Question about Jenn-Air Pro-Style JFC2089H French Door Refrigerator
Refrigerator indicator lights read off and cannot be turned on by up and down arrows
Temp indicator lights read "off" cannot turn on by pushing arrows on either control.green indicator lights are off and alarm did not function. coils are clean.threw breaker off for 10 minutes to see if it would auto reset. Can you help?
    Sergeant:
  • 409 Answers
you have a problem with either the keypad or the control board. have you checked either one yet?
Posted on Oct 01, 2008
Chimes constantly. How do you turn them off?
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator. Cause of Beeping Noise in Frigidaire Refrigerator eHow
May 15, 2016 | Samsung RF263AEBP Refrigeration :...
There is a constant buzzing noise coming from the lower freezer ice maker. It is producing very few ice cubes. The control bar is down and in proper position to make ice.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
May 21, 2015 | Whirlpool Gold Series GB2SHTXTS (219 cu...
Refridgerator beeps
Fridge keeps beeping: The following is for Frigidaire models but others can be addressed similarly.
Apr 19, 2015 | Refrigerators
Is there any way to silence the sounds these machines make when you turn the selector knob or push any button
Apr 19, 2015 | Maytag Maxima MGD9000YW 27" Front-Load Gas...
How do you get the model 370lb to stopping beeping
Mar 30, 2015 | Refrigerators
Open door 18 beeps lights flash red green fridge not cooling
Mar 14, 2015 | Refrigerators
What does Sb mean on the door of my frigidaire refrigerator
Hello Andeo Deonarayan - Typically SB indicates that the unit is in Sabbath Mode. It is a feature that disables portions of the refrigerator and it is controls in accordance with observance of the weekly Sabbath and religious holidays within the Orthodox Jewish community. Sabbath Mode is turn ON and OFF by pressing and holding the down arrow on freezer temp and up arrow on refrigerator temper for five seconds.
Mar 07, 2013 | Frigidaire FPHS2387KF (226 cu ft) Side by...
Help!!
Have you tried unplugging the fridge and then replugging it in? Sometimes a power down/power up cycle will clear errors and get it started again...
Aug 24, 2008 | Maytag MFD2560HES Bottom Freezer French...
Jenn air refrigerator temp gauge problem
Hi again,
In your particular model I believe it is termed as "MaxCool". It is also possible that the sensor for the refrigerator is covered by a food item and therefore was getting erroneous readings hence cutting off early (making the temp go higher than normal). Based on this, you can try switching the food items around relocating them as to how they were placed inside. Incidentally, frequent opening and closing of the refrigerator of course would be exposing the inside to warmer air making the unit work harder.
The reset requires that the unit be unplug for an hour or more hence my suggestion during the Live Session to make use of a second refrigerator while checking out the Jenn Air.
Jun 02, 2008 | Jenn-Air JFC2089H Bottom Freezer French...
Jenn-Air Pro-Style JFC2089H French Door Refrigerator Logo
149 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
