Question about GE 29318GE1 Corded Phone
How to delete numbers that are stored leaving the memory storage empty?
No long distance service is available at this phone location at this time.  When one of the memory buttons is pressed, the operator comes on the line telling that no Long Distance service is installed.  To save the frustration of the person trying to dial without success, I want to remove all the long distance numbers from the phone.  Please e-mail me at:  cmapeach@Copper.net        Thank you for this service.  Sincerely, Mary Ann The model # of this phone is: 2-9268
Store a new number in the same location of that which you wish to delete. Otherwise, just don't use the buttion.
The procedure is
Pickup handset
Hit Store Button
Push numbered buttons for phone number
Hit Store Button
Put handset back on cradke
Record number
Posted on Nov 30, 2008
Need to program new phone numbers
The manual is available here: www.uniden.com/pdf/CEZ260om.pdf. If you search google for "uniden cez260 corded phone manual" it is the first result.
You can find the instructions in the fourth column of text under "Storing a Name and Number in Memory"
Here is the text from that section, but I can't promise the copied text is accurate. Check the pdf at that address if anything doesn't work.
1. Press STORE. LOCATION? shows in the display.
2. Press the desired memory location (0 to 9 or quick call buttons A, B, or C.) NOTE: Press LEFT or RIGHT to scroll through 0 - 9 or quick call buttons A, B, or C to select a location.
3. Press STORE again to con? rm the memory location. NOTE: Use Delete to erase existing memories or to correct errors.
4. Use the number keys to enter the telephone number (up to 32 digits) and then press STORE to save. (The unit will not dial a phone number in this mode.) The cursor automatically moves to the text line for name entry.
5. Use the number keys to enter the name of the person associated with the telephone number you just entered. More than one letter is stored in each of the number keys. Press the keys multiple times to scroll through the letters for that key. For example, to enter "B," press "2" twice. Press LEFT two times to create a space. NOTE: The ? ashing cursor automatically moves to the next position or you may press LEFT or RIGHT to move the cursor to the next position.
6. Press STORE to save the name.
7. To enter another name and number in a di erent memory location, return to step 1 and repeat this process.
Storing a Pause in Memory
The REDIAL/PAUSE button has dual functionality and becomes a pause button when pressed in sequence after the STORE button. It is valid only when storing a number into memory locations. Use the REDIAL/PAUSE button to insert a pause when a delay is needed in an automatic dialing sequence (for example, when you must dial a 9 to get an outside line or when you enter codes to access your long distance company).
NOTE: A pause is 3 seconds in length and you can store more than one if a longer pause is needed. Changing a Stored Number Repeat the storage sequence under Storing A Name and Number in Memory, and press DELETE to delete the old number before entering the new number.
Erasing a Stored Name & Number
1. Press STORE.
2. Press the memory location (0 to 9 or quick call buttons A, B, or C) to be erased.
3. Press DELETE.
Copying Caller ID Memories to User Memory
1. Press LEFT or RIGHT to view the caller number and name you want to copy.
2. PressSTORE.
3. Press the memory location (0 to 9 or quick call buttons A, B, or C). The number ? ashes if there is a number already stored in that memory location.
4. Press STORE to enter Edit mode, and then pressSTORE again to edit the name. NOTE: Select a di erent memory location by using LEFT and RIGHT to scroll through 0 - 9 or quick call buttons A, B, or C.
5. Press STORE to con? rm and save. Wait three seconds to exit.
NOTE: If the name you want to enter is longer than 12 characters, only the ? rst 12 characters will be copied into memory.
Storing a Redial Number to Memory
1. Press STORE.
2. Press any key (0 to 9 or quick call buttons A, B, or C) for the memory location. If a number is already stored in the memory location, it will appear on the display. Use LEFT and RIGHT to select a di erent location.
3. PressSTORE again to con? rm.
4. Press REDIAL/PAUSE, and then press STORE again.
5. Enter the name, if necessary, and then press STORE to con? rm.
Copying a Redial Number to Memory
1. Press REDIAL/PAUSE while on-hook. Redial number will display along with PICKUP PHONE.
2. Press STORE.
3. Press any key (0 to 9 or quick call buttons A, B, or C) for the memory location. If there is a number already stored in the memory location, it will appear on the display. Use the RIGHT or LEFT buttons to select a di erent location.
