Question about Mitsubishi WS-65613 65" Rear Projection HDTV
Mitsu medallion hdtv ws-65613
I have already tried the reset and removed from surge protector and i have also replaced the four capacitors on the dm board however that has not fixed it either i was unable to read the original capacitors and went with the 35v 1000uf and then noticed that the originals are 16v 1000uf could this be the problem that the green light is still blinking or do you still feel it is a boot up error please any help would be great and i also dont think the tv manufacturer has sold everyone garbage but it still would be nice to see what im watching its tough going back to a small one when your used to a big one haha thank you very much
    Problem Solver:
  • 6 Answers
Hi Mikehill278,
No the capacitors should be fine 35v 1000uf are actually what I was told to put in and I just put them in and the green light went off and tv started up. However, now I have no video so not sure if I jarred something lose in the whole process. Anyhow, hope this helps.
Posted on Nov 08, 2008
Can't turn on the TV. Green light keeps blinking.
You need to change the four capacitors C9B01,C9B02,C9B10,C9B11 all 1000 MFD 16 VOLT (on the DM board which is inside the metal shield standing upright on the left looking from the back of the set)The tops of the capacitors will look puffed out making them easy to find. This is your HD tuner digital board which is trying to reboot but can't - when the green light stops blinking after a minute,than you can power on your TV.
Aug 26, 2007 | Mitsubishi WS-65613 65" Rear Projection...
The power light on the front of the tv has been blinking for 20 HRS now...have reset tv, plugged and unplugged and still will not come on. It is on a surge protector. Has done this before but never for...
If you unplug that unit and plug it back in the LED will blink for around 70 to 90 seconds. That is how long it takes for the DM module to boot up. When the blinking continues past that time it is because the DM module is not booting up and responding to the main micro. The fix is to replace four capacitors in the DM module. It will take a reputable tv shop to know how to do this repair. I have done many and this is a common problem with this model.
May 18, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi-ws55859 power failure flashing timer green light
the capacitors on the DM need to be replaced. Very easy repair you can get the repair kit at this link which is for your model it contains the replacement capacitors and step by step insturctions.
Apr 03, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Misubishi WS-65613 Flashing green reset light
do you have the service manual? also have you checked the diodes or protection fuses for the volts out of the loptr ( low output trans) , also check the volts on the trans for no volts , low volts , or voltage drop
let me know what tests and results you have , and if you dont have a schematic yet , this one should be about the same as yours , this is part 1 with 7 zip files
this is part 2 with 2 zip files,%20WS-65869,%20WS-55909,%20WS-65909,%20WS-73909.html
Nov 26, 2008 | Mitsubishi WS-65613 65" Rear Projection...
Blinking green light, will not power up
DM module repair instructions
Use four 1000mf 25v 105 degree capacitors for repair......T.
Jan 13, 2008 | Mitsubishi WS-65613 65" Rear Projection...
Mitsubishi WS-65613 blinking green light
Try doing the self test by pressing input/device and menu for 5 sec. You should get an error code by blinks. see
Dec 30, 2007 | Mitsubishi WS-65613 65" Rear Projection...
Mitsu HDTV 55 inch model #WS55613 power failure problem
Four bad 1000mf/25v capacitors in DM module = common repair
for qualified Mits tech.........................T.
Nov 03, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Flashing green button
Four generic caps 1000mf/25v 105 degree (high temp) buy from
any electronic supply, replace inside DM module.......T.
Oct 25, 2007 | Mitsubishi WS-65613 65" Rear Projection...
Ws 55513
The constant blinking green light means that the TV is not booting up. This is a common problem on this set.You need to remove the shield from the DM board (standing upright on the left where the DTV RF connector is)and inside you will see the four leaky capacitors (1000 MFD 16 VOLT)replace them,plug the TV in and wait 70 seconds for the blinking light to stop,then turn on the TV.The hard part will be removing the board from the TV(lots of screws and connectors,takes time)
Sep 22, 2007 | Mitsubishi WS-65613 65" Rear Projection...
Mitsubishi WS-65613 65" Rear Projection HDTV Logo
62 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
