If you have a background in Electronics I would suggest that you open up the unit and using a dummy load on the antenna check the two TX audio amps to see if when you key the mic and speak into it the amplifiers are amplifying your voice and sending it to the modulator. If the problem is not amps or the filters in between the amps, the modulator and the VCO buffer are suspect. If the TCXO is being modulated I would check the PPL IC and the Drive amp to see if the modulated signal is getting through. The last two checks I would perform are on the final amp and the TX switch prior to the antenna jack.
If you do not have a background in electronics, still check your mic, but the rest of the above advice can be done by a qualified Radio Technician.
I hope this helps,
Thank you,
Shuttle83
Posted on Nov 03, 2008
How do i increase the modulation on my maxon mcb-45w
RV 101 SQ RANGE--RV 201 AMC ---RV 202 TX MTR ---- RV401 RX MTR --- Q7 AMC DEFEAT
Sep 19, 2014 | Cinema 4d Maxon MCB 45W CB Radio 120...
It will not transmit or recevie i get a little static on the weather channle but nothing on the cb i can here the mic key up when i have my other cb on but that is all.
there may be an issue with the mic. The mic is required for receive. there may be some broken wires in the cord for the receive and mic.
Try a different mic.
Mar 31, 2010 | Maxon MCB-30 40-Channels Base CB Radio
Hello there, I have the maxon mcb 30 and I have lost the mic. Do you know what kind of mic I must use to work good?
Try the stock mic from cobra, the regular 4 pin mic, its a great mic..... enjoy.... hope this helps....
Mar 13, 2010 | Maxon MCB-30 40-Channels Base CB Radio
Display lights up. very,very low audio.no squelch tx light lights up when keyed. no tx
Sounds like the voltage regulator is failing. Ship it in to me for service at Dodgem250.com
Oct 12, 2009 | Maxon MCB-30 40-Channels Base CB Radio
Meter Shows Signal, no noise
when you have no RX or TX at the same time, that most often means the pre-driver audio transistor is bad.
Thanks,
Dodgem
http://dodgem250.angelfire.com
May 06, 2008 | Maxon MCB-30 40-Channels Base CB Radio
SL55 Not Transmitting/Recieving
the two radios are on different CTCSS Tones
Feb 01, 2008 | Maxon Radio SL55, SP130, SP140, SP150...
Earphone/mic for Maxon 27MCB radio
I recall the combo unit as I used to sell them. I am about sure they are no longer avaidable. You never know, you might see something on ebay/auction sights that might be to your liking. Good Luck.
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Maxon MCB-30 40-Channels Base CB Radio
Squelch when keying ptt
I would check my ptt wiring making sure the button is set so that when you push it it switches you from RX to TX. If you have a wiring diagram that would be helpful if not are you able to get one? In any event make sure the wires are not misconnected.
Sep 12, 2007 | Maxon MCB-40 40-Channels Handheld CB Radio
Earbuds
If you are using vox (voice activated transmit) go into the menu and make sure you don't have the VOX setting too high. You should be able to put the headset on... hit the "push to talk" button on the radio and transmit you audio. Turn the other radio on and make sure the radio is "keying" (tx with no auio) then make sure there is audio. If you don't have audio but the radio is transmitting.. you might have the wrong type of plug on your headset for the audio..... there are 2 plugs... 1 for transmit audio....1 for recieve audio. It could be the wrong type of plug for the jack in the radio. Regardless.. the way the headset works is either you push the "push to talk button" onj the radio OR you use the VOX function... with the vox function you just have to talk into the mic to transmit. This is what your headset is designed for. You will have to go into the menu and set up the radio for VOX. If you still have problems follow my directions at the top of this page ( check mic jack and stuff) I think you just have to set the radio up for VOX operation and set the VOX setting. You should be able to push the push to talk button and talk through the mic on the headset. If you don't get any audio that way there is a problem and you should check the jack and plug on the headset.
Aug 25, 2007 | Motorola Talkabout T5720 (7 Channels)...
Maxon MCB 10 A
I'm not sure about your particular model but many CB radios use the microphone push-to-talk switch to kill the speaker while the radio is transmitting. If you don't have the correct microphone or if the cord has a broken wire it can cause the radio to have no sound. Another possibility is that the speaker is bad. There is probably an external speaker jack on the back of the radio. You could try plugging a different speaker or even an earphone in the jack to see if you get sound there.
Mar 07, 2007 | Maxon SP-100G (4 Channels) 2-Way Radio
Maxon MCB-30 40-Channels Base CB Radio Logo
248 people viewed this question
Top Maxon Radio Communications Experts
Steve
AnyMHz.com
AnyMHz.com
Mike Charette
Are you a Maxon Radio Communication Expert? Answer questions, earn points and help others