4. Press STORE twice.
5. Enter name, if necessary, and then press STORE again to con? rm and save.
Dialing Numbers Stored in Memory
1. Press DIAL.
2. Press a memory location button or use LEFT or RIGHT to scroll through stored memory locations to ? nd the desired number. The number in that memory location displays.
3. Press SPEAKER or pick up the handset to dial the displayed number.
OR
1. Lift the handset or press SPEAKER.
3. Press DIAL again to dial the stored number.
Jun 11, 2015 | Uniden CEZ260 Corded Phone
Recovery of delete messages from nokia n 72
1. Download and install this free
mobile File Manager - (FExplorer).
2. Launch FExplorer and navigate
to C: if you use Phone Memory
to store your message (default)
and D: if you use Storage Card
as your SMS storage location.
3. Now navigate to and open
system folder.
4. Now open the mail folder.
5. This folder should contain many
folders named similar to
0010001_s etc. with files named
similar to 00100000 etc., These
files are the actual deleted
messages, Simply use the
FExplorer browse through every folder
until you get the required sms.
May 17, 2012 | Nokia N72 Cellular Phone
Camera on standby phone memory full whats a sollution
The phone camera can only function when there is available storage for the image(s). So once it if full, the initial storage location is full, then you do have to create space for new images to be stored before the camera can function properly again.
If your phone doesnt have a memory slot, the means that you are limited to the memory size you use, which is your phone memory.
The solution here is to delete some data on your phone, or transfer it to another device. Then restart your camera.
If your phone has a memory slot, but your dont have a micro SD card in it, get one, then start your camera, go to settings, and change the storage to memory card.
If you already have a memory card, and it is not full yet, it means your camera is storing the images on the phone. Go to settings when you turn on the camera, and change the storage location to memory card.
But if you have a memory card, and it is full, you would have to delete some items to create space.
I hope one or more of the instances was helpful to you?
Have a nice day.
Jul 05, 2011 | Cell Phones
Putting numbers in the memory and editing
To store numbers in memory do the following
(Make sure the phone is in standby and not in TALK mode)
2.) Press the memory button on the handset or base.
3.) Press the desired memory location button (0 through 9 number keys) or
use the CID-VOL (- or + ) buttons on the handset or CID/rev or CID/skip)
buttons on the base to scroll to desired memory location. If the memory
location is occupied, the stored name and number displays. If the
memory location is unoccupied, EMPTY shows in the display.
4.) Press the memory button again. The display shows ENTER NAME.
5.) Use the base or cordless handset touch-tone pad to enter a name (up to
15 characters).
6.) Press the memory button again to save your selection. The display
shows ENTER TEL NUMBR.
7. Enter the area code followed by the
telephone number (up to 24 digits, including pauses) and press the
memory button again to save your selection. The unit beeps to confirm.
8. To enter another name and number in a different memory location,
return to step 1 and repeat the process.
Manual available HERE
Jun 17, 2011 | Uniden Cordless Phone
HP I can not live (hang), the possibility of storage memory full, because before I can not send SMS with the information storage is not enough memory
Welcome to FixYa!
To have more storage capacity for your phone, delete unimportant SMS in your INBOX, OUTBOX and SENT ITEMS. Delete also unimportant pictures, videos, music and ringtones. The phone memory is relatively small and is shared to all data and other files that are stored in the phone. By deleting some of these will free you some memory.
Alternatively, you can also put in a Micro SD memory card(Memory Card model depends to what your cell phone is compatible of, Micro SD is a sample) to your phone which will also increase its storage capacity. A Micro SD Card look something like the picture below.
A 16GB Micro SD is available at AMAZON http://astore.amazon.com/doityousol-20/detail/B001L1H0SC
Thank you for using FixYa.
Have a great day.
Jas247
May 18, 2011 | Samsung Omnia Pro B7320 Smartphone
How do you program #'s in to the phone
There are 20 memory locations to store numbers in, they are numbered 01 - 20. Press and hold the memory button until Memory Store shows in the display. Dial the 2 digit memory location or use the arrow keys to choose the memory location. Press the select/channel button which will show Store Name in the display if the memory location is empty or will show edit and delete options if the memory location has an entry in it. If the memory location is empty, use the number keys to enter a name for the memory location. Press the select/channel button which will show Store Number in the display. Enter the phone number using the dial pad. Press the select/channel button to save the entry. Press the memory button to end.
