Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony Wega Trinitron KV-32HS20 TV
I have sound but no picture when I turn on the TV, and the standby light flashes 4 times then shuts the TV off a few seconds later. This happened once before and I unplugged the TV and put it into another electrical socket and it solved the problem. But this time I have tried this and it does not work. Any suggestions.
  • jettaracin41 Feb 15, 2009
    I just got the same TV from someone who had this problem. Can you tell me what I need to fix it. I can solder so that is not a problem.
    Thanks!
  • guitrman Apr 04, 2009
    so what is the solution, i am having the same problem
  • 4,234 Answers
The 4 blinks usually indicate a vertical problem. If you can solder, you can fix this yourself. Let me know if you wish to attempt this repair. If not, expect a parts cost of $10-$15 plus the local labor rate for the repair.
Dan
Posted on Oct 01, 2008
3 Suggested Answers
stonephoenix
  • 563 Answers
SOURCE: Sony FD Trinitron WEGA KV-32HS500...red standby light blinks 6 ti
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with
troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. If you're still in warranty, the TV will be repaired at no charge to you. The warranty would likely be at least one year from the date of purchase from the manufacturer. If you purchased an extended service plan they will repair the TV at no charge as well.
If the TV is no longer in warranty, it will likely cost a minimum of $150 parts and labor. This is assuming that you only need one
circuit board or small part. If the problem is more than one of the circuit boards, the price of repair could go much higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Posted on Jul 11, 2009
gopakumarg43
  • 74634 Answers
SOURCE: My sony trinitron wega KV-32HS20 shuts off,
Hello
Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly. Just decrease the screen voltage by adjusting the screen contron on the LOT, a little bit counter clocwise. Increased screen volgage also can make this fault. OK
Posted on Sep 28, 2011
My Sony Wega Trinitron KV-32HS20 does not tun on and the standby light flashes 4 times. I can hear the sound but no picture and the it turns off automatically after a few seconds.
This is a tip I got from a tech bulletin.
IC600 output pins 14, 15, 16, all have aprox 130v (all should be higher) until relay clicks
then they drop off. 200v line goes up to 50v, 135 goes up to 40v.
Checked D611 (135v rectifier) it was fine. Checked D615 (It's labeled D601 on the board)
it was shorted. (D615 is the 19v rectifier for the Audio B+) Removed D615 set power up
and has good picture with no sound.
Sep 08, 2010 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony Trinitron Wega KV-27FS100 picture on and off
i'd say your tv is unhappy.
unplug for 10 min..and see if that resets it.
May 31, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Kv-32fs16, no picture or sound , red lights flash 4 times
Hi
In sony tv`s the 4 blink code(sony error codes)usually means that there is a vertical deflection problem.
It is often caused by a faulty vertical output i.c and/or related components. If you feel handy with a soldering iron let me know and i`ll help you with it.
Hope this help Merry Christmas
Dec 17, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron TV. No picture; red standby/timer light flashes.
My Sony trinitron has the stero lite on steady and standby lite flashes four times then pauses and repeats. Can you tell me the circuit/condition causing the set to not turn on.
Jul 15, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Blinking/standby timer
Sony Trinitron TV. Worked well last evening. Now picture won't go on. When power is turned on, standby/timer red light flashes, but picture or sound does not work.
Jul 01, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Nov 29, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony Trinitron KV-32FS12
i think your tv had a lose contact or crack on board
Oct 18, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Kv-32s120 standby LED blinking no sound or picture
How many times does the timer light flash between pauses?
Sep 05, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony WEGA KV 32FS100
No picture. Standby light blinks 5 times. Tried unplugging and restarting. Same problem
Dec 22, 2007 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
364 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
