Question about Denon DVD-2900 DVD Player
Denon DVD-2900 My CD's and SACD's will not play on my Denon 2900. The DVD's have no problem and play fine (sounds and picture). However, when I try and play a CD, the display indicates " loading" and then jumps to 00H00M00S. To the left of the time indiactor the word "progressive" is lit up in red. Can anyone help?
  • Anonymous Apr 14, 2009
    Same as Above
4 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: Denon 2910 CD player malfunctions
There has been a number of reports of similar issues with Denon models that utilizes the 'PureProgressive technology'. Some of the issues and tried corrective measures are -
1. It would appear that in certain occasion, performing a "region free hack" disables the 'PureProgressive technology' and one solution tried is to set the unit to NTSC and not multi or PAL;
2. disable/turn-off digital output;
3. some has reported significant improvement when a firmware upgrade was performed;
4. use DVI instead of of other outputs.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 13, 2008
By this time I figure most peoples warranties are expired. So give this a try:
1 Open the case.
2 Turn the unit on and load a disk.
3 On top of the disk transport, you will see a black disk trying to spin as it reads the disk. You might notice that it is a bit quite as the display goes to 00H00M00S. It should be fast and a bit noisy.
4 Try loading a disk again, except this time, try to help that little black disk spin. It might take a couple of attempts, but I was able to get my 2910 working again.
The last year I've had to do this 2-3 times. But it works. From what little I have read, it may just be an issue with lubricating the right part with the right oil. I've narrowed my choices to PTFE 3n1 oil, Lithium oil, or silicone oil.
now I just need to find the right places to oil.
There should be quite a bit of noise and speed
Posted on Sep 11, 2008
  • 4 Answers
you could try this http://www.fixya.com/support/t244156-denon_2910_cd_player_malfunctions or clean the lens
Posted on Jun 14, 2009
Transport problem on denon 2930
i strong recommend to go to the repair shop TV for fix it or evaluation if the cost is NOT higher, that will be better to buy a NEW one.
see the block diagram, and see how many circuit are involved .God bless you
Aug 02, 2012 | Denon DVD 2930 DVD Player
is this happening with all the cds??
the case may be with the cd sometime..where the tracks wouldnt have been properly completed...
Jul 13, 2008 | Denon DVD-2900 DVD Player
Denon dvd-2900 suddenly has music and background sound but no dialogue
Is there subtitles instead of the dialogue? Sorry, may be an obvious thing that you have already checked.
Jan 22, 2012 | Denon DVD-2900 DVD Player
The sacd player was working fine. But now will not play them. Using optical for sound hdmi for video. Played around with different settings but will only read the cd portion of the sacd. Any ideas? like i...
Your PS3 may actually be playing the SACD layer but if you're listering through optical you're not going to get any better sound quality than CD.
For stereo SACD quality you can use the analog outputs; for multichannel SACD quality you'll need to use HDMI.
See the PS3 SACD FAQ.
Jun 25, 2010 | Sony Playstation 3 (PS3) Console
What is the best way to attach a Sony SCD CE595 CD player SACD to a Denon AVR 2105 Receiver. I thought the optical input would be best but according to a web posting, toslink does not support SACD
That is correct. Digital connections through some models of SACD players are via "firewire", otherwise it is analog output. There are no optical connections.
The shortest pair of RCA cables, or even component video cable as an alternative will work.
Dec 12, 2009 | Denon AVR-2105 Receiver
Denon 2900 will not play CD's
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} hi!! we have read your problem.make sure the dvd player is kept in a position such that its able to sink the temperature ie (free space for 5 cms from the player on each side).clean the lens using only the recommended solvents.never use detergents or plain water and importantly dont touch the lens with bare hands. every problem has a solution.hope your problem is tackled..have a nice day
May 22, 2009 | Denon DVD-2900 DVD Player
Dennon 3930 dvd player unable to play sacd in 5 channels only in stereo.will play dvd-a disc in 5 channels
For DENON DVD-3930: In "setup", HDMI sound settings have to be "2-channel". Then SACD 5-channel output is enabled.
Jul 14, 2008 | Denon DVD-3910 DVD Player
Magnavox DVD Video Player DVD609AT
DVD609AT:
The manual is available at Philips website, the number for more info in manual is out-of-date; the new number is 1-800-605-8610
This unit has a problem when playing dual-layer discs of some kinds - read the warnings on the Magnavox website - playing the wrong kind of disc will cause an error that will require svc/repalcement to fix
Playable Discs
This DVD Player will play Digital Video Discs (DVDs) and Audio CDs. In order to play a
DVD or Audio CD on this DVD Player, make sure the Disc meets the requirements for
Region Codes and Color Systems as described on this page. Also, the Discs should have
the following logos and should meet these standards.
• CD-ROM
• Compact Disc-Interactive
(CD-I)
• Compact Disc-Recordable
(CD-R)
• Digital Video Disc-Video
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Super Audio CD (SACD)
• Photo CD
• Video CD
• Video Single Disc (VSD)
Digital
Video
Disc
12 cm
12 cm
Approx. 4 hours
(single-sided)
Approx. 8 hours
(double-sided)
Approx. 80 minutes
(single-sided)
Approx. 160 minutes
(double-sided)
20 minutes
8 cm
8 cm
(singles)
Logo
Maximum
Disc Type Contents Playback Time
Sound
and
Pictures
Audio
CD
Disc Size
Sound
74 minutes
Disc
Segments
DVDs are
divided into Titles,
which are divided
into Chapters.
Titles and Chapters
are numbered.
Audio CDs are divided
into numbered Tracks, i.e.,
a track may be one song.
Unacceptable Discs
If you insert an unacceptable type of disc, “Please insert a playable disc” will appear on
the TV screen. Also, “- - - - - “ will appear on the DVD Player display panel. Insert a
DVD or Audio CD. The following Discs will not play on this DVD Player.
• CD-ROM
(CD-I)
(CD-R)
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Photo CD
• Video CD
May 28, 2008 | Philips Magnavox DVD/VCR Dual Player
No SACD output
Set the HDMI to "Stereo" from multi-channel.
Mar 26, 2008 | Denon DVD-3910 DVD Player
Nov 06, 2007 | Denon DVD-2900 DVD Player
Denon DVD-2900 DVD Player Logo
361 people viewed this question
Top Denon Televison & Video Experts
Jonathon summesfield
Are you a Denon Televison and Video Expert? Answer questions, earn points and help others