Here is a link to download the manual in pdf format.
http://www.uniden.com/pdf/TRU348om_VA.pdf
Jan 23, 2011 | Uniden TRU348 Cordless Phone
I need to know how to program the numbers into the speed dial option. My mother's phone is a table set with large numbers #29267A ... close enough?
Before you store a telephone number in memory, make sure the dialing mode is
correctly set for the type of service you have. The default dialing mode is tone
(touch-tone), so if you have pulse (rotary) service, you must first change the dialing
mode. See “To Set the Dial Mode.” The following buttons can be stored into any
memory location: 0-9.
STORING FREQUENTLY CALLED NUMBERS
1. Pick up the handset.
2.Press the store button.
3. Push the desired memory location button.
4. Press the store button.
5.Use the handset number keys to enter the telephone number (up to 16-digits)
and press the store button.
6.Hang up the handset.
NOTE: If you make a mistake, use the delete button to delete wrong digits.
CHANGING A STORED NUMBER
Repeat the storage sequence above. The new number replaces the old number at
ERASING A STORED NUMBER
3.Press the memory location (0-9) to be erased.
4.Press delete for three seconds until the number in the display is erased.
5.Hang up the handset.
DIALING FREQUENTLY CALLED NUMBERS
1. Pick up the handset and press the mem button.
2. Press 0-9 for the memory location. The number dials automatically.
OR
1. Pick up the handset and press the dial button.
2. Press the review button for the desired memory location.
3. Press the dial button to dial the number.
OR
1. Press dial button while the handset is still in the cradle.
2. Press the review button for the desired memory location, lift the handset and the
Download User Manual
If this information was helpful, please give me a big thumbs-up when you rate my answer. Thank you.
Feb 02, 2010 | GE 29267GE3 Corded Phone
Program numbers
Storing a Number in Memory
1. Press the STORE button. ENTER TEL. NO. is displayed.
2. Use the keypad to enter the phone number. You can put spaces in the number and it will still dial correctly. To enter a space, press NEXT button.
• To scroll forward or backward, use NEXT (when the cursor is not at the end of the number) or REVIEW.
• To erase the current digit, press DELETE.
3. When finished, press STORE. ENTER NAME is displayed.
4. Use the keypad to store a name (up to 16 characters). More than one letter or character is available in each of the number keys. For example, to enter the letter "A," press the 2 key once. For a "B," press the same key twice. For a "C," press it three times.
• To add a space, press NEXT.
• To scroll forward or backward, use NEXT or REVIEW.
• To erase the current character, press DELETE.
5. When finished, press STORE. MEMORY LOCATION is displayed.
6. Press the memory location number (0-9 or A, B, C) to store the number.
Here is a link for this telephone off the GE website:
http://www.home-electronics.net/ge/pc/IB/29897GE1_IB.pdf
May 11, 2009 | GE 29897GE1 Corded Phone
MOTORIZR Z3 - Message Memory Issue
One of my few complaints about my Z3 is the low message capacity. I have a 2gb sd card in there...why can't I store more than 500 texts?
But...500 is a lot more than 10, there's definitely a problem here.
I know there's a way to change the default storage location, although I'm not sure it will change the location of texts or not. Here's how to do it:
Go to the main menu and select "Settings". Scroll down to "Phone Status" and select it. Then select "Download Location" and finally, select the memory card.
Now...What concerns me the most is the 4Tb message flood O_o
Aug 27, 2008 | Motorola Mobility MOTORIZR Z3 Cellular...
Storing Speed Dial Phone Nmbers
Emergency/quick dial numbers: Pick up handset, push store, enter the phone number (it will not call the number), push store again, Push A,B or C. hand up handset. Frequently called numbers, pick up the handset, push store, enter the phone number, push store again, push key pad 1, or 2, etc. for memory location. Hang up handset. How to change a stored number. just repeat the sequence. How to clear a stored number, repeat the storage skip step 3 (do not enter the phone number). How to correct an error while storing, just hang up and repeat.
Feb 26, 2007 | GE Telephone pr521w
GE 29318GE1 Corded Phone Logo
281 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
