Question about Drills
Hilti TE-60 hammer drill
I was wanting to take apart a TE-60 and can't get to the slug and the pistion of the drill how does the end come off of drill? Thanks Brent.
  • 2,176 Answers
What I would do if you have a fax machine is call 1-800-879-8000 and request a schematic on this tool first. Some of their products are not that easy to disassemble. I never have worked on the TE-60 but have on some of their other products and they are all different. Hope this helps
Posted on Dec 19, 2008
What hilti hammer drills use TE-C bits? I want to buy one
TE2, TE4, TE6, TE7, TE30, TE40. The 30 and 40 are only corded, (not cordless).
TE-C bits come TE-C (standard head) and TE-C3X which is a high performance bit. SDS is the industry term for this connection.
Dec 09, 2012 | Hammer Set Of 6 Hilti Te-c3x Drill Bits...
My hilti te-75 drills but is not hammering or will not go into chisel mode whay coud be the problem with it
Have seen this problem with some 'none' HILTI bits which do not fit correctly into the SDS chuck.
Tends to be with larger drill bits which have a wider shank than the SDS connector, the wider shank hits the end of the drill nose which stops the end of the drill bit contacting with the internal hammer.
Solution is to purchase original bits from Hilti. If you have OEM bits and chisel it will be another problem. Hope this helps.
Feb 07, 2011 | Hilti TE 70 Hammer Drill Performance...
How can i get to the hammer cam, is it repairable?
http://www.us.hilti.com/fstore/holus/techlib/docs/tool_schematics/drilling/TE_7_C.pdf
Breakdown for the Double Insulated(2-wire) Drill
http://www.us.hilti.com/fstore/holus/techlib/docs/tool_schematics/drilling/TE_7_C_Grounded.pdf
Breakdown for the Grounded(3-wire) Drill
These should help you take the drill apart, and get to the piece you feel you need to replace.
Let me know if this helps.
Nov 29, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
We have a Hilti TE72 Hammer Drill.... We have taken it to fix but they say they can't find parts... We think it is the piston and a rubber gasket that goes with the piston.... Do you have this?
Parts are no longer available for the TE72. You may find some used parts on EBAY. If the tool is not hammering it would need more than the piston and oring that goes on the pistion. Without all the proper seals and gaskets I would not even attempt to repair. If you do attempt to repair it do not put more than 70cc of lube in the drill. Too much oil will distroy the gears.
Aug 09, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
Te70 hilti hammer drill
The TE-70 is permantly lubricated. You would only add lubricant if you took the tool apart. You can add a small amount of grease to the end of your bit occasionally before putting in the chuck. This keeps the chuck parts lubed.
Jul 09, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
Hilti drill want hammer.
Not positive but I think that it works on air. Is there a cylinder with a piston in it. The orings could be blown?
Im not positive. Just tryn to help
May 30, 2010 | Hilti TE 70 Hammer Drill Performance...
Hilti te 15-c i have a oil leak behind the chuck.
It depends on where the leak is. if you email me I can send you an exploded diagram of tis machine. This will give you an idea of how to take it apart.
paul@wysehire.gi
Apr 09, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
Hilti TE 12. It will not hammer.
the rotory cam has been broken inside if not producing the hammer effect
Mar 11, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
Drills Logo
1,603 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
